Old 04-08-2013, 12:40 PM   #1
chevy72blu
chevy72blu's Avatar
LS1 air intake for a 67-72
I have gone through lots of build threads, but I cant seem to find what I'm looking for.
What air intake setups are you using in your 67-72? I've seen some real cheap ones on ebay for around $60-70, but its difficult to envision what is going to fit and what wont from pictures.
I think just a simple 90* coming out of the TB with a 6-7" pipe and cone filter would work best. Street and Performance also makes a square element that bolts right to the TB. Any downside to this?
Also, what size tubing are you using? I am using the OEM 98' LS1 TB and MAF
Thanks!
edit: I am using a '98 F body rad and e-fan setup
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 04-08-2013, 05:30 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: LS1 air intake for a 67-72
mine is a k&n cai for a 99-up silverado.. fit pretty good, didnt use the box thing tho....can't see why it wouldn't work for 67-72's
mooseknuckles is offline   Reply With Quote
Old 04-08-2013, 09:02 PM   #3
85burb
85burb's Avatar
That is what I am using too. Not a 67-72 but for the price buy it and cut the angle part off if you don't like it. 69 bucks shipped.
82 c10 5.3/4l60
84 c20 5.3/sm465
85 chevy k10 suburban LQ4/4l60
91 chevy c10 suburban Lsa 5.3/4l60
2017 Silverado whipple 5.3
1964 Vw beetle
1974 vw beetle
85burb is offline   Reply With Quote
Old 04-09-2013, 12:40 AM   #4
mcmlxix
Collector of Projects
mcmlxix's Avatar
I started with a 90* silicone elbow and a K&N filter, both with a 4" inner diameter. What I have come to find out is that the MAF is slightly smaller outer diameter. I still need at piece of 4" pipe too.. I feel like I should have just bought a kit. I may save a few bucks in the end, but its a pain piecing it all together...
Rich
1972 K5 Blazer CST Click HERE
Old 04-09-2013, 08:28 AM   #5
85burb
85burb's Avatar
That is why I got a kit again. I was way over 70 bucks for the parts I wanted to make the intake and was having to use a tiny air filter. The one in my pic was 69 shipped with everything.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-09-2013, 10:41 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Here's my air intake.
Kinda looks like one of these Tornados inside.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 04-09-2013, 10:59 AM   #7
G8DAN
G8DAN's Avatar
Hahaha nicely done ^^^
G8DAN is offline   Reply With Quote
Old 04-09-2013, 12:35 PM   #8
chevy72blu
chevy72blu's Avatar
Thank you all for the help, this is perfect.
Do those tornado things really make more power?
RIP EastSideLowLife
Old 04-09-2013, 01:28 PM   #9
Wasted Income
Boosted Member
Mine does. haha.
Turbo diesel
Old 04-09-2013, 10:35 PM   #10
themb2g
Spectre makes one for an ls swap into a 69-72 truck. I'd show you pics of mine but I haven't installed it yet.
Check out my build: 1972 LQ4 Swap
http://67-72chevytrucks.com/vboard/s...=1#post5427693
themb2g is offline   Reply With Quote
Old 04-10-2013, 10:24 AM   #11
Wasted Income
Boosted Member
Ok now that i'm done being a smartass, I will answer your question. I would come off the TB with a 90* silicone elbow, 3.5 or 4" aluminum tube to the MAF (with silicone couplings on either side to connect to the tubing, then more tubing to your air filter location. Basically the same as mcmlxix mentioned.
FYI, since you're running a MAF (and not running Speed Density), you will not be able to come directly off the TB with a filter, unless you have room to sandwich the MAF in there.
I was MAFless on my jet boat, and did just the filter.
The monte carlo I built just had a quick and dirty intake on it. I have since put another 90 on the end to get the filter in front of the radiator to draw less warm air. I was seeing some pretty high IATs on hot days with it sucking under hood heat.
I'm a DIY guy, so I'd have a hard time paying someone to put something this simple together for me.
If you want to source the parts to do it yourself, I've had good luck with
www.siliconeintakes.com and www.racepartsolutions.com for finding silicone elbows, t-bolt clamps, aluminum tubing, air filters, etc.
That's pretty cool that they are developing a product for such a niche market.
Turbo diesel
Old 04-23-2013, 07:57 PM   #12
cjohnson6772
cjohnson6772's Avatar
Can you post a link at that price? I'm seeking them at like $300 plus!
cjohnson6772 is offline   Reply With Quote
Old 04-23-2013, 08:03 PM   #13
85burb
85burb's Avatar
Here ya go. Hope it works. http://item.mobileweb.ebay.com/viewi...id=38484525345
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2013, 08:09 PM   #14
cjohnson6772
Looks good. I guess I had been searching for K&N brand and getting those $$$ results. I'll probably just get that one in black though. Thanks!
Old 04-23-2013, 08:12 PM   #15
85burb
85burb's Avatar
Well you can get that one and later on buy a k and n filter later if you want one.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2013, 08:21 PM   #16
cjohnson6772
That's what I'm thinking about. Any chance you could measure from the center of the tb to the the BASE of the filter for me?
Old 04-23-2013, 08:24 PM   #17
85burb
85burb's Avatar
I have it installed right now. It's kinda a pain to remove but I can get a measure ment of it installed if you want me to.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2013, 08:39 PM   #18
mooseknuckles
sounds about right....
Old 04-23-2013, 08:59 PM   #19
85burb
85burb's Avatar
I have two set up two different ways. The red one is 20-21 from filter base to middle of throttle body. The blue one is 23-24.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2013, 09:16 PM   #20
85burb
85burb's Avatar
Blue
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2013, 09:35 PM   #21
cjohnson6772
Blue
Thanks! Extremely helpful. Is the only difference just the way the tb elbow is cocked?
Old 04-23-2013, 10:41 PM   #22
BigShoe24
True Addiction
BigShoe24's Avatar
Street & Performance
RCC
BigShoe24 is offline   Reply With Quote
Old 04-23-2013, 11:07 PM   #23
85burb
85burb's Avatar
Ya one may be compressed more then the other. There is some adjustment that can be made. And the blue one has a different water pump so the hose will route different to the rad.
82 c10 5.3/4l60
84 c20 5.3/sm465
1964 Vw beetle
1974 vw beetle
Old 04-23-2013, 11:09 PM   #24
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
you running a SD tune BigShoe?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 02-19-2014, 10:24 PM   #25
littlevictories
bought one of those cheap ebay CAI's
this one
http://www.ebay.com/itm/SIERRA-SILVE...fd4583&vxp=mtr
seems exactly like every other one i have seen. $65 shipped.
the seller included a 10% discount code if anyone needs it
K2-110109
good till the end of may
littlevictories is offline   Reply With Quote
