![]() Join Date: Jul 2013
Rack and Pinion 65 panel
Thinking of putting a Crown Victoria aluminum Rack and pinion suspension on my 65 panel. Has anyone out there down anything like this. It appears that I will just have to do a little welding and modifying steering column. I understand they are a great unit to Airride. Any wisdom to stop or proceed with my insanity. I am also getting the rear end to go with it. Putting discs all the way around.
67-72 parts collector,…
![]() Join Date: Nov 2002
Re: Rack and Pinion 65 panel
The worse part about these old trucks is the crossmember.
It hangs too low when lowered, and worse when you air ride the front. I would spend your money on a Dropmember to increase the ground clearance. There are three versions that give you 1", 2', or 3" additional ground clearance. All use a rack and pinion steering. They center the wheels in the wheelwell. And they correct ALL the issues associated with the stock GM front end.
The Thunderbird rack fits the C10 chassis, but requires welding, and bit of figuring.
If your good with a welder or have a friend who is. You can section your cross member 1.5 inches or possibly more with a rack and pinion. You can also Z your frame, and move the cross member forward the inch to center the wheels. Then while at it you can move you lower a arm forward 1 inch in comparison to the upper for much better handling. If you look around you can rebuild every thing along the way, and be alot cheaper then a drop member. It just won't look as cool, but if you have a front end not many will see it anyways. |
Personally I'd go with a dropmember myself. It keeps the guessing game and math to a minimum.
I used the 79-93 mustang rack and pinion on mine. Then you either buy 2 steering u-links or get em off of an Astro van. Posted via Mobile Device |
#5 | |
I think you should go for it. I've seen that same front end used on a number of older vehicles that had terrible stock suspension. Everything from trucks to older hot rods. They're cheap too if you look around. Keep use updated if you go that route.
Yea thanks, that's my plan. Picked up the front and rear end today. Will start pulling old stuff off this week and get to mocking up new gear. Will continue to post picks on the mod. Will be mounting a built 350 once things are ready. This front end gives me the versatility to mount the motor as far back or forward as needed.
