![]() Join Date: Aug 2008
1970 Chevrolet C10 OEM fuse block & under dash wiring harness with guage & AC
Entertaining all offers!!!
This is an interior wiring harness and fuse box that was removed from a running a driving 1970 Chevrolet C10 pickup. The truck did have gauges. It also did have A/C. This harness will fit other 67-72 chevy trucks, but I cannot guarantee anything. I cleaned the harness with soap and water after I removed it from the truck. As mentioned above, this harness was removed from a running and driving truck, but it is not without issues: 1. There is some heat damage to the headlight switch plastic plug. The headlight connector had been connected using butt splices. I removed these, soldered and heat shrank the joints. The headlights were functional. (See photos #3,4 &5) 2. The wires for the connector for the dimmer swich have been connected using butt splices. This appears to be a good repair done with the correct crimping pliers. I can replace the butt plices with solder and heat shrink 3. The white wire for the wiper switch had the insulation stripped but the wire wasn't cut. I removed the terminal from the connector and applied heat shrink over this area. 4. The yellow wire for the left rear directional/ stop lamp had the insulation stripped but the wire wasn't cut. I removed the terminal from the connector and applied heat shrink over this area. The connector for the neutral safety switch is missing. 4. The grey wire for instrument and panel lights has been cut. I did not think to check if the instrument lights were working before I removed tha harness and I didn't have a wiring diagram at the time. $100 shipped USPS Priority Mail to the lower 48 states, you cover the paypal fees SOLD Last edited by WIDESIDE72; 11-22-2013 at 11:07 PM. |
Re: 1970 Chevrolet C10 OEM fuse block & under dash wiring harness with guage & AC
Photos
more photos
ttt
ttt
Ttt
Posted via Mobile Device |
Sold to jaborabbo
