Old 04-20-2013, 09:43 PM   #126
naphtali5725
naphtali5725's Avatar
Re: My new project 86 Silverado
moved my cab out of the carport, now can sand and prime the bottom over the next few days.
moved my frame back into the carport up on jackstands.
now i can stay out of the rain while i do the frame, and clean up frame parts.
will be redoing all the tie-rod ends now, and the installing the LCA's
pics tomorrow...
will be going flip kit, and 2.5" drop spindles in the front after may 1st.
My build thread...
http://67-72chevytrucks.com/vboard/s...d.php?t=515829
Disabled Veteran
82nd Airborne Division
Operations: Desert Shield, Desert Storm, and Uphold Democracy
naphtali5725 is offline   Reply With Quote
Old 04-20-2013, 09:51 PM   #127
rs74
rs74's Avatar
I am glad you said that about the tie rods. I need to go ahead and put all my new steering stuff on. Did you end up getting any drop springs or are you cutting yours down?
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 04-20-2013, 09:57 PM   #128
naphtali5725
i'm going with Mcgaughy's drop spindles, and flip kit. not going to cut any springs, don't want the ride to suck
My build thread...
Disabled Veteran
Old 04-20-2013, 11:22 PM   #129
77ChevySharkBite
77ChevySharkBite's Avatar
Sounds awesome man!!! Can't wait to see the pictures!!!
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 04-21-2013, 09:28 AM   #130
68Timber
I know the pieces fit
68Timber's Avatar
Originally Posted by naphtali5725 View Post
since i have a 10 bolt that came with my truck, and a spare 12 bolt out of a Burb, I have been doing some reading...
it appears that a truck 10 bolt has a larger pinion than a truck 12 bolt, a car 12 bolt is stronger than a truck 12 bolt. so basically a truck 10 bolt is built stronger than a truck 12 bolt...will have to keep researching to see if it is worth the swap. if the truck 12 bolt is weaker, then i'll keep my 10
anyone confirm this?
That's what they say. I've read the debate a few times and can't pick a side anymore. When will your engine be done? Looking forward to the dyno pull.
John
79 2wd Blazer (Bruiser)
85 M1009 Blazer (Sarge) build
74 Honda Z50 build
Old 04-21-2013, 09:45 AM   #131
naphtali5725
I'm going with my 10, if I bust it to pieces, i'll have the 12 as a backup plan
Joe@cmengines said 2-3 weeks for the engine...
My build thread...
Disabled Veteran
Old 04-21-2013, 06:27 PM   #132
naphtali5725
frame is up and ready to be put back together
stripped all the dash foam off the dash panel.... i think i'm going to sand it down, and paint it so it looks like part of a cockpit panel or something and leave all the bullet holes in it....
finally got to where I can pull out my doors/fenders/bed etc.
My build thread...
Disabled Veteran
Old 04-21-2013, 07:20 PM   #133
mooseknuckles
mooseknuckles's Avatar
start weldin all those holes up....lol. I think it would look cool.
mooseknuckles is offline   Reply With Quote
Old 04-21-2013, 10:01 PM   #134
naphtali5725
LOL that's the thing. I was thinking of leaving all the holes there. like it's a lightened cockpit panel hehehehe
plenty of places for switches and lights
My build thread...
Disabled Veteran
Old 04-21-2013, 10:08 PM   #135
rs74
rs74's Avatar
I for one would like to see that happen. I would prefer the holes filled if it were mine but its not. Either way I would like to see it finished out. That would probably be pretty cool.
Roy
1987 R10 shortie
Old 04-21-2013, 10:27 PM   #136
naphtali5725
guess i'll have to save up for a mig welder then LOL
My build thread...
Disabled Veteran
Old 04-21-2013, 10:29 PM   #137
rs74
rs74's Avatar
Seriously, I think you might be on to something there. That would have never crossed my mind. The metal is pretty thin isn't it. I would be worried about it warping. Still a great idea. Do it!
Roy
1987 R10 shortie
Old 04-21-2013, 10:33 PM   #138
naphtali5725
i could weld some reinforcements underneath, it would stay rigid. i just thought it would be different. never seen one done like it before.
My build thread...
Disabled Veteran
Old 04-21-2013, 10:48 PM   #139
77ChevySharkBite
It's going to look awesome with whatever you decide to do! maybe weld some of the holes up, and leave a few to put some lights or guages in maybe?
Korwin
Old 04-22-2013, 11:55 AM   #140
naphtali5725
hood - half done
10 60 grit DA disks and 2 80 grit DA disks later.... damn my hands are buzzing...
My build thread...
Disabled Veteran
Old 04-22-2013, 12:02 PM   #141
77ChevySharkBite
Looking good bro!! Keep it up
It's one of the joys of sanding even when your done you still feel like your sanding
Korwin
Old 04-22-2013, 05:18 PM   #142
naphtali5725
epoxy primed bottom of cab...
stripped the hood to bare metal... epoxy primed
My build thread...
Disabled Veteran
Old 04-22-2013, 07:55 PM   #143
rs74
rs74's Avatar
Looks great! At this pace you will have it back together in no time.
Roy
1987 R10 shortie
Old 04-22-2013, 08:09 PM   #144
naphtali5725
that damn hood was a pain, i need to get some 40 grit paper cause 60 just didn't cut it good enough.
i'll be glad to get the front/rear suspension done so i can hang this cab...
My build thread...
Disabled Veteran
Old 04-23-2013, 12:09 PM   #145
naphtali5725
stripped the fender, 10 60 grit DA disks.... no body filler found on the hood or the fender so far.
degreased, and will prime later today after a final 80 grit DA sand
damn i'm tired...
My build thread...
Disabled Veteran
Old 04-23-2013, 01:35 PM   #146
77ChevySharkBite
Looking sharp man! You can do it, just think when it's all done you can sit back and admire your handy work and say DAMN I did a awesome job!!
Korwin
Old 04-23-2013, 02:17 PM   #147
inovermyhead
I'm no expert but I kept my 10 bolt (mainly b/c of cost) and put Richmond 3:73 gears in it. The guy that did my rebuild told me I was better off w/the 10 vs. the 12 b/c the truck 10 is stronger. He's been running a truck 10 bolt in his 81 Firebird drag car for years w/out any issues.
Nice build so far, keep at it. Can't wait to see how the dash is going to turn out.
81 GMC C15 RC SWB 5.3L 4L80E project
inovermyhead is offline   Reply With Quote
Old 04-23-2013, 08:11 PM   #148
naphtali5725
both fenders stripped to bare metal....
no body filler found!
right one has a few dings here/there...
will epoxy prime tomorrow after 80 grit and a wash
My build thread...
Disabled Veteran
Old 04-23-2013, 09:06 PM   #149
68Timber
68Timber's Avatar
Good Lord, you've removed some material haven't you? How big a compressor do you have? Looks great, tuned in for the progress.
John
74 Honda Z50 build
Old 04-23-2013, 09:37 PM   #150
naphtali5725
yeah man, but made the mistake of getting 60 grit DA paper--- took all day long , man I wish I would have had 40 grit
compressor is a porter cable 6hp 6.8 SCFM@90 psi 25 gallon tank - not a powerhouse but it will get the job done, i'll be spraying the whole truck with it too...
My build thread...
Disabled Veteran
