06-03-2012, 01:37 AM | #226 | |
Re: 8 lug wheels - what's on YOUR truck?
Sorry for all the questions, just trying to nail down some issues I'm having with wheels on my current project.
1967 K30 4x4/12v Cummins/getrag/D60/D70/355s 1967 GMC suburban 4x4/LS swap 5.3/4500/205/10 bolt/14 bolt full floater 1963 C10 reg cab long box 1970 Chevelle 1968 Biscayne 2dr post "...there is no excuse for what I am about to do, but dangit....it's gonna be fun!" |
06-03-2012, 01:56 AM | #227 |
Chevy Enthusiast
Those are Kelsey Hays 16.5s that came on camper specials, they made them in two different widths 9.75" and 8.25" which I believe is what he has.
Tony 1985 GMC K2500 restoration Project: Rust, White & Blue 1989 Chevy R3500 CC Cummins & 4X4 swap some day... 1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress) |
06-03-2012, 11:40 AM | #228 |
BlahBlahBlah
8.25 16.5 is correct. I dont have them anymore, sold them to another board member.
... Monroe Swap meet May 18-19. Mike has the same spots for the NW guys he's had forever. Lunch time BBQ at the spaces. If you have stuff to sell bring it along. If you have a question PM stllookn (Mike) here via the board. https://67-72chevytrucks.com/vboard/...d.php?t=851291 |
06-10-2012, 09:50 PM | #229 |
BlahBlahBlah
Im looking at Wheel Vintiques on Summits website and Im not seeing the 16 inch 8 lug steel wheels. I know a couple people on this thread said they got them from there. Could you get me a little more info ... part number or something?
Mark
06-10-2012, 09:59 PM | #230 |
I found that calling them was easier than the web site but they do have them for sure. Also Jegs has them as well 1 800 345 4545 is there number thats where I got mine they have all sizes like Summit. hope this helps also, jegs is 24 hours day on that # for orders and tech supports for parts and info as well
06-10-2012, 10:06 PM | #231 |
BlahBlahBlah
Ok, thanks for the info!
06-10-2012, 10:44 PM | #232 |
Wheel Vintiques 82-680804 - Wheel Vintiques 82 Series Wheels
1972 Custom Deluxe 20 4x4 burb 1971 GMC SWB CST 4x4 1972 GMC k20 4x4 (X- brush truck ) 1971 Chevy CST Blazer 4x4 1971 Chevy C/10 1970 Cab Chassis C30 157" 1971 Cab Chassis Custom 30 Deluxe 157" 292/4spd ( Napco Replica ) 1988 Chevy V30 4x4 wrecker challenger 4812 |
06-10-2012, 10:54 PM | #233 |
BlahBlahBlah
Gotta love more help =)
Does anyone know what the stock 8 lug rim width is? ... I'm not talking the Kelsey Hayes upgrade wheels. Just plain ol stock 8 lug width.
06-10-2012, 11:19 PM | #234 |
Summit Racing's part #WVI-82-680804.
1927 Willy's Knight 24,000 original miles, 1958 Impala 283/Powerglide, 1964 C-30 383/4 speed, 1971 Monte Carlo 350/350, 1972 GMC K2500 350/350, 1976 Chev. K10 350/350, 2006 GMC Sierra 2500HD LBZ Duramax/Allison, 2006 Chev. Silverado K3500 LBZ Duramax/Allison |
06-11-2012, 01:31 PM | #235 |
BlahBlahBlah
ttt for stock steel 8 lug width, not the Kelsey Hayes
06-11-2012, 02:22 PM | #236 |
06-11-2012, 06:07 PM | #237 |
BlahBlahBlah
Wow only 6.5 inches wide. Seems so narrow for a big truck
06-20-2012, 05:30 PM | #238 |
Has anyone ever seen a stamped 8-lug steel wheel (either aftermarket or modified "stock") that has been grafted to a 17" barrel???
I'd love to be able to use a stock set of hubcaps, and would really like to have the stock-appearing steel wheel but in the 17" diameter and with at least 5.5" of backspacing I realize it's an odd request, and will probably be a one-off custom job but I'm curious if it would even be possible to cut out and use a 16.5" center in the larger barrel???? Thanks for any links or suggestions on who might be capable of doing this kind of project. Bonus points to anyone who can post a pic where this has already been done by someone else! -G
1972 K5 - 502BBC/4L80E/Magnum205/Mog-9s/5.26s/38" BFG KM2s Find me on INSTAGRAM @MIGHTASWELLK5 '72 K5 - Greg's "Might As Well" Build |
06-20-2012, 08:44 PM | #239 | |
06-20-2012, 09:21 PM | #240 |
Thanks.
My only other idea was to find an off-the-shelf plain-looking steel 17" wheel and try to figure out a mounting scheme to hang a stock hubcap on it somehow? Maybe just weld the retaining "bumps" from the stock wheel to the generic wheel.... Or create some kind of wireframe mount that would latch to a factory hubcap? -G Posted via Mobile Device
06-20-2012, 10:40 PM | #241 |
Chevy Enthusiast
Check this out, definitely an idea: http://67-72chevytrucks.com/vboard/s...60&postcount=6
Or maybe the centers from some old 17.5" wheels would fit some outer 17" rings. If you could find some plain 17" steel wheels you like it probably would be easiest to just weld some tabs on them.
04-27-2013, 08:31 AM | #242 | |
The coolest would actually be to use the old center caps on these wheels somehow....
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
04-27-2013, 08:37 AM | #243 |
Six in a row makes it go...
I saved the clips from my split wheels on my '67, along with the hubcaps. Someday, in my spare time () I hope to mount them on my later-model wheels and run the old caps.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 The height of sophistication is simplicity." - Clare Boothe Luce |
04-27-2013, 12:03 PM | #244 |
Looks really good
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son |
04-28-2013, 05:59 AM | #245 |
Very cool! Thanks for sharing the pics. That would actually be a great way to mount the caps to newer wheels. Instead of drilling a hole for the rivet, I΄d probably spot weld the clips to the wheel instead though.
04-30-2013, 11:04 PM | #246 |
17 x 9 with 4.5" back spacing
American Racing Artillery AX181 Last pic is a photoshop of what I'm shooting for....
'71 Chevy 3/4 Ton Longbed '22 Chevy Tahoe RST '67 Firebird- 8 sec street car '19 Chevy CC 4x4 Duramax Dually |
04-30-2013, 11:29 PM | #247 |
05-01-2013, 09:09 AM | #248 |
Roto Reuter thats the name...
My C20 has Hummer H2 wheels and Chevy Caps.
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
05-01-2013, 04:34 PM | #249 |
I like that H2 Chevy cap combo
1969 Chevy K20 Custom Camper 350, 4sp, 33's High on plans, Low on funds |
05-01-2013, 05:36 PM | #250 |
The H2 wheels and Chevy caps will be going on mine when I get to that point. I'll have a little different looking cap though. I'm trying to mimic the original hubcaps.
