Brake Pedal - help please
The brake pedal on my 71 only has a few inches of travel and has a solid bottoming out feel. It is still several inches from the floor at this point and the stopping power is ok but not great. I don't see anything binding in the linkage and I haven't disconnected the pedal yet to see if it's the master cylinder or pedal causing the problem, just thought I'd check here first to see if anyone else has had this problem.
Another 71 My truck In tank fuel pump how to LS factory gauges wiring how to-post 18 |
20' Daredevil (Ret)
![]() Join Date: May 2003
Re: Brake Pedal - help please
Pedal travel sounds good -- the last thing you want is the pedal going to the floor. Maybe the power booster has failed, or is not getting enough vacuum?
- Mike - 1972 K20 LWB 350/350/205 RIP El Jay |
TchncnDen, what did you come up with?
I'm having the same issue.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! ![]() 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! ![]() |
I had something similar. Turned out to be a couple bad wheel cylinders AND a bad master cylinder. You can get a brand new master cylinder from Oreillys for like $17. I'd start there, and also pull the wheels off to see if you have any leaking cylinders before you bleed for nothing. Or, do the reverse and pull the wheels first and check for leaks
Posted via Mobile Device |
