05-08-2013, 11:22 PM | #101 |
Re: Project; Divorce Therapy ( 72 SWB 4x4 )
I'd like to know as well. I'll tell you what I used... a 4x4 and a U-bolt. Needless to say, I was pretty nervous.
Drew -------------------------------------------------------------------- Drew's 72 K10 85 k10 AKA "The Turd" |
05-09-2013, 07:26 AM | #102 |
I made it. It's not that hard if you can weld at all, and have access to some steel. It works really slick, it turns cab removal & install into a one man job ! It's also adjustable and should work on almost any cab !
Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
05-09-2013, 07:41 AM | #103 |
Well it's raining here so I told the blaster to hold off until next week, the body shop won't be ready for about a week anyway.
I've placed several orders for parts, a couple of big ones:
Here's a link to the Body Shop I'm using: http://www.colonialautobody.net/ The owner is my neighbor, he makes his money on collision repairs but takes on a few projects from time to time. He won't have his guys work on it, he will personally do my truck. I'll post pics when stuff arrives. Gary
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 05-09-2013 at 08:10 AM. |
05-13-2013, 06:08 PM | #104 |
Stopped at the blasters today and this is what I saw !!! No unexpected surprises, a few dents, one rocker needs replacing !!!! They are not quite done yet a little more on the cab and then the doors. This is about 6 hrs so far, they use crushed glass and low pressure so nothing gets damaged ! This is one solid cab !!! What do you guys think ?
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 05-13-2013 at 07:04 PM. |
05-13-2013, 06:13 PM | #105 |
More pics !!!
05-14-2013, 08:18 AM | #106 |
Looks good, what did they use for blasting material.
Matt Garage build http://www.garagejournal.com/forum/s...ead.php?t=6784 My slow but sure truck build http://67-72chevytrucks.com/vboard/s...d.php?t=394924 My philosophy on tires is the same as cigarettes. "smoke them if you got them" HAPPILY DIVORCED! |
05-14-2013, 09:21 AM | #107 |
They use crushed glass, it's very fine and the use lower air pressure so there's no damage to the sheet metal ! It takes more time & costs a bit more, but I believe it's worth it !
05-14-2013, 10:20 AM | #108 |
The Few, The Proud
Looking good Gary. That's a nice foundation to start with.
Shannon |
05-14-2013, 11:03 AM | #109 |
Thanks !!!
I'll post pics of the doors when I can, but they should be just as nice as the cab !
05-14-2013, 07:38 PM | #110 |
Love the project. I'm gonna start on mine pretty quick, what did you paint the frame with ? Thanx
05-14-2013, 08:40 PM | #111 |
It was sand blasted, epoxy primed then topped with urethane.
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 Last edited by CUSTOM/10; 05-14-2013 at 09:33 PM. |
05-15-2013, 05:13 PM | #112 |
Pics of the doors after blasting ! Other than some extra holes for different mirrors these doors are awesome. My body guy said he will weld them up and I'd never know they were there ! The white & tiny bit of black you see is seam sealer, there is hardly even a pit from rust. You just don't find parts like this around New England !!!
05-15-2013, 10:47 PM | #113 |
Nice doors for the east coast!
05-16-2013, 08:22 AM | #114 |
Hey Matt !
Just noticed the "HAPPILY DIVORCED" "LOL" So am I now !!!
05-16-2013, 08:25 AM | #115 |
I'll post up my shirt later today. You will like it.
05-16-2013, 10:13 AM | #116 |
Awesome starting point, not much work at all...we should all be so lucky to have a solid body like that in the great north east lol
05-16-2013, 10:32 AM | #117 |
Thanks !!!
The only reason I have this nice rust free sheet metal is having freinds with connections with truckers. I buy the stuff out west and get it shipped back. Thank god I have most everything now because the guy I used the most got out of trucking !!!
05-21-2013, 05:28 PM | #118 |
Up-date:
Well kinda, Made a stop on the way home to pick this up at the taxidermist : 50 Lb King Salmon from Alaska !!! The bedsides & cowl hood were delivered to the body shop, and I'll be dropping the cab & doors off next Tuesday and hopefully start getting this moving forward !
05-21-2013, 11:09 PM | #119 | |
05-28-2013, 06:32 PM | #120 |
OK..... Well the cab and doors are finally at the body shop !!! Woo Hooo !!!
Know I just hope this doesn't turn into Paint Prison like what has happened to so many others !!! The new bedsides and cowl hood are also at the body shop, had them shipped directly to them.
08-03-2013, 06:27 AM | #121 |
Hey Gary, just happened to run across your build. Everything looks pretty nice, have any progress on the truck lately.
Scott |
08-03-2013, 07:13 AM | #122 |
It's in paint jail right...... "LOL". They're make progress but slowly. He is working on it in between insurance jobs. Cab, doors and the front clip are almost done being aligned, primed and block sanded. Should have some color soon.
I need to either get a bigger garage or lower the truck some. My door is only 6'6" ..... I can get a 7' in, but I think I'm going to remove the 4" lift and put in a 2" and sell the 4". Between doing both it should fit in ! Gary Posted via Mobile Device
08-03-2013, 08:12 AM | #123 |
Good to hear your truck is still progressing. Have you narrowed down to what color your going with?
Scott |
08-03-2013, 09:44 AM | #124 |
Green and white 2 tone. That's what it was originally. I like the orange and white just as much but the originality of the green and white won-out !
The green will be med olive metallic. Code 502 I believe.
08-03-2013, 09:48 AM | #125 |
Cool, it's going to look nice.
Scott |
