Burb Roof
The 63 I just bought has a jacked up motorhome style sunroof in it. Would the best thing to do is find a donor and patch just the opening or cut more and go drip rail to drip rail with the piece? Or keep the sunroof and update it.
Re: Burb Roof
Also was on ebay and happened to see this
http://cgi.ebay.com/ebaymotors/1962-...item589ff7f7da |
1961 crewcab
Re: Burb Roof
the sub/panel had a slightly taller roof (above the drip rail) than the pickup, however you should be able to use part of a truck roof for your patch, a pic of what you have might help us make better suggestions.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: Burb Roof
I have a spare
![]() ron |
Check The Champ, Demonstrator
![]() Join Date: Jun 2009
Re: Burb Roof
Is there a difference in the roof panels according to production years?
1963 Chevrolet Truck Literature LINK: https://picasaweb.google.com/113840717762774560215 YouTube Channel with 20+ Original Chevrolet Truck Salesmen, Mechanics & Service Department Training Slideshows. https://www.youtube.com/results?sear...otruk63&page=1 |
1961 crewcab
Re: Burb Roof
I think the roof panel/skin is the same, it is just the frame work around the windshield that is different.
Re: Burb Roof
Mine had a leaking 70's sunroof. I took the whole top off and spliced in the pillars. that piece of padresags would be ideal. there is less inches of metal to weld and the all the corners reduce warpage. I did my whole roof in a weekend.
Re: Burb Roof
forgot I had some pics.
