Old 02-07-2013, 08:49 PM   #26
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Anyone rebuilt an OEM sliding rear window?
Originally Posted by 2Cav View Post
The lock on mine is gone, sure would like to find a new clip, or even a new frame if that is what I need.
subscribed!
Jeff
Aftermarket pieces are available. Not an OEM match but they work. Last one I got was from Mike's Bump and Grind Garage, now out of business I believe. I'd call Wes at Classic Heartbeat or try another board vender.
Old 02-07-2013, 10:29 PM   #27
70cst
70cst's Avatar
If one is patient one might try and find a slider that is cheap and buy it for parts.
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 02-07-2013, 10:57 PM   #28
Littletony
Littletony's Avatar
Looks good, I cant wait until you get it back together. If everything is tight and leak free I will by me a slider and do the same thing. Thank you for posting this up for everyone.
"Some people spend an entire lifetime wondering if they've made a difference. The Marines don't have that problem." President Ronald Reagan,1985
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!" ..............Eleanor Roosevelt, 1945
Littletony is offline   Reply With Quote
Old 02-07-2013, 11:22 PM   #29
A-B Slinger
A-B Slinger's Avatar
My 80 K10 has the rear slider. The local auto glass shop here in Lewiston had the upper and lower sweeps. Perfect match. They also had the catch assembly. Another perfect match. If I remember correctly these two items came to around 20 bucks. The rubber between the two glass panels came from the RV shop here in Clarkston. Perfect match and free at that.
A-B Slinger is offline   Reply With Quote
Old 02-08-2013, 08:25 AM   #30
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
I'm skeptical that a 40 year old rear slider with tight seals and intact glass can be located in a salvage yard anywhere.
I hear that. You'll just end up with another one that needs new seals.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 05-04-2013, 12:27 PM   #31
owner 84
owner 84's Avatar
Anyone has done rebuilding his sliding window? After all discussion.
What model of sliding woindow?
What website did you buy from?
What is the spesific size or number of product?
email me @ nasser_060@hotmail.com
and Check out my flicker @
http://www.flickr.com/photos/0060/
owner 84 is offline   Reply With Quote
Old 05-04-2013, 12:35 PM   #32
owner 84
owner 84's Avatar
I tried a local glass shop (two) and called a local business that installs camper shells and repairs the sliders in these shells with no luck.
First image shows the "sweep" I need to track down:
The sweep inserts into the vertical metal post at the far right of the second image. This post has screws (shown) that attach to the outer frame. The weather stripping and a plastic insert that goes into the bottom of the outer, narrow "C" channel are also shown:
Third pic shows square rubber strips mounted inside the larger inner "C" channel at each corner that function as bumpers to stop the mobile glass. Mine are still surprisingly pliable and don't need to be replaced:
Potential source for a replacement latch: http://www.technologylk.com/__663/cr...t-latches.html
Can you tell the PART NO for each one?
How many inches did you need?
Old 05-04-2013, 12:40 PM   #33
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Sorry no more progress on my end yet - have been way too busy but my schedule is slowly easing up. I've posted all the details I have so far as regards the specific parts. I will finish this. I have to for my K20 build (link in signature below) and will post here once I'm back on the job. It's getting the right rubber parts that's the challenge - the slider is easy to assemble/disassemble.
Old 06-20-2013, 06:55 PM   #34
MW826
MW826's Avatar
Does anyone have the part number or company of the OE latch? I always thought my slider was aftermarket, but now I'm not sure, maybe just my latch. It was built by SouthCo Lester Pa. The rest of the window looks too contoured to be aftermarket.
-Mike
Psalm 25
'71 Custom Camper 20-400
http://67-72chevytrucks.com/vboard/s...d.php?t=421720
MW826 is offline   Reply With Quote
Old 06-20-2013, 07:21 PM   #35
DeadheadNM
Carpe manana
DeadheadNM's Avatar
These are/were available - I got one a while ago from Mike's Bump and Grind Garage - not sure the company is currently in business. Maybe Wes at Classic Heartbeat would have an idea?
Old 06-20-2013, 08:26 PM   #36
70shortfleet
70shortfleet's Avatar
If I remember correctly that latch was used on numerous years after 1972 and was still available from GM the last time I got one. I have 2 maybe 3 factory sliders up in my attic!
70shortfleet is offline   Reply With Quote
Old 09-27-2013, 01:17 PM   #37
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Finally completed the slider rebuild and it works well (pics installed on my K20). However, the vertical aluminum trim/handles had to be re-attached with silicone so I have concerns about long term longevity. As a consequence. I open the slider windows using the firmly affixed midline trim where the latch pieces attach. Who knows, it may hold up for a long time. The white weatherstrip shown in post #24 worked fine but I had to shave the base of the molding's "T" with a scalpel in order for it to fit inside the trim channel. Even with that, the fit was snug so I used Windex along the channel and inserted a dowel inside the wstrip to apply force along its long axis so as not to pull it out of the channel. The chunky rubber corner blocks (ex. on last pic post #8) cleaned up real well and honestly look fresh.
As an aside, I had rear window trim installed with the slider but GM shipped slider-equipped trucks without the rear window trim.
Old 09-27-2013, 03:00 PM   #38
Lemield
Lemield's Avatar
Wow Pete...truck and slider window look really nice.
Larry
1949 Willys CJ2A, Kubota Turbo Diesel engine, Warn Overdrive, 11 inch brakes, 12volt, Warn M8000 Winch "Little Green"
1970 Rustoleum Roller Red C20 Custom Camper 454 TH400 "Big Red"
1971 K20 6.2 Turbo Diesel 4x4 4spd Ranger Overdrive "Pumpkin Wagon"
2005 VW Beetle Diesel 44+ MPG "Silver Bullet"
Lemield is offline   Reply With Quote
Old 09-27-2013, 04:36 PM   #39
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
Try a local "aluminum products," & storm windows, & window replacements store. Auto glass shops probably wouldn't have the same kinds of weatherstripping on hand.
I had a siding, guttering & window replacement & storm window business for many years, & we had rolls & rolls of lotsa (dozen or more) different styles of similar weatherstripping that I kept on hand to do repairs. Had what looked to be a twin for the compressible tube weatherstripping in the photos. Not an uncommon type at all. Shouldn't be too hard to find.
If it wants to slip out after installed, "stake-it" into place near the bottom of the track - we always used a small straight tipped screw driver to punch down (lightly) the sides of the track that the bottom (T-part) slides in. That stops it from sliding down / falling out when the sun gets on it & softens the rubber & stretches the aluminum track a little bit.
Dave Ellis
Mtn Home, AR
68shortstep is offline   Reply With Quote
Old 09-27-2013, 04:56 PM   #40
bigmac73
bigmac73's Avatar
is the outside gasket/seal the same as the regular glass, i noticed that they are not listed in any catalog, for a slider
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 09-27-2013, 06:31 PM   #41
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Thanks Larry!!
Dave Ellis
Mtn Home, AR
Appreciate the suggestions Dave - I have a few more and look forward to rebuilding another - will use your suggestions for sure. BTW - I have a good friend who just moved to Mountain Home, sounds like a real nice place and a good area for trout fishing. Pete
Old 09-27-2013, 06:36 PM   #42
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Yep, same gasket you choose trim or no trim depending on whether you are using trim or not - just like that for regular one-piece glass. Pete
