06-15-2013, 02:10 PM | #1 |
gas tank for blazer
I bought a gas tank that fits a blazer and I am installing it in a 68 chev short wheel base steep side C10. The tank came in and with it was the sending unit and two rubber o rings. My question is: Which O-ring do I use? The one with the tab or without the tab. Since I'm dealing with gas I want to get a good fit and no leaks. What is the correct way to install the oil ring? Is there a lub that is used on the oil rings also? Gdavis
Check out Patches Cars I owned in the past. 1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev 1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS 1967 Buick electra 225 1995 Harley Davidson bager What does not kill you will make you stronger 1968 c10 short wheel base stepper |
06-15-2013, 03:41 PM | #2 |
Re: gas tank for blazer
Might be simple but do the 0-rings sandwich the sending unit?
tank - o-ring - sending unit - o-ring - lock ring? |
06-16-2013, 03:55 PM | #3 |
That might be the case. I really don't know. I thought that someone here has installed the sending unit on a poly tank.
06-17-2013, 02:23 PM | #4 |
I just dropped my oem tank, and it had the o-ring with the tab on it
06-17-2013, 03:48 PM | #5 |
Thanks a lot for the informaton on the o-ring. But, I need a three hole bracket that attached to the tank. Tank number 2042 the previous owner had altered it and now it is distroyed. So the short story is. I have to get another one. I contacted the builder of the tank this moring. I hope they can ship me another one.
06-18-2013, 04:07 PM | #6 |
How do you plan to attach the filler neck to new tank. Just curious because mine leaks there. Someone previously did something incorrect so I need to re do this.
Posted via Mobile Device |
