Old 02-08-2013, 02:53 AM   #201
shenk10
shenk10's Avatar
No I didn't have any problem in the front. I did have a problem in the back though. They didn't rub but then I dropped the rear to paint it and put it back and it just barely rubbed on the one side, so I just barely dented the inner fender and it didn't rub again.
Jordan
1972 Chevy K5 Blazer, 6" Lift, 35x13.5R15, 6.0/6L80E/NP205
1982 Chevy C10 SWB, 2006 LS2/4l70e
In progress....
http://67-72chevytrucks.com/vboard/s...d.php?t=439860
shenk10 is offline   Reply With Quote
Old 09-23-2013, 10:25 AM   #202
shenk10
shenk10's Avatar
Well it has been a while since I updated anything on here. I have been slowly working at the truck and have completed a few things since I posted last. With the cab I got all the drip holes welded up and all the paint removed from the exterior. I didn't like how the pieces I welded in replace of where the stock steering shaft go so I cut the pieces back out and then ended up welding two pieces of steel across the whole firewall. I also got one collector welded to the header and still have to weld the other before I can get them coated.
Jordan
In progress....
Old 09-23-2013, 10:27 AM   #203
shenk10
shenk10's Avatar
Jordan
In progress....
Old 09-23-2013, 10:35 AM   #204
shenk10
shenk10's Avatar
Then I started to concentrate on the bed some. Both of my bedsides have bad rust at the tailgate posts where the tailgate mounts. I ended up removing all the spot welds and taking the outer bedside panel off and removing the tailgate post into the two pieces. The replacement tailgate post I got wasn't exactly what I needed and I couldn't find any place that sold the inner tailgate post so I got pieces out of the replacement post I got for both the inner and outer tailgate. I still need to finish it up but I'm very happy with it. The outer post still needs the holes drilled. The first picture is what it should look like from stock.
What mine looked like:
Jordan
In progress....
Old 09-23-2013, 10:43 AM   #205
shenk10
shenk10's Avatar
Repair to outer post:
Repair to inner post:
What mine looks like now, I still have to drill the holes and cut the outer post so that it matches the angle of the stock post:
Jordan
In progress....
Old 09-23-2013, 07:08 PM   #206
oldman3
oldman3's Avatar
Re: 1982 C10 swb "SS"
Looks like your moving right along, nice repairs...Jim
oldman3 is offline   Reply With Quote
Old 09-23-2013, 11:03 PM   #207
shenk10
shenk10's Avatar
Thank you
Finished up the tailgate post today and started on the other bedside.
Jordan
In progress....
Old 02-22-2014, 07:49 PM   #208
moregrip
moregrip's Avatar
awesome job! any updates?
1983 Chevy C10 250/3spd (current project truck)
1976 Chevy C10 350/350 Heavy Half (future project truck)
moregrip is offline   Reply With Quote
Old 09-14-2014, 06:30 PM   #209
shenk10
shenk10's Avatar
Well I'm still around, just don't have any updates. The truck is back in PA, and I'm stationed in AK, so it might be a while before I get the chance to work on the truck again.
Jordan
In progress....
Old 05-16-2015, 05:26 PM   #210
raulb24
raulb24's Avatar
Great project!!! any updates?
raulb24 is offline   Reply With Quote
Old 04-09-2016, 08:12 PM   #211
shenk10
shenk10's Avatar
Well I'll still be up in Alaska for another 2 years so I wont get a chance to finish the truck until I get back home. I did end up buying a 1972 Chevy Blazer up here though so that is my new project. The plans for it are a 6" lift running 35x13.5r15 tires with drive line being a 2010 6.0/2011 6L80e and the original np205. Hopefully I'll get that running before the end of the summer and may make a build thread for it. Name:  20150824_170233.jpg
Jordan
In progress....
Old 05-24-2021, 10:27 AM   #212
Duck1
Originally Posted by shenk10 View Post
Does anyone have any input on what rear I should run? Will the 10 bolt be enough for a 3200 rpm stall and at most 400 wrhp for now? I think I might look at junkyards and try to find a 10 bolt or 12 bolt with a posi and hopefully 3.73 gears.
for 12 bolt look in pre 80 4X4 they typically com 12 bolt and posi from factory. 10 bolt should be fine thats what your donor truck had
Duck1 is offline   Reply With Quote
