Old 01-25-2011, 04:49 PM   #26
kwmech
Re: How much does it weigh?
My 68 GMC with a big block and a lumber rack weighs in at around 4500
Old 07-01-2013, 05:44 PM   #27
Prematuregrey
Prematuregrey's Avatar
Thought I would add to this since I ran mine over the scales last month.
71 K20 LWB is 5200#
Mine has a BB, twin saddle tanks (empty at time), 1 ton axles with HD sway bars, 4" spring lift, dual shocks all around and steelies no AC or radio equipment.
Pretty light imho, compared to my Benz and 4Runner it's down right scrawny. 2nd gen 4Runners curb around 5800# same as the 560 SEL and my Runner is around 6500# geared out.
Owner: Times Are Tough Toys
92 4 Runner (Joyce, long story from my time in Africa) Lotsa stuff, just about finished dumping money into it.
89 Mercedes 560 SEL, Merdle. Wrecked
71 Chevy K20, Clifford, BB and 1 Tons
Prematuregrey is offline   Reply With Quote
Old 07-01-2013, 05:47 PM   #28
71GeneralMotorsCorp
My 72 Chevy with a built 327 and a turbo 350 weighs in at 4624#
"Repetition penetrates even the dullest of minds"
71GeneralMotorsCorp is offline   Reply With Quote
Old 07-01-2013, 08:48 PM   #29
WorkinLonghorn
WorkinLonghorn's Avatar
I think those weights in the Data Book are for standard trucks without options or add-ons. Six cylinder 3 speed etc.
AC, Power steering and brakes, V-8 or big block, 4spd etc. adds weight.
My '69 GMC weighed 4680 (when I bought it in '98) on the scale empty but it has saddle tanks, dealer AC (?), wood bed, rear step bumper, etc. (The GMC equivalent of a Long Horn also).
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, 2nd owner, Work-Truck supreme. Best $300 I ever spent.
WorkinLonghorn is offline   Reply With Quote
Old 07-02-2013, 01:01 AM   #30
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Where are you getting those numbers? that seemed awfully high so I googled them and they are both 3600 to 4000 lbs curb weight.
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 07-02-2013, 11:40 AM   #31
Prematuregrey
I stand corrected. Could've sworn I got the 4Runner weight off of Edmunds and estimated geared weight from what I've put in it, but looking now and you are correct. Now I've got to go and weigh them both out to fix my mind. The Benz weight I got off the title and will have to check that too.
Old 02-10-2017, 03:47 PM   #32
a1vintage69
a1vintage69's Avatar
My K20 4x4 Cheyenne Super Custom Camper with weight adding options include a/c, heavy duty camper springs and Eagle alloy wheels + 285/75/16 and 1/4 tank of gas weighted at 4800 pounds! With me and the rubber bed mat in it was over 5000, so I removed the mat and me. For California DMV weight fees under 5k is much cheaper.
I hope this helps someone.
[IMG][/IMG]
a1vintage69 is offline   Reply With Quote
Old 02-10-2017, 09:21 PM   #33
Gromit
My 1970 C10 weighed 4,010 (after subtracting my own bodyweight) according to the scales at the local landfill last time - it has: Long Bed, HD springs, SB350/TH350, front stabilizer and power steering and original steel wheels, regular chrome bumpers and no bed mat but sacrificial 3/8ths plywood. Factory A/C but that entire system is removed at the moment.
Fleetside and steel floor..
Gromit is offline   Reply With Quote
Old 02-10-2017, 09:34 PM   #34
Coley
Coley's Avatar
My 'real deal' numbers on my C10, 8ft. fleets were in keeping with the measured scale numbers here.....ie: all over 4000 lbs.
My last C10, 8ft bed (Cheyenne Super), with 350, a/c, ps, pb...& without me in it was around 4100 lbs on the scale.
The numbers listed for weights in a lot of GM literature are absolutely bare bones, stripped weights...often with a 6 cylinder, no options and no rear bumper...so do not use these as the number for you truck.
Simple...take it over the scale and weigh it. If you have one of the freeway where you live, just go over there when they are closed and check it out...easy peasy.
I'd love someone to post up a 3800# measured scale weight....I've never seen one of those despite the literature.
That said, you can count on that C20 being (at least) 4500 lbs if it has a V8, ps, pb and a rear bumper.....and thats probably without you in it.
Important operational note: If you have spare fuel tanks you can always fill them with Helium in order to reduce your road weight.
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 02-10-2017, 09:55 PM   #35
hjewell2
hjewell2's Avatar
Originally Posted by cam.man67 View Post
Nope. C10 (8ft fleet) weight for 1971 is 3605 lbs, and the C20 is 386 lbs heavier.
Here's a source for you:http://www.oldride.com/library/1971_chevrolet_c10.html
The perception that trucks are piggish, overweight brutes is only a result of the past two (maybe three) generations of American vehicles which, due to incessant government nannying, are increasingly heavy and plain huge. Ours, however, ain't that way.
everybody also says the old trucks got 10 MPG HMMM lets see here ,, my 2007 siverado gets 18MPG ,, my 1970 C10 gets 16-17 MPG
hjewell2 is offline   Reply With Quote
Old 04-27-2017, 10:41 PM   #36
Chevycruisin88
Hey guys does anyone know how much the bed itself off a long bed weighs? Going to pick one up for my truck but was wondering if we could just load it up on my buddys truck without a flatbed trailer...my truck isn't running or I would take off the old one and just bolt up the new one.
