Old 07-08-2013, 12:30 AM   #76
78bronzechariot
78bronzechariot's Avatar
Re: 1968 GMC "Camillian"
I also sandblasted and painted the frame.
78bronzechariot is offline   Reply With Quote
Old 07-21-2013, 11:48 PM   #77
78bronzechariot
I started on the SS Camaro hood modification. In keeping with the theme of what a '68 SS pickup might have looked like, I am grafting the center velocity stack "ice cube trays" from a '68 Camaro SS hood into the truck hood. It seemed best to install the whole center section including the pointed peak to give the hood a more aggressive look. Unfortunately the '67 Chevy hood I have wasn't in the best shape. It appeared that a flex fan had decided to come apart and put a whole bunch of outward dents in the hood. The good thing was this made the hood a prime candidate for modifiaction, the bad news was I could not get all those dents out without a major oil can problem, so I replaced a section out of the drivers side of the hood while I installed the center of the Camaro hood. Pics show the process, I still have quite a bit of welding to do next weekend.
Old 07-22-2013, 12:23 AM   #78
Hardesty454
Hardesty454's Avatar
That is awesome!
Rob
1971 c10 - ground up in progress
Tripp's Speed Shop Build -
http://67-72chevytrucks.com/vboard/s...d.php?t=589750
Hardesty454 is offline   Reply With Quote
Old 07-22-2013, 12:34 AM   #79
78bronzechariot
Originally Posted by Hardesty454 View Post
That is awesome!
Thanks!
Old 07-22-2013, 07:23 AM   #80
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Looks good ,I like that you are going with a 68 camaro theme...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
FRENCHBLUE72 is offline   Reply With Quote
Old 07-22-2013, 07:38 AM   #81
78bronzechariot
Thanks!
Old 07-22-2013, 02:04 PM   #82
71' Custom
71' Custom's Avatar
Subscribed!
..........___
..____//_{)] ______
[_(O)_[___][__(O)_]
Project: Under Pressure II
http://www.67-72chevytrucks.com/vboa...d.php?t=559720
71' Custom is offline   Reply With Quote
Old 07-22-2013, 05:08 PM   #83
Rusbuilt
Rusbuilt's Avatar
Looking good! Keep it up!
Rusbuilt is offline   Reply With Quote
Old 07-22-2013, 11:51 PM   #84
78bronzechariot
Originally Posted by 71' Custom View Post
Subscribed!
Glad you guys like it, thanks for the compliments!
Old 07-23-2013, 11:45 AM   #85
mjensen
mjensen's Avatar
That is looking pretty killer. I'm in.
Mike
'69 GMC 3/4 ton 4x4 Build Thread
mjensen is offline   Reply With Quote
Old 07-24-2013, 12:20 AM   #86
78bronzechariot
Thanks for following along!
Old 08-25-2013, 11:24 PM   #87
78bronzechariot
Final got some updates on here. It would have been sooner if the website allowed mobile uploads. Anyway I filled in the original blower hole as well as fixing poor repairs in the upper fender mount. After that was done, I started body working the closeout panels and the roof of the cab. I also re hung the passenger door to verify fit after the rock replacement and to bodywork the cab corners to match any slight variation between it and the door. Lastly I modified an original power brake booster bracket to fit a '92 astro van hydroboost I had bought at a junk yard. The bot pattern is the same as the stock vacuum booster, but the rod is just over 1 inch longer. In the effort to not make custom parts for "wear" items I thought it best to make the bracket longer so that if I need to replace the booster, it would be a simple parts swap instead of having to modify a new one. It isn't the prettiest way to do it, but the most effective for a truck I intend to drive a lot.
Old 08-25-2013, 11:35 PM   #88
78bronzechariot
Old 09-03-2013, 09:46 PM   #89
78bronzechariot
Sprayed polyester on the roof and final blocked it out, and started matching the door to the cab corner. Not exciting, but it has to be done.
Old 09-16-2013, 12:44 AM   #90
78bronzechariot
I got quite a bit done over the last couple of weekends. I finished body working and painting the firewall, I sandblasted painted and under later the bottom of the bed, I finished rust repair in he drivers door, hung the doors and fenders, filled the drivers fender marker light and started body working the drivers door and fender.
Old 09-16-2013, 07:51 AM   #91
Rusbuilt
Rusbuilt's Avatar
Looking good sir!
Old 09-16-2013, 08:31 AM   #92
78bronzechariot
Looking good sir!
Thanks!
Old 09-16-2013, 09:10 PM   #93
duallyjams
duallyjams's Avatar
Wow you have been busy, you got a lot done.
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 09-16-2013, 09:28 PM   #94
El Campo
El Campo's Avatar
Subscribed!
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 09-16-2013, 11:28 PM   #95
78bronzechariot
Originally Posted by El Campo View Post
Subscribed!
Thanks! Glad you guys like it!
Old 12-29-2013, 11:05 AM   #96
78bronzechariot
I haven't been able to work on the truck for a while again because of the SEMA deadline on a car at work, then playing catch up on the other cars at work that we put on hold for the SEMA car. I did manage to get an afternoon in on Christmas Eve to do some more work on the tailgate. Sprayed polyester primer on it and have it about ready for urethane primer then paint.
Old 04-06-2014, 09:07 PM   #97
78bronzechariot
Extra long overdue update, its a little frustrating that my iphone or the site wont allow mobile uploads, so I finally had some time to copy the pictures from my phone and get some on here. There has been a bunch more bodywork and sanding, which doesn't always look like a lot in pictures. I also installed roll pans on either end, and went about making the '68 Camaro bumpers fit, I ended up using two back bumpers and one front bumper to make them wide enough to fit the truck. I also set the bed on momentarily so I could get a feel for what everything is going to look like. After I was satisfied with the rear roll pan and bumper, I pulled the bed and sprayed the final coat of primer before paint.I will leave the rest to pictures...maybe more than one post of pictures to get caught up.
Old 04-06-2014, 09:14 PM   #98
78bronzechariot
More catch up pics
Old 04-06-2014, 09:40 PM   #99
Rusbuilt
Rusbuilt's Avatar
Wow! Its looking great!
Old 04-07-2014, 09:32 AM   #100
frmula505
frmula505's Avatar
Coming out great, that bed really came out nice.
1961 GMC Suburban Custom
1969 Short wide project http://67-72chevytrucks.com/vboard/s...d.php?t=535479 (SOLD)
1959 Apache fleetside (frame off in progress) http://67-72chevytrucks.com/vboard/s...d.php?t=348746
1960 Apache short/narrow shop truck http://67-72chevytrucks.com/vboard/s...d.php?t=350780 (SOLD)
1951 Plymouth leadsled project
2005 Corvette conv. Procharged
1969 Corvette stingray
2006 Cadillac XLR-V
1950 Oldsmobile 98 custom project
frmula505 is offline   Reply With Quote
