09-21-2013, 10:42 PM | #1 |
What is the solution to keeping the bolts tight at the Collector?
Mine are comming loose every time I drive it and I have been tightening the **** out of them!!!
09-21-2013, 11:00 PM | #2 |
Re: What is the solution to keeping the bolts tight at the Collector?
Remove headers, and install ramshorn manifolds, problem solved.
1972 Chevrolet Cheyenne LB 1/2 ton finished restoration/rebuild 1995 350 throttle body FI, 4L6E (running on modified GM wiring harness) 3.08 posi rearend, factory A/C on 134A, p/s, p/b, late 70's power windows and locks and cruise, speakers in the dash + 6x9's behind the seat, factory tilt, 40 gallon fuel tank in the bed with integrated tool box, air assist bags on the rearend, sway bar up front and much more. 1972 chevrolet SNB finished 2002, 350 TB FI, TH400, factory A/C, p/b, p/s, (FOR SALE) 1969 Chevrolet 1 ton in work, home made PTO dump bed extended frame, 350 CI , 1972 Chevrolet 3/4 ton suburban future project 1972 Chevrolet 3/4 ton p/u maybe a project one day 1966 Toyota Landcruiser my playtoy |
09-21-2013, 11:08 PM | #3 |
Make sure the rest of the exhaust has lots of flex in it. Can't be too tight or collectors loosen due to engine movement.
09-21-2013, 11:19 PM | #4 |
Cone style locknuts.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
09-21-2013, 11:23 PM | #5 |
Use pinch nuts instead of regular hex nuts.
Like these, http://www.sandersonheaders.com/Sand...e-5-set-6.html |
09-22-2013, 12:31 AM | #6 |
I put two nuts on each bolt.
I'm not as good as I once was, But I'm as good once as I ever was. |
09-22-2013, 02:32 AM | #7 |
I have had decent luck with loc tite but the pinch nuts would be best.
Posted via Mobile Device |
09-22-2013, 08:13 AM | #8 |
have a routine maintenance list// check fluids grease front end check header bolts etcetc do it with your oil change and the problem is solved
09-22-2013, 08:27 AM | #9 |
I used Percy's soft aluminum gaskets on the headers and collectors. 1" header bolts grab more threads and new bolts on the collectors that came with the gaskets with lock washers seem to be holding well. I have full exhaust all the way out the back.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller 72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350 |
09-22-2013, 09:55 AM | #10 |
I like to use old rocker arm pivot balls as washers on collector flanges.Helps spread the load
72 Cheyenne Super LWB 350/350 Factory A/C Tilt/Posi White/Med Red/White(on the way) 72 Custom Deluxe Burb(Arizona truck)Nice interior Great patina Project Patina Azul http://67-72chevytrucks.com/vboard/s...d.php?t=467668 |
09-22-2013, 04:17 PM | #11 |
CAN'T FIX NOTHIN
I am gonna assume you are using headers and flanges with gaskets ? that's why they wont stay tight I fought with them for years , SUMMIT has a product they are called HEADER BUDDIES they are made so that you DONT USE A GASKET ! you can install them tighten them and FORGET THEM !
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
