Front cab mounts
Do they make the front cab mounts for the frame ?
Posted via Mobile Device |
Re: Front cab mounts
The cab has four mounting points: each receives 2 rubber bushings. You can use polyurethane ones if you like to feel every bump in the road.
Are asking about the rubber cushions or the metal frame bracket that holds the cushion?
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Lee H,
That's a good question, sorry I missed it! We definately need more info here to give accurate advice. |
Frame brackets
Hi, saw this question just before heading out the door...so the short and quick answer is, yes,the frame mount brackets are available.. I bought a pair for my truck as they were quite rusted.I found them on Brothers website..part # FM72CMR 67-72 cab support frame mount - rear. Hope this helps you.
_____________________________________________ 69 C-20 292, 4 spd O/D, 4:56 rears. No a/c p/s p/b p/w......restoration project,"Operation:Stovebolt" 78 C-10 305 TH350 new (old) daily driver 02 Suburban Z71 a.k.a. the family truckster 99 Silverado 1500 Z71 |
It does thank you very much
Just getting back.....good answer.
