Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1967-1972 Chevrolet & GMC Pickups Parts Board > Blazer and Suburban Stuff
Old 05-02-2013, 02:24 PM   #26
muckmuck
Junior Member
muckmuck's Avatar
Re: Leftovers-72 Jimmy seat brackets, emblems, a/c, etc.
Luis- just noticed you are in LV so no need for your zip. If you want to take a look I can meet you somewhere.
muckmuck is offline   Reply With Quote
Old 05-02-2013, 02:57 PM   #27
jorgensensc
jorgensensc's Avatar
I'm interested in the rear seat front brackets pending dimensions. How tall are they? About 8" or about 4"?
1972 C20 Suburban- Big Blue Betty
'56 Chevy Bel Air Sedan- Frame up Restoration
-What would you attempt to achieve if you knew you could not fail?-
-I Refuse To Tiptoe Through Life, Only To Arrive Safely At Death's Door-
R.I.P. EAST SIDE LOW LIFE
jorgensensc is offline   Reply With Quote
Old 05-02-2013, 04:21 PM   #28
bluek5
bluek5's Avatar
How much for the 4x4 shift boot, black seat belt retractor, and gas tank straps?
Thanks, Paul
bluek5 is offline   Reply With Quote
Old 05-02-2013, 05:16 PM   #29
muckmuck
Junior Member
muckmuck's Avatar
Paul- shift boot is gone already by local sale but I do have the ring still, sorry! If you are still interested I will work you a deal on on three items you mentioned. I will post photos of the seat belt.
Old 05-02-2013, 05:17 PM   #30
muckmuck
Junior Member
muckmuck's Avatar
Jorgensensc...
Old 05-02-2013, 05:19 PM   #31
muckmuck
Junior Member
muckmuck's Avatar
Paul...
Old 05-02-2013, 05:20 PM   #32
muckmuck
Junior Member
muckmuck's Avatar
Another...
Old 05-02-2013, 05:26 PM   #33
jorgensensc
I'll take them. What is the price and does it include the hold downs also?
Old 05-02-2013, 05:33 PM   #34
muckmuck
Junior Member
muckmuck's Avatar
David...
Just noticed a little delamination in the curve around the tach. Let me know if you are still interested.
Old 05-02-2013, 05:40 PM   #35
29od1
If it looks pretty local/small area and the copper runs are still intact, then I'm ok with it.
29od1 is offline   Reply With Quote
Old 05-02-2013, 05:42 PM   #36
muckmuck
Junior Member
muckmuck's Avatar
I have the complete set priced at $100 shipped. This is with the hold down clamps, front mounts (2), and all four rear mounts...
Old 05-02-2013, 05:46 PM   #37
jorgensensc
Sounds good. Do you take PayPal? If so can you shoot me your Paypal addy?
Old 05-02-2013, 05:54 PM   #38
muckmuck
Junior Member
muckmuck's Avatar
PM sent.
Old 05-02-2013, 05:58 PM   #39
muckmuck
Junior Member
muckmuck's Avatar
PM sent
Old 05-02-2013, 06:57 PM   #40
muckmuck
Junior Member
muckmuck's Avatar
Still have another set of rear seat hold down brackets $50...
Old 05-02-2013, 07:46 PM   #41
Leroy-B1
Can I get a close up of other seatbelts and get a total price shipped to 28787 with the armrests if available
Leroy-B1 is offline   Reply With Quote
Old 05-02-2013, 07:47 PM   #42
Leroy-B1
The parchment belts
Old 05-02-2013, 07:52 PM   #43
Leroy-B1
Also a shipping quote on the a/c stuff
Old 05-02-2013, 08:07 PM   #44
muckmuck
Junior Member
muckmuck's Avatar
Leroy...
Old 05-02-2013, 08:08 PM   #45
muckmuck
Junior Member
muckmuck's Avatar
Another...
Old 05-02-2013, 08:17 PM   #46
muckmuck
Junior Member
muckmuck's Avatar
This is what is included with ac system.
1. Under dash diverter (or whatever it's called) is missing flapper.
2. One rubber hose that leaves coil is cut.
3. Upper slide on controls has broken lever.
4. Plastic connector tube for inside has broken bolt holes
Most of this and some other issues should be visible in photos. Includes only what is pictured...
Leroy... If this still interests you I will work up a quote
Old 05-02-2013, 08:25 PM   #47
Leroy-B1
Lets leave out the a/c stuff ...work me up a quote on the other
Old 05-02-2013, 08:47 PM   #48
muckmuck
Junior Member
muckmuck's Avatar
David,
PM sent with a total including shipping for the cluster and front seat mounts.
Old 05-02-2013, 08:48 PM   #49
muckmuck
Junior Member
muckmuck's Avatar
Will do. You are interested in just the two seat belts or all of them?
Old 05-03-2013, 12:52 AM   #50
Leroy-B1
All of the parchment I suppose how many more do you have?
