04-15-2013, 02:54 PM | #1 |
12 bolt car vs. truck
Ok it's been a really long time since I've been on here....but it's good to be back!!! Anyway I am back working in my C10 and I was getting the parts lined up for the rearend and was reading about the difference in car vs. truck and I don't know what I have....it was given to me not with a rig so I'm worried and I don't quiet understand what is different....is the housing? Or the internals? Or all of it? I was going to replace everything but the housing pretty much....new 5 lug axels and an rayon posi unit with new gears....but I'm scared of buying missmatched parts...I have tried to search on here and the Internet with bono luck so hopefully I didn't miss a lot...but anyway thank for your help!!! You guys are the best if the best
-1969 C/10 Short Step soon to be Brand NEW Ls6/T56 -03 Mazda Protege 5 -WTB 1970 Chevelle project |
04-15-2013, 05:50 PM | #2 |
Re: 12 bolt car vs. truck
Nothing interchanges expect maybe a few gaskets, and their gear ratio's are a bit limited by comparison.
They are two different rear ends, and the car is better in nearly every way. If I am not mistaken the 8.5 10 bolt is stronger in more ways too then the truck 12 bolt. |
04-15-2013, 06:07 PM | #3 |
Most of the BOP ones are nice for a shell because its 4 link ready, first thing you do to a race car and off road truck, 4 link system. on the cars it just wasn't adjustable with stock arms.
just be careful for the 8.75 10 bolt cover with a 12bolt carrier inside, lots of those are posi [got one] but no one makes parts and no parts from others will fit. [you can reuilb the posi] can't even get the right 10bolt cover gasket, as its bigger then a 10bolt, but strong as a tank. |
04-15-2013, 08:07 PM | #4 |
1. Chevy car 12 bolt.
2. Truck 12 bolt. |
04-15-2013, 08:11 PM | #5 | |
04-15-2013, 10:10 PM | #6 |
I've heard the axles are slightly better, and usually have more teeth. Also the main caps are supposed to be a touch better.
If my truck had one I wouldn't rip it out, and I would actually build it up a bit. There fine for just about anything thrown at them. Except 500+ HP, and sticky tires. Or heavy off-roading. |
04-16-2013, 12:39 AM | #7 |
60-66 Nut
The 12 bolt car and truck both use 30 spline axles. The 12 bolt car gears can actually be used in the truck housing. There is a thread on this forum in the "Racing and High Performance" section with the bearing number to make it work.
There are actually a few members here that race their trucks and are still running the truck 12 bolt.
04-16-2013, 11:46 PM | #8 |
So how do I know what I have? I am assuming the housing are different...so do they measure out different? I'm fine running a truck 12 bolt I just wanna make sure I get the right parts
04-16-2013, 11:54 PM | #9 |
The rear covers are shaped different....Did you not see my earlier post?
04-17-2013, 12:04 AM | #10 |
60-66 Nut
Here is a link to a page with some more info on identifying a car 12 bolt from a truck 12 bolt.
http://www.drivetrainshop.com/GM_12_Bolt_s/105.htm
04-17-2013, 12:42 AM | #11 |
Grandpa in the rustmobile...
I sold the rearend from my 68 to a guy with a chevelle who was tickled to get it? lol idk
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
04-17-2013, 06:44 AM | #12 |
I'm running a truck 12 bolt with moser 33 spline axles c-clip eliminators and a car 12 bolt billet yoke and a full spool with welded axle tubes.. Works great so far.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
04-17-2013, 11:55 AM | #13 | |
Posted via Mobile Device Posted via Mobile Device
04-17-2013, 01:12 PM | #14 |
Raced a Narrowed 12 bolt with factory posi for years, twisted an axle once, but that was about it. 3500# car 14x32 slicks running 10's It's all in setting them up properly.
04-17-2013, 02:07 PM | #15 | ||
"I ain't nobody, dork."
Like mentioned earlier... the "weak" link in a truck 12-bolt is the smaller pinion diameter as compared to the car 12-bolt. But I have seen a lot of cats with trucks with truck 12-bolts putting some serious punishment to them, and they hold up fine.
Gary
04-17-2013, 04:24 PM | #16 |
Thank you guys just one last question and I know it's kind of broad but any idea what someone would charge to install the new posi axels exit if I bought parts....just strictly labor I have read the sticky and I might do it myself but just checking
Tags |
12 bolt, car, truck |
