The Older Generation
Rear Axle Ratio Charts For 1967 - 1972 GM Trucks
I have saved these from different places so they don't match each other. I saved them as image files and they are all different resolutions and sizes. They really need to be typed into a document file so the size and style of font matches on all of the charts. Unfortunately I don't type good enough to do that so we will try it this way. I just hope they are all readable with the image size restrictions for the board. I think I have them sized close to the maximum that the board allows. Disregard the C14 designation in the '67 chart, it should be C10. In case someone is thinking Photobucket or some other photo hosting service, I won't do that for two reasons. One, I am not going to sign up for an account & Two, If the photobucket account is ever closed the thread will be worthless because their won't be any pictures of the charts in it, just empty boxes ... Thanks. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-21-2017 at 10:12 PM. |
Re: Rear Axle Ratio Charts For 1967 - 1972 GM Trucks
This is the last Chart. It looks like they are mostly readable. A couple of them may be a little blurry. There is no guarantee of correctness or completeness (is that a word?) in any of these charts Edit: I might as well add this chart to the thread too. Rear Axle Ratios Ratio 2.56:1 - Tooth Combination 41,16 Ratio 2.73:1 - Tooth Combination 41,15 Ratio 3.07:1 - Tooth Combination 43,14 Ratio 3.08:1 - Tooth Combination 40,13 Ratio 3.08:1 - Tooth Combination 37,12 Ratio 3.31:1 - Tooth Combination 43,13 Ratio 3.36:1 - Tooth Combination 37,11 Ratio 3.42:1 - Tooth Combination 41,12 Ratio 3.55:1 - Tooth Combination 39,11 Ratio 3.73:1 - Tooth Combination 41,11 Ratio 4.10:1 - Tooth Combination 41,10 Ratio 4.11:1 - Tooth Combination 37,9 Ratio 5.14:1 - Tooth Combination 36,7 The tooth combination numbers will be found stamped into the ring gear when you take the back cover off. They may not all be for the trucks. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 05-05-2024 at 05:35 PM. |
Nice job LocDoc, thanks for posting those.
CHEVY/GMC VIN DECODERS Last edited by bruceman1968; 08-15-2013 at 01:52 PM. |
This is great! I'm thinking this is for Chevrolet with the 10,20,30 designates. And,I don't see any posi for K/20,only No-Spin. A Dana 60 would have the Power-lok. It shows a 4.11 for K/20,which is the Dana 60,
![]() Join Date: Nov 2012
Thanks LockDoc!
![]() I'm sure many people will be less confused. Now there is a place to direct people searching for that elusive code!
If I have to be on 4 wheels, It has to be a classic Chevy 1967 c10 Longbed (Hawghauler/Icy weather transport) 2003 BMW K1200GT (Rain bike) 2007 Softail Deuce (Sun bike) 2009 Ultra Classic Electra Glide (Everything else bike) |
No problem guys. It might be nice to have them all in one place. I added some info to my 2nd post also. LockDoc
where can you find these codes on the axel?
1968 C10, 250, L6 4spd OTF, Fleetside Upgrades: Power Steering .......................____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ |
Usually on the passengers side axle tube. Just use the first 2 or 3 letters which ever it has. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 03-20-2020 at 01:12 PM. |
#9 | |
I'm not offended that the fonts and sizes don't match. Lends credibility to the documents, in my way of thinking. k
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
I never knew of a 3.36:1 ratio in these trucks. Looks like it was just in Vans. That would be a sweet ratio to swap into a little C/10
Proud owner of a 55.1 AD
![]() Join Date: Oct 2006
Thank you for posting. Great information.
Location: North Cal and no Sac or Bay area is not NORTH
Good stuff.
Never argue with an idiot, they will bring you to their level and beat you with experience.. |
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, all stock, Survivor. ![]() |
![]() Join Date: Dec 2012
I climbed under the truck this afternoon and coudln't find the axle code on the tube. Could they have put it under the spring mount? I REALLY don't want to unbolt the springs to check it.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#15 |
Are you talking the front axle? dana 44? that axle stamp is just to the right of the front of the pumpkin towards the upper area..
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#16 |
I don't think it would be under the mount. Sometimes they are stamped pretty light. There may be some that didn't get stamped. If that is the case you would have to pull the rear cover off, check the numbers on the ring gear and use the "Red" chart in post #2... Example: If the numbers 41 : 11 were stamped into the edge of the ring gear it would be a 3.73 ring & pinion. LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 11-19-2013 at 12:47 AM. |
#17 | |
Thanks Leon. It may not have been stamped or these old peepers just didn't catch them. I'll look again from different angles. It may also help to get my 5 year old under there. She sees EVERYTHING. Thanks for your guys help on this subject. I truly appreciate it.
#18 | |
No problem. Be sure and take a strong light and some coarse sandpaper under with you... Funny how those kids see it all.... LockDoc
#19 |
Look on top of the pumpkin passenger side of the pumpkin. I didn't think the Eaton had a stamp on the axle, i didn't see one on mine.
#20 |
OK I'll look there too. I did see some stuff stamped there.
#21 |
Okay, here's a total noob question, please don't flame me too badly
![]() For 1967 what's a C14 and why isn't there a C10 in the chart? Quick google on 1967 and C14 yielded nonsense. Is that a misprint for C10?
Dave L. 1967 Chevy C10 SWB Stepside, L6 250 1967 Chevy C10 Fleetside, LS2 6.0L 1972 Chevy C10 LWB Fleetside, 350 |
#22 |
well since i dont see it yet. I can probably OCR these are convert them to text. Ill fiddle with it today.
#23 | |
Well my OCR software is kind of crappy but it wont take to much to clean this up. You guys prefer csv, xls or just a text file. the coloms are never going to line up correctly in the forum so it should be a download of some kind.
#24 | |
I don't see a c14 listed for '67 in any of my literature so it is probably a misprint... LockDoc
#25 |
For 67 is c14 3.73 positraction the equivalent to a 67 c10 with 3.73 posi?
