Old 09-12-2013, 09:39 PM   #1
Joesjunk
Joesjunk's Avatar
Turbo 400/205: Trans pumping fluid into the transfer case???
I have an '86 1 ton with a 400 turbo/205 transfer case. The trans in pushing fluid into the transfercase. Im going to pull the T/C but what seal needs to be replaced? Thanks
72 3/4t Custom Deluxe 402/auto 66k Original paint
71 3/4t 4x4 Custom Deluxe 10k original miles Original paint
71 3/4t Cheyenne 402 70k original paint
72 3/4t 4x4 Custom deluxe
72 3/4t 4x4 Custom deluxe 91k original paint
72 Cheyenne/30 Dually
69 Camaro SS396 4-speed
13 GMC 2500HD Duramax I bought new
05 Jeep Wrangler "Willys Edition" 12k miles (I bought new)
85 3/4 ton 4x4 Scottsdale 33k miles original paint
86 1 ton 4x4 SRW Silverado 454 restored
80 1 ton 4x4 SRW Silverado 9,434 original miles!! original paint
95 GMC 1 ton dually 4x4 my dad bought new
95 GMC 3/4 ton 4x4, regular cab 454, 31k original miles
2002 2500HD 4x4 regular cab 6.0L 67k miles
2002 2500HD 4x4 regular cab 8.1L 28k miles
2003 GMC 2500HD 4x4 regular cab Diesel 93k miles
67-72 Parts for sale
Joesjunk is offline   Reply With Quote
Old 09-13-2013, 10:30 AM   #2
turp mcspray
turp mcspray's Avatar
Re: Turbo 400/205: Trans pumping fluid into the transfer case???
There are 2 seals in the adapter. They look look like trans tailshaft seals. There is also an o ring seal, that goes on the shaft, and seals against the inside of the collar that connects the trans and transfer shafts. I think a complete transfer case seal kit is like $25.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
Old 09-16-2013, 09:18 PM   #3
Joesjunk
Joesjunk's Avatar
Any suggestions on a good place to order a seal kit?
Old 09-17-2013, 08:18 AM   #4
BLAZERMAN
Currently Blazerless
BLAZERMAN's Avatar
Quad4x4.com should have the seals you need.
1972 C/30 133" W.B. C&C
1970 GMC 3500 157" W.B. single wheel C&C
BLAZERMAN is offline   Reply With Quote
Old 09-17-2013, 09:40 AM   #5
Joesjunk
Joesjunk's Avatar
Thanks Rob
