Old 06-16-2013, 09:10 PM   #51
boynton
boynton's Avatar
Re: 1970 Burn Victim
my fiance took some engagement pictures with the truck...my fiance has named the truck Roxy. The photographer did great with the truck!
boynton is offline   Reply With Quote
Old 06-17-2013, 02:28 AM   #52
boynton
boynton's Avatar
Ok figured out the pictures are too large to post when I figure out how to shrink them I will post them
Old 07-28-2013, 03:02 AM   #53
boynton
boynton's Avatar
Ok finally figured out this re-sizing thing...
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
Old 07-28-2013, 03:03 AM   #54
boynton
boynton's Avatar
two more
1970 SWB Step-Side
Old 07-28-2013, 01:06 PM   #55
rgunlock
rgunlock's Avatar
Nice pictures! See you in a couple weeks.
Rick
78 GMC K15 SWB, 350/NV4500/NP205/4.10s Project Hazel
71 GMC C25 350/TH400 - Project Angie
59 Chevy SWB Stepside (next in line? Not sure now )
2001 GMC Sierra K2500
rgunlock is offline   Reply With Quote
Old 07-28-2013, 02:31 PM   #56
boynton
boynton's Avatar
Yup!
1970 SWB Step-Side
Old 12-04-2013, 01:26 AM   #57
boynton
boynton's Avatar
OK I am looking at installing a sway bar-which I already have. I installed one on my other '70 and really like it. This truck sits a little lower, does anyone have any suggestions on the frame brackets to suck it closer? I have power steering, so I can't bolt it directly to the frame. I use the ECE brackets on my last install just curious what else is out there.
1970 SWB Step-Side
Old 12-04-2013, 12:15 PM   #58
mcbassin
Still Learning
mcbassin's Avatar
Dang! I love this truck! One of the nicest steppers I've seen on here. I go right through your town on my annual pilgrimage to Zapata. Thanks for sharing all the pictures.
Old 03-18-2014, 10:14 PM   #59
boynton
boynton's Avatar
Thank you so much. If you are ever in the area hit me up! I am right off the highway in Salado.
I got some new wheels and tires a few days ago. I am trying to keep up with this truck while building another 6.0 '70. I went with a bigger tire in the back so that the front will have enough room to turn and the back will have enough meat to hook...sorta
1970 SWB Step-Side
Old 03-18-2014, 10:15 PM   #60
boynton
boynton's Avatar
rear tire size
1970 SWB Step-Side
Old 03-18-2014, 10:18 PM   #61
boynton
boynton's Avatar
the wheels and tires from this truck are going to the 6.0 build...until I melt them away
1970 SWB Step-Side
Old 03-18-2014, 10:40 PM   #62
mcbassin
Still Learning
mcbassin's Avatar
Very nice new tires and wheels.
Old 03-18-2014, 11:03 PM   #63
boynton
boynton's Avatar
Thank you so much. I was a bit nervous, but I think they turned out well.
1970 SWB Step-Side
Old 03-19-2014, 10:06 AM   #64
Katrina/10
Katrina/10's Avatar
Nice choice on the wheels and tires.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-19-2014, 10:23 AM   #65
Low Elco
Looks good, I like me some old school chrome.
Low Elco is offline   Reply With Quote
Old 03-19-2014, 10:50 AM   #66
rgunlock
rgunlock's Avatar
The old wheels were sharp, but these look a lot more correct. Looks great (and shiney)!
Rick
Old 03-19-2014, 12:10 PM   #67
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Perfect!
Tom Vogel is offline   Reply With Quote
Old 08-05-2014, 09:53 PM   #68
boynton
boynton's Avatar
Well it was time for some maintenance this week. My speedo has not been working for a while so I decided to track down the problem. I found out the speedo gear on the tailshaft had come loose and stripped the inner ring out so it no longer stays in place. I dropped the drive shaft and removed the trans tail shaft cover and then removed the gear located on the tail shaft. It was completely out of place amd no longer making contact with the speedo gear that attaches to the speedo cable...time to order a new gear. It is currently torn down in my garage...bummer.
While I was under my truck I noticed the exaughst was loose so tighter it up at well...then snap I broke a bolt...wonderful. I then pulled the manifold off and realized that a second bolt was bent so I replaced both of them. It was also time for some new exaughst manifold gaskets so I bought a set. Now time for everything to go back together...
1970 SWB Step-Side
Old 08-05-2014, 10:03 PM   #69
rgunlock
rgunlock's Avatar
It's always something. Jared and I just spent 4-5 hours this weekend replacing his catalytic converter that should have been take out 4 bolts, replace converter and bolt back up. You can probably guess why 4 bolts on exhaust took so long
Rick
Old 08-06-2014, 12:35 AM   #70
boynton
boynton's Avatar
You didn’t pull out the reciprocating saw or torch out soon enough.
1970 SWB Step-Side
Old 08-06-2014, 12:55 AM   #71
gdavis
gdavis's Avatar
It's good to see someone save a old truck like that. You want be sorry for it. Take care George
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 08-06-2014, 08:08 AM   #72
mcbassin
Still Learning
mcbassin's Avatar
You have to love routine maintenance. Especially when it throws a curve ball. Looks like you got it under control. Sure love this red truck! Keep on trucking.
Old 02-15-2015, 05:51 PM   #73
boynton
boynton's Avatar
I got the truck all cleaned up yesterday for Valentine's Day. Its been a while since it was this clean!
1970 SWB Step-Side
Old 02-15-2015, 10:01 PM   #74
rgunlock
rgunlock's Avatar
Man that's Purdy!
Rick
Old 07-05-2016, 12:42 AM   #75
boynton
boynton's Avatar
'merica
Happy 4th everyone.
1970 SWB Step-Side
