Old 04-17-2013, 08:44 AM   #1
ozkiwi
Temporary heater core block off ???
Can I run a hose from the inlet manifold that normally goes to heater core directly to the heater hose inlet on the radiator to cut the heater core out of the circuit until I have a chance to replace it.
I cannot see why not but thought I should ask first.Seems easier than blocking off the radiator and the inlet manifold.
ozkiwi is offline   Reply With Quote
Old 04-17-2013, 08:54 AM   #2
J Knight
J Knight's Avatar
Re: Temporary heater core block off ???
Yes you can.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 04-17-2013, 08:58 AM   #3
ozkiwi
Originally Posted by J Knight View Post
Yes you can.
Old 04-17-2013, 09:08 AM   #4
meter swinger
meter swinger's Avatar
I have one of my trucks set up like that.
meter swinger is offline   Reply With Quote
Old 04-17-2013, 11:23 AM   #5
KQQL IT
At the body shop.
KQQL IT's Avatar
Pipe plugs instead of hose barbs works as well.
Old 04-18-2013, 05:20 AM   #6
wraprail
wraprail's Avatar
Only thing you mite run into is the inlet side of the heater core is 3/4 hose and outlet is 5/8. (Or the other way around)
I just did mine last week and used an old hose fitting ( the one that goes into the intake manifold) put the 5/8 hose on the hose end and the 3/4 hose on the threaded side (1/2 pipe) couple clamps instant hose adapter.
wraprail is offline   Reply With Quote
Old 04-18-2013, 01:52 PM   #7
wilkin250r
wilkin250r's Avatar
I've found that a good hose clamp can seal a 3/4 hose on a 5/8 fitting, they're not that far off.
Or, the other direction, I've found a little bit of heat, a little bit of lube, and some force can stretch a smaller 5/8 hose on a 3/4 fitting.
I know a little about cars, but if you have a question about electricity or sport quads, I'm your man!!!
wilkin250r is offline   Reply With Quote
