Old 05-06-2013, 05:49 PM   #26
NoNeck
NoNeck's Avatar
Re: Wilwood Master Cyl question
Ed -
Here is the pic of the m/c hole and spacer plus one with the spacer installed. It looks just like yours doesn't it?
I noticed you are using a CPP master. Is it 1.21" (1-1/8") bore? Maybe only the 7/8" and 1" bore m/c use the spacer thingy... I could be wrong.
Chad has ordered several different length pushrods from Wilwood, so we are going to experiment with them when they get here.
Thanks, POP
2016 RAM Laramie HEMI
1966 Fairlane GT/A, 390/335 HP
If it costs you a dollar to make a friend, KEEP THE DOLLAR.
If it costs you a friend to make a dollar, KEEP THE FRIEND.
NoNeck is offline   Reply With Quote
Old 05-06-2013, 06:02 PM   #27
lolife99
67-72 parts collector,…
lolife99's Avatar
What does the front of the booster look like?
I always thought the spacer what needed for the trucks that run a booster.
(like in the second picture)
Flush with the back of the Wilwood M/C.
Keith
Convert to disc brakes.
lolife99 is online now   Reply With Quote
Old 05-06-2013, 06:07 PM   #28
nlped
nlped's Avatar
I'm with Keith! Mine looks just like the 2nd picture and I've been running it for quite some time. I just bought the aluminum one from Shawn072 because I'm great at pissin money away . I'd tell you to try the spacer... Mine has been on 2 other trucks before the '70 model...all with a p/b booster and the McGaughy 13" brake kit front & rear. I think that's the "ticket".
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 05-06-2013, 06:09 PM   #29
nlped
nlped's Avatar
My only other thought is that the pieces that came with the Wilwood go in the stock booster pushrod after you take out the adjustable "head" from the o.e. piece... just a thought?
Carter
Old 05-06-2013, 06:09 PM   #30
shawno72
C/10 junkie
shawno72's Avatar
Maybe you need to cut the spacer down to get the correct length??
Shawn
70 LWB C10 current driver/project
http://67-72chevytrucks.com/vboard/s...d.php?t=663051
68 SWB C10 Work in progress.....SOLD
http://67-72chevytrucks.com/vboard/s...d.php?t=559520
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
http://youtu.be/kbB0QrBIs9k
My mom always had the best advice. It was just a tad late. After a fall that involved blood, she'd say....."Careful!"
shawno72 is offline   Reply With Quote
Old 05-06-2013, 06:15 PM   #31
nlped
nlped's Avatar
I just double checked mine...okay like quadruple checked mine, and I am using the same booster pushrod (your pic "A") and I still had to use the spacer piece. My spacer piece is slightly longer than yours at 1 1/2" in length and I still had to adjust out the stock pushrod only slightly to get the appropriate drag on the m/c (or lack there of...something to do with pedal freeplay, I believe). I'm totally convinced that you should use the stock pushrod and the spacer doohickey. Put a little anti-seize on the spacer, put it in the M/C, install the o.e. pushrod into the booster, mount the M/C & give the pedal a push... bet you get fluid outta that M/C then... Be sure to put the bleeder lines back into the reservoir so you don't make a mess.
Carter
Old 05-06-2013, 07:32 PM   #32
Rusbuilt
Rusbuilt's Avatar
So just to make sure I understand correctly... With the mater cylinder mounted in place and the lines disconnected fluid doesn't even drip out?
Rusbuilt is offline   Reply With Quote
Old 05-06-2013, 07:48 PM   #33
nlped
nlped's Avatar
It shouldn't, right? Without compressing the piston, the reservoir is not "open" to leak out. Mine didn't leak but a drop or 2 when I pulled the bench bleed lines and installed the factory steel lines. Mine bled fine...after much pedal pushing.
Carter
Old 05-06-2013, 07:56 PM   #34
CC69Rat
CC69Rat's Avatar
Correct, .. thinking gravity feed, .. with the lines disconnected from the ports on the MC no fluid comes out. But, is is supposed to?
Pop, .. I think we need the doohickey. We just have to find the right pushrod. Don't hesitate to cut one if you need to.
(the push rod! .. )
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 05-06-2013, 08:09 PM   #35
nlped
nlped's Avatar
Lol. I'm thinking that you're over thinking it. Use the stock pushrod (screw it all the way in to start) and put in the doohickey and bleed the brakes. Then adjust the pushrod once you have appropriately bled brakes.
