Old 05-17-2013, 03:44 PM   #1
ubtripn
ubtripn's Avatar
Just got this engine for $1300
All new. I do not have a ton of experience buying engines but I figured I could roll the dice for this much. What do you think?
87-95 series 350 (5.7) Four bolt main, bored 40 over, Moresa pistons, cast iron rings, Engine Tech lifters, SA cam, 10 under rod, 10 under main, 10-10 crank, machined heads, SA timing set, spread bore Edelbrock manifold, Mr. Gasket oil pan, valve covers, timing set cover, all chrome. 2 inch crank for flywheel, gasket set for accessories
ubtripn is offline   Reply With Quote
Old 05-17-2013, 03:46 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: Just got this engine for $1300
good find. It should be a great powerplant.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 05-17-2013, 04:04 PM   #3
ubtripn
ubtripn's Avatar
I am really looking forward to finding out!
Old 05-17-2013, 05:02 PM   #4
Rufton
I would do some spot quality checks.
Some easy spot check examples:
Verify dip stick level indication correct.
Verify lifters adjusted to spec.
Verify #1 TDC lined up correct.
Verify >50psi oil w/ drill prime.
Verify oil flow to valve train w/ drill prime.
Verify head bolts don't turn when torqued to spec.
Look closely an intake end gaskets/RTV.
Note quality of gasket/RTV application.
Drop pan and verify all crank bolt torques.
Verify oil pump bolt torque.
Verify crank clearances w/ plastigauge.
If all pass and I'm feeling lucky I'd consider startup.
Rufton is offline   Reply With Quote
Old 05-17-2013, 06:10 PM   #5
Coley
Coley's Avatar
Smile Re: Just got this engine for $1300
I recommend you put a starter on it, a ring gear and compression test before you do anything much just yet.
If the numbers come out nice and fairly even, then I would proceed with all the fun stuff!!
Good Luck, keep us posted!
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 05-17-2013, 06:42 PM   #6
SS Tim
SS Tim's Avatar
Start with a cylinder leak down test. It will tell you far more about the condition of the engine than a compression ever will.
SS Tim is offline   Reply With Quote
Old 05-17-2013, 07:10 PM   #7
woodywoodward_123
woodywoodward_123's Avatar
I have been watching Boise craigslist for a long while to find a deal like that. good work
woodywoodward_123 is offline   Reply With Quote
Old 05-17-2013, 09:33 PM   #8
68c10airstream
68c10airstream's Avatar
Hi tim, i thought i was the only one to use a cylinder leak tester! 10% loss or more equals more checking and possible trouble. Is my memory correct? I just joined a week ago but you must have worked in repair shops also, as i did. Brian F.
68c10airstream is offline   Reply With Quote
Old 05-20-2013, 12:31 PM   #9
ubtripn
ubtripn's Avatar
Thanks guys, I will do it all!
Old 05-20-2013, 12:40 PM   #10
jhwkns
Registered Cruiser
jhwkns's Avatar
Good price on that.
It's difficult to get a good gasket seal on those chrome parts. If you "rough up" the mating surfaces of the chrome parts with fine sandpaper, the sealer will get a better bond. Otherwise plated pans, and front covers notoriously leak.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 05-20-2013, 03:49 PM   #11
ubtripn
ubtripn's Avatar
Good to know, thanks!
