06-02-2013, 07:25 PM | #1 |
1971/72 4X4 Small Block Exhaust Manifolds/Valve Covers
WTB 1971/72 4X4 Exhaust Manifolds for 3/4 ton and Valve covers with bolts.
Also interested in heat riser tin for manifold and tube to Air Cleaner. Let me know if you might have something? Alan Last edited by My72BB; 06-02-2013 at 07:41 PM. |
06-02-2013, 08:10 PM | #2 |
Re: 1971/72 4X4 Small Block Exhaust Manifolds/Valve Covers
If whoever gets you the valve covers doesn't have the bolts and hold down tabs, I have some. pm me as I will forget to check back.
Chuck 68swb Fleetside build ''Choncho'' http://67-72chevytrucks.com/vboard/s...d.php?t=374892 My trailer redo http://67-72chevytrucks.com/vboard/s...69#post5893869 Chuy my 59 bug http://67-72chevytrucks.com/vboard/s...d.php?t=653798 Putnam 87 GMC Shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=707687 |
06-02-2013, 08:27 PM | #3 |
I have some exhaust manifolds but not sure what year / years they are, do you have part numbers ?
Gary Posted via Mobile Device
Gary 72 SWB 4x4 My 72 SWB Build http://67-72chevytrucks.com/vboard/s...d.php?t=259859 |
06-03-2013, 10:18 AM | #4 |
I will have to get back to you on that...I know I need Ramhorn style center straight down dump...no angle. Also does not need accessory bolt holes like the pre-67ish had I believe.
Will get back with a picture and part #'s. thanks. |
06-03-2013, 11:00 AM | #5 |
I'll also take a look at what I have, I do believe they are center dump straight ram-horn manifolds from a 4x4 but don't know what yr.
Gary
06-04-2013, 07:26 AM | #6 |
I have pictures of the ram horns I have, but can't seam to up load them to the site. If you want PM me your email address and I'll try sending them to you. If not I maybe able to up load them when I get home tonight.
All are straight center dump in good condition. Gary
06-04-2013, 08:41 AM | #7 |
OK...Sending you a PM.
Thanks...Alan |
06-04-2013, 09:06 PM | #8 |
Custom/10...Thanks for the pictures...I ran the numbers and while they will work 2 of those are 58-65 Vette/Car and 1 is 69-70 car so at this point I'm going to pass.
Thanks for the pictures. Still looking for 71/72 vintage 4X4 Truck manifolds. |
06-04-2013, 09:39 PM | #9 |
Vintage 4x4s
If you're not in a hurry I may part with a set. Need to inspect and sort what I have
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades) 67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore ) 86 CHV K30 502 th400, apple red NEW 71 CHV K20 350 SM465, ochre (saved work truck) 71 CHV K20 292 SM465, white, tach, PTO, (future project) 72 CHV K20 350 350th, medium blue (project stocker) 01 CHV K2500hd crew, indigo blue ^3 dont run and the others don't see winter either '86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649 '71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642 '72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6 |
06-04-2013, 10:35 PM | #10 |
OK...let me know...any idea of time frame your thinking?
06-05-2013, 07:02 AM | #11 |
No problem ! They were taken off 67-72 4x4,s, so someone must have swapped them in the past. Good to know what there from anyway.
Thanks ! Gary
06-05-2013, 08:15 AM | #12 |
Custom 10, do you have a driver side manifold for a 350? I'm looking for one. TJ
06-05-2013, 10:19 AM | #13 |
TJ Sent you a PM.