That's A LOT of pushrod, screwing & doohickey references.
Carter
Old 05-06-2013, 08:10 PM   #36
NoNeck
NoNeck's Avatar
Keith -
Here is a pic of the front of the CPP booster. The pushrods that came with the Wilwood M/C have little tips on the end that insert into the booster. Does that round metal thingy (Ed's word) on the end of the original pushrod come off? It doesn't look like it does.
On stock M/C's, there seems to be a lot more fluid seeping when you remove the bleeder screws to connect your metal lines. We get maybe a drop or two.
But, when bench bleeding the fluid really flows great through the clear bleeding tubes using a large phillips head screwdriver.
Maybe, since we now have 4 huge Corvette style units and replaced most of the brake lines, it will take a LOT of fluid to get them full.
Thanks guys!
POP
Old 05-06-2013, 08:16 PM   #37
NoNeck
NoNeck's Avatar
Ed -
After inserting the spacer in your M/C, did you have to apply a good bit of force to get it to slip over the booster bolts and depress the pushrod?
I tried using the insert in the M/C, but I couldn't get it to slide over the bolts?
POP
Old 05-06-2013, 08:22 PM   #38
NoNeck
NoNeck's Avatar
Oh, by the way... the stock pushrod will not insert into the CPP booster with that big circular metal thing on the end. The rubber shroud inside the hole is different from the original one. You can see the original rubber "washer" that slides into the factory booster still hanging on the pushrod "A" in my photos.
I was using the longer Wilwood pushrod "B" with the spacer when the M/C didn't want to slide on the CPP booster as stated above.
POP
Old 05-06-2013, 08:38 PM   #39
CC69Rat
CC69Rat's Avatar
Ok, .. let's just stop. I have three Wilwood branded (if that matters) push rods on the way. Summit had three available so we can just use the one we need and send the other ones back. All three of them make reference to using a Wilwood tandem MC with a booster.
Lets just wait and see what those do. Pop, I'll come up after work tomorrow and we'll look at it again.
Chad
Old 05-06-2013, 08:43 PM   #40
CC69Rat
CC69Rat's Avatar
Summit part numbers:
WIL-230-9384 http://www.summitracing.com/parts/wil-230-9384
WIL-230-3776 http://www.summitracing.com/parts/wil-230-3776
WIL-230-6926 http://www.summitracing.com/parts/wil-230-6926
Maybe one of these will work.
Chad
Old 05-06-2013, 08:48 PM   #41
nlped
nlped's Avatar
Wow!!! Well, waiting seems to be the smart thing to do.
Carter
Old 05-06-2013, 09:05 PM   #42
NoNeck
NoNeck's Avatar
Sounds good... we'll get it figured out. I will get with you tomorrow.
POP
Old 05-06-2013, 09:14 PM   #43
Rusbuilt
Rusbuilt's Avatar
Fluid should leak out of the MC when lines are unhooked. Think about it, gravity bleeding plus breaks can leak down sometimes while a truck sits. I would take the plugs out on both sides of the MC and see if fluid comes out.
Old 05-06-2013, 09:58 PM   #44
nlped
nlped's Avatar
Go to sleep. We will get it figured out tomorrow.
Carter
Old 05-07-2013, 06:48 PM   #45
CC69Rat
CC69Rat's Avatar
We have brakes!
Short push rod + doohickey = fluid. Thanks everyone for your help.
Chad
Old 05-07-2013, 08:10 PM   #46
shawno72
C/10 junkie
shawno72's Avatar
Originally Posted by CC69Rat View Post
We have brakes!
Shawn
72 LWB C10 Sold
71 LWB C10 Sold
68 LWB C10 CST Sold
Old 05-07-2013, 08:47 PM   #47
Rusbuilt
Rusbuilt's Avatar
Good deal!
Old 05-07-2013, 08:58 PM   #48
nlped
nlped's Avatar
Excellent!!! I'm you & Pops are happy happy happy.
Carter
Old 05-07-2013, 09:53 PM   #49
NoNeck
NoNeck's Avatar
I'm happy!!! Thanks guys.
POP
Old 05-07-2013, 09:57 PM   #50
CC69Rat
CC69Rat's Avatar
Not bad Pops! We have 95% pedal without the booster / engine running. I can't wait to drive it and once the booster engages... woo wee!
Chad
