05-11-2013, 04:53 AM | #1 | |
Re: Which intake for my truck???
The duration at .050" is 234 244 on the cam.
Gary Slowly looking for my next 67-72 truck |
05-12-2013, 04:46 PM | #2 | |
As for the spreadbore they work but they were designed as a quadrant replacement and the over size secondary's make for an unstable fuel curve at the top end. Depending on what rpm your turning that engine normally a normal double pumper or vac secondary will give it a good all around feel. The plus side is the spread bore will give a better cylinder fill and response at low rpm Right now I would lean towards the wieand Posted via Mobile Device
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
05-12-2013, 06:14 PM | #3 | |
I have an old weiand on there now, but it is leaking (sucking air) so that is part of the reason for replacing it. As far as rpms, I am turning up to 6k with the hammer down. My biggest issue has been a stumble or hesitation when accelerating from a roll, I didnt have it as much with the spreadbore carb as with the street avenger. Granted, I found out the intake was leaking when I pulled the spreadbore off so that has made matters worse. Just not sure which carb I should use either?
