Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Old 05-26-2013, 01:36 AM   #76
Captainfab
60-66 Nut
Re: Power Brake Booster Adapter Bracket
Looks good
What diameter booster is that? It looks to be about 7"
Old 05-26-2013, 05:35 PM   #77
gonnuts
gonnuts's Avatar
It's about 8"
67 Chev SWB, 400 SB .040 over, vortec heads, comp XE268 cam, performer EPS intake, edel. 650 AVS carb, 700R4
gonnuts is offline   Reply With Quote
Old 06-09-2013, 06:23 PM   #78
CTENTA1
Registered 1971 K5
Originally Posted by gonnuts View Post
It's about 8"
Gonnuts-
Im thinking about buying this bracket myself. I want to use the 8" booster also. Your setup looks great! Did you have to mess with the steering column at all as previous members claim they have had trouble installing the bracket? Or maybe the previous members are using a bigger booster causing the problem with the linkage to steering column. Your feedback would be greatly appreciated as im just waiting on some solid answers to order the bracket.
Thanks.
CTENTA1 is offline   Reply With Quote
Old 06-09-2013, 08:45 PM   #79
gonnuts
gonnuts's Avatar
I have my column pushed in about 1 3/4" or so I believe(not sure I'd have to measure), and I have lots of room. I didn't do that to make the booster fit though, I did that when I put the column in for comfort. I turned the bolt around on shifter before I put the bracket because I thought I would need the space, but I don't think that was necessary and I plan on turning it back around.
Old 06-09-2013, 11:22 PM   #80
Captainfab
60-66 Nut
The guys that had the interference issue with the column shifter hitting the booster were using a typical 10-11" diameter OEM booster.
Old 08-20-2013, 09:39 PM   #81
luke6667
Does anyone know what Booster Gonnuts used? That setup looks pretty sweet and i would like it on my 1966.
Also I need a PM for the bracket please, might as well make it black powder coated too!
luke6667 is offline   Reply With Quote
Old 08-21-2013, 12:36 AM   #82
Captainfab
60-66 Nut
That booster is just one of the universal aftermarket boosters. You'll have to elongate the holes in my booster bracket slightly to bolt one of those to it.
I'll send you a PM with ordering info.
Old 08-21-2013, 11:14 PM   #83
gonnuts
gonnuts's Avatar
Mine bolted right up, just had to fab a rod connector.
Old 08-27-2013, 09:05 PM   #84
luke6667
Do you happen to recall what booster and where you purchased it from? I want one the will bolt right up.
Also, Great item Captain Fab it looks very nice.
Old 08-27-2013, 10:03 PM   #85
oldies1938
Thumbs up Re: Power Brake Booster Adapter Bracket
Thanks i got my bracket on Monday!! Mounted it today had to make the holes a little bit bigger....i think that was because i was using a universal brake booster.....looks great!!!! Thanks again!!!!
oldies1938 is offline   Reply With Quote
Old 08-28-2013, 12:51 AM   #86
Captainfab
60-66 Nut
That looks good
That is correct in regards to elongating the holes for the booster. My booster brackets are designed to use factory boosters with the 3-3/8" x 3-1/2" stud pattern, not the aftermarket boosters with the 3-1/2" x 3-1/2" stud pattern. So the amount to elongate the holes is only 1/16" each.
Would you mind if I copied your pics and posted them in the '63-'66 booster bracket for sale thread?
Old 08-28-2013, 01:57 PM   #87
oldies1938
Yes you can!! thanks again!!!
Old 08-29-2013, 12:06 AM   #88
Captainfab
60-66 Nut
Old 09-10-2013, 02:30 PM   #89
gmhardwick66
if you can...please look at my set up on my brakes. it is 1968 with front disc brake conversion on it when I bought truck so I am in the dark about specifics. I am wondering if the bracket that you offer would work for me and what would I gain if used it other than giving me a more cleaner more spacious look under hood. thank a lot. your product looks great.
gmhardwick66 is offline   Reply With Quote
Old 09-10-2013, 02:32 PM   #90
gmhardwick66
if I used your bracket what would I have to change other than the push rod length? and whats the proper measuring technuiq for this?
Old 09-11-2013, 12:02 AM   #91
Captainfab
60-66 Nut
Since you already have power brakes, all you will gain is looks and room. When lengthening the booster pushrod, it just needs to be done in such a way so that it is long enough, and still has adjustment available. There are a few different ways to go about it.
Here are a couple ways:
http://www.67-72chevytrucks.com/vboa...&postcount=324
http://www.67-72chevytrucks.com/vboa...d.php?t=564518
Old 10-07-2013, 11:18 AM   #92
Rochlow
Pm sent.
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 10-08-2013, 12:34 AM   #93
Captainfab
60-66 Nut
I replied to your PM
Originally Posted by Rochlow View Post
Pm sent.
Old 12-05-2013, 10:39 PM   #94
Bowtie468
Bowtie468's Avatar
PM sent
Chris
click here to see my buildpage
http://67-72chevytrucks.com/vboard/s...d.php?t=394656
1979 C10 Silverado Big10 SWB
Factory 454/400
Cardinal Red/Santa Fe Tan (original paint)
1968 C10 SWB Fleetside (Sold)
468BBC MultiPort TPI / Dynamic EFI P4
Black/Black
1963 Nova SS convertible (Sold)
194 I6/ PowerGlide
Bowtie468 is offline   Reply With Quote
Old 12-06-2013, 12:53 AM   #95
Captainfab
60-66 Nut
Reply sent
Originally Posted by Bowtie468 View Post
PM sent
Old 12-06-2013, 09:51 PM   #96
Bowtie468
Bowtie468's Avatar
PayPal sent. ! Thx
Chris
Factory 454/400
Black/Black
194 I6/ PowerGlide
Old 12-07-2013, 12:26 AM   #97
Captainfab
60-66 Nut
Your booster bracket shipped out today Chris. You should receive it by Wednesday.
PayPal sent. ! Thx
Old 12-07-2013, 01:33 PM   #98
gmhardwick66
do you offer any rear disc brake conversion bracket kits? or any tips on a conversion using found parts from typical salvage yard vehicles?
Old 12-08-2013, 12:54 AM   #99
Captainfab
60-66 Nut
Yes I have 5 rear disc brake bracket sets. There are links to the for sale threads for the 3 five lug bracket sets in my signature line. If you need 6 lug, let me know and I'll send you the links to those.
Old 01-07-2014, 05:27 PM   #100
Clrussell
Clrussell's Avatar
Sent ya a pm
61 apache
Clrussell is offline   Reply With Quote
