View Poll Results: If you had the option, which of these grills would you use? | |||
Original 66 painted grill | 1 | 20.00% | |
64-66 C60 painted grill | 2 | 40.00% | |
an original aluminum grill that needs to be restored | 2 | 40.00% | |
the repo aluminum grill that is now available | 0 | 0% | |
Voters: 5. You may not vote on this poll |
07-04-2013, 08:41 AM | #226 |
I'm just glad to be here!
Re: pdx-sanity66
It takes a bit to get the texture to look the way you want. I ended up holding the gun about 12" away and used a fairly quick movement side to side to get the texture I wanted. I had a spot where I laid it on really thick and it looked OK but different from the rest of the area. It was not hard to use at all. I plan on doing the inside of the bed with it too.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
07-04-2013, 03:36 PM | #227 |
Re: pdx-sanity66
Ok buddy, you totally inspired me to change up my compressor game too.
However, I had a heck of a deal fall into my lap. I am going to install my new set up today, and post some pics !! Happy 4th down there, hope you get a chance to enjoy it !
Michael McMurphy My 66 Stepside My 64 Tow Truck My 66 Tempest Table Of Contents Added to Page1 |
07-12-2013, 11:20 PM | #228 | |
Re: pdx-sanity66
I'm getting ready to order the undercoating for the cab bottom so I decided to get the inside roof stripped and epoxy primed while it's in a convenient location. None of that upside down sanding for me. I didn't quite get done today so I'll finish up tomorrow. Here's how it looks now.
Sanity'66 http://67-72chevytrucks.com/vboard/s...d.php?t=515110 Long bed, Fleetside, Small back window I've Done So Much, With So Little, For So Long, That Now I Can Do Anything With Nothing. |
07-14-2013, 06:39 PM | #229 |
Re: pdx-sanity66
I finished the epoxy on the roof.
07-14-2013, 06:41 PM | #230 |
Re: pdx-sanity66
Looks good
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
07-14-2013, 07:27 PM | #231 |
Re: pdx-sanity66
Nice job Brett.
Are you going back with that original color? |
07-14-2013, 08:54 PM | #232 |
Re: pdx-sanity66
Thanks, man.
Thanks. No, I'm going with a silver. Something resembling an aluminum look. I haven't found the exact color but I know in my head what it will look like. Along with a dark dash, black carpet, and some well placed trim colors. I haven't decided on the seats, yet. Probably either black or a match to the dash.
07-20-2013, 05:08 AM | #233 |
Re: pdx-sanity66
I was able to get a little more done on Sanity the last couple of days. I got the blaster out again and cleaned up around the windshield frame and the tops of the door frames. You know, more of that upside down stuff when the cab goes back upright.
Everything cleaned up nice. Now it's time to smooth the seams on the door frames and the front door pillar to roof section. I used some steel rod and a small piece of sheet metal on the largest gap. Pictures will be coming when possible.
08-04-2013, 11:19 PM | #234 |
Re: pdx-sanity66
I got the seams all filled on the upper door frame and the roof to pillar area. Still no pictures. I have taken quite a few but I just don't want to go through the hassle it takes to post them now. Too bad things had to be "fixed" and it made things worse. The reason I started this build thread was to keep motivated while I work on my truck and hopefully share what I learn with others. I may just become a little antisocial and start lurking instead of posting for a while till things work themselves out. I'm too old to put up with the hassle. There are better things to put my efforts in to.
08-04-2013, 11:47 PM | #235 |
Re: pdx-sanity66
Sounds like your making tons of progress on the cab.
I use Photobucket but have been told that I will regret it some day. Others re-size their pics in paint to upload on the forum. Good luck on the pic thing. Hope to get a look at your truck progress.,.,,,,sounds like your making lots of progress |
08-11-2013, 04:39 AM | #236 |
Re: pdx-sanity66
Testing out the picture posts. Looks okay so here goes. As I mentioned earlier I got this crazy idea that I needed to fill the seams in the door pillars and roof pillars so here goes. These are some pics of what I'm talking about
08-11-2013, 04:50 AM | #237 |
Re: pdx-sanity66
Some of the patches for the gaps.