Chevycruisin88 is offline   Reply With Quote
Old 04-27-2017, 10:56 PM   #37
a1vintage69
Truck beds can get damage very easy. If you can use a trailer it is much better. good luck. a1
Old 04-27-2017, 11:01 PM   #38
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Heavy enough my floor jack told me it stands replacement. It was used to lifting the front of a C10.
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assm. guide "kit" for restoring the truck from ground up. With assys, the guide accts for 1000s details, OEM identifications & part numbers, written in short order. 700+ images of assm., illust., charts, and points of interest. Much of the info. applies to all 67-72 GM trucks, and to a lessor degree all 67-72 GM vehicles. My build thread, and more on the guide https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
Old 04-27-2017, 11:08 PM   #39
Gromit
I would guess 325 pounds without the tailgate but If no one else speaks up and you are in a hurry I would look at one of the parts websites and check to see what the shipping weight is for left plus right bedsides and floor.. (and front panel and tubs) for example Classictrucks or LMC or Brothers or The Truck Shop.. one of those should show the weights - maybe you have to add everything to a shopping cart to see the total shipping weight.
Old 04-27-2017, 11:32 PM   #40
71CHEVYSHORTBED402
Probably the minimum weight off the floor. Add BBC, A/C, step bumper, couple tanks, etc. etc.....4500 might be a reasonable average.
Tony
Old 06-23-2017, 10:31 AM   #41
Coley
Coley's Avatar
Smile Re: How much does it weigh?
...just back from dropping off a load full of scrap/rotted wood at the dump (careully packed of course...lol)....so I have another truck weight reference for those interested:
The weight of my truck via the weigh scale there was 4180 lbs. (without people/passengers- truck only)
The truck is equipped as follows:
'72, C10, 1/2 ton
8' long bed w/ trailing arm suspension (not leafs)
Relatively complete option group (ps / pb / a/c, radio, gauges, deluxe trim, etc)
350 / auto / h.duty rad / chrome rear bumper w/ hidden tow hitch.
std. tires (235-15") (w/ full spare tire on board)
Fuel load: less than 1/2
....so for sure, easily north of 2 tons..and that is an empty 1/2 ton.
All good
Coley
2000 Dodge Ram 1500
Old 06-23-2017, 11:13 AM   #42
davepl
davepl's Avatar
Originally Posted by 70chevytruck View Post
Gross weight on my 70 Longhorn is about 4600 lbs. Its on the door tag.
That's gross... my 70 Longhorn scales around 4250 I think. That's what my lift says, and while it says "+/- 2%" I don't know if it's really within 2 percent or not...
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-01-2017, 09:23 PM   #43
Dieselwrencher
6>8 Plugless........
Dieselwrencher's Avatar
My 72 Longhorn is 6450 with about 8 gallons of fuel before my aftermarket bumpers. That is with 3/4 boxed frame, all 1/4" wall cross members, a Cummins, and D60/D80 axles. I figured it would be higher than that when I was building it.
Ryan
1969 Chevy milk truck
Old 08-01-2017, 09:40 PM   #44
pritch
pritch's Avatar
My '68 C-10 seems to weigh more at the gravel pit than it does at the County dump. I think someone's got their thumb on the scales...
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 08-01-2017, 11:45 PM   #45
Coley
Coley's Avatar
I would recheck that number Dave...that definitely doesn't sound right.
If you get a chance take it over a community scale or thereabouts...I think you are going to pick up 500 lbs in a hurry for a 3/4 ton Longhorn.
all good
Coley
2000 Dodge Ram 1500
Old 08-02-2017, 11:38 AM   #46
68GRNK20
68GRNK20's Avatar
interesting thread, I am always interested in the weight of a vehicle and how it effects performance and fuel economy. I still havn't driven my truck yet and was wondering how it would do with the 350 that is in it. looks like about 5000 lbs for a K20 probably be not too bad.
68GRNK20 is offline   Reply With Quote
Old 07-10-2021, 02:04 PM   #47
HO455
HO455's Avatar
Here is a thread with some more information.
http://67-72chevytrucks.com/vboard/s...=598378&page=1
RIP Bob Parks.
Old 07-10-2021, 11:22 PM   #48
wesmigletz
wesmigletz's Avatar
Originally Posted by 67chevy1series View Post
so how much should a small block 67 1/2 ton swb fleetside wood floor truck weigh?
I weighed my 67 SWB when I got out of the Army in 2013 - had to weigh it empty and loaded for my self move. 283/manual brakes, no AC, no pS, buddy buckets: 3660 pounds with a 1/2 tank of gas.
1970 2WD K5
1968 Camaro Conv
1967 Chevy SWB
1964 Malibu SS
1957 Corvette
Pics
www.picturetrail.com/wesmigletz
wesmigletz is offline   Reply With Quote