08-11-2013, 04:58 AM | #238 |
Re: pdx-sanity66
welds cleaned up and ready for primer and a little filler.
08-11-2013, 12:25 PM | #239 |
Re: pdx-sanity66
Seams look great.
Its those nice finishing touches that makes a nice quality build all that much better. Nice Job |
08-11-2013, 12:52 PM | #240 |
Re: pdx-sanity66
Looks like you are still tinkering along. As always can't wait to see more.
08-11-2013, 08:39 PM | #241 | |
Re: pdx-sanity66
Thanks for looking in. Now that I've got the picture thing working for me I'll hopefully have more stuff soon.
08-11-2013, 11:20 PM | #242 |
Re: pdx-sanity66
Love the attention to detail, keep rockin!!!
DON Proverbs 27:17 US Air Force Retarded errr Retired My '65 Stepper Build:http://67-72chevytrucks.com/vboard/s...d.php?t=533920 My '60 Rusty Patina Build:http://67-72chevytrucks.com/vboard/s...66#post7402266 My '72 http://67-72chevytrucks.com/vboard/s...59#post7204359 SOLD |
08-31-2013, 02:51 AM | #243 |
Re: pdx-sanity66
I finally got back to Sanity after a camping weekend off. I got the Raptor Liner sprayed on the bottom of the cab. I have also been working on the seams a little more and sprayed another coat of epoxy on them. They are now ready for a small skim coat of filler.
08-31-2013, 03:10 AM | #244 |
Re: pdx-sanity66
man thats cool. and you're right. we seem to be on the same track as far as build timing goes... erie, maybe but kinda fun too. i really do wish i had taken the time to fill the seams, that is cool and cleans up an area that i never could figure why the factory didn't take care of...
08-31-2013, 03:31 AM | #245 |
Re: pdx-sanity66
Thanks, man. I had planned on filling the seams on the rockers from the beginning but to be honest I never really thought about the upper pillar and roof seam until I got the cab on its back. After staring at them for a couple of weeks they had to go.
09-10-2013, 02:40 AM | #246 |
Re: pdx-sanity66
Not to much to report. At least nothing worth posting pics of right now. I've been working on smoothing up the seams I welded. A little filler, primer, etc,etc. You all know the routine.
I have been trying to find another seat bottom from a custom option seat so I can continue with my bucket seat project. I thought I had one but when I went to see it, it had broken springs on the driver's side which always seems to be the case. Still on the lookout for one. If anybody locally has one they're willing to part with for a decent price, please let me know. I won't be working on Sanity for a couple of weeks as I'm on vacation as of Wednesday. We're heading down to American Fork, Utah to visit my mom and siblings.
09-10-2013, 08:48 PM | #247 |
Re: pdx-sanity66
progress is looking good, I like how you filled the seams, I will be doing the same on mine along will the gap on the a pillar on the inside! I have already filled the seam for the big back window and want a smoother look!! keep it up, it looks great!! have a great vacation, we will all be here when you get back to sanity!!
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
09-10-2013, 08:57 PM | #248 | |
But Found Her 25yrs Later!
Re: pdx-sanity66
09-24-2013, 12:21 AM | #249 |
Re: pdx-sanity66
I got back from vacation on Saturday and back to work Sunday for 3 days of 12 hr. shifts. I hope to get back to Sanity on Wednesday but I wanted to share a couple of pics I dug out while visiting my 84 yr. old mother. One is my high school ride, a 55 chev 210, and the other is the truck my dad had when I was a kid. Went on many camping trips in this rig. This is where my love of these trucks started.
09-24-2013, 07:08 AM | #250 |
Re: pdx-sanity66
Awesome Pics...
