09-27-2013, 09:13 AM | #1 |
gas tank move
is it really worth the trouble of relocating the gas tank to the rear under the bed???
and what are the common problems and issues when doing the install??
Mike 72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider. 421 SBC / TH350 3000RPM Stall Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks |
09-27-2013, 09:18 AM | #2 |
Re: gas tank move
I am also in the same boat! This is another winter project for me! Same quwstions here?
Posted via Mobile Device |
09-27-2013, 09:44 AM | #3 |
Active Member
Re: gas tank move
The main problem I've heard people talk about has been the location of the filler neck. The other problems I've read about are fuel pump type, venting, wiring and the looks of a fuel tank hanging on the back side. One person mentioned he didn't like the possibility of being rear ended with a tank full of fuel on the rear.
I've contemplated it but always decide to just leave it where it is. I figure it's been there for 40 plus years without any problems so far. Some people don't like the idea of a fuel tank behind the seat, but to me, it's safer than behind the rear axle. Plus, if it has a leak, I can smell it a lot quicker. Some of the pro's are that you don't have fuel smell if the one you have is unvented and added weight moved to the rear axles.
68 GMC 250/3 speed Saginaw p/b p/s 69 Chevy 350/350 currently in pieces still lookin for a cab 06 Trailblazer I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive... |
09-27-2013, 09:53 AM | #4 | |
Re: gas tank move
i agree i guess i was looking for more room behind the seat for speakers, i just did not want to cut my doors, put it is a pretty standard move with the older trucks
09-27-2013, 12:41 PM | #5 |
Its a Truck Thing......
Re: gas tank move
I have done it and the only issue I have had was the filler neck, which I have made work, but it could be better. I wouldnt worry about crashing because there is a lot of frame rail that has to be destroyed before the tank gets hit. The suburbans have it so its not like you are starting from scratch. I would go with the metal or aluminum tank, not a fan of the polly tanks.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time |
09-27-2013, 01:17 PM | #6 |
Re: gas tank move
71MEANGREENC10
Smitty, Are you ever coming back to Huachuca? Still playing with mine. Wish you were here to kick me in the butt every now and then.
Keith 70 CST longbed in progress. Hoping to get it back on the road soon. |
09-27-2013, 01:49 PM | #7 |
Re: gas tank move
If you move it you will need to decide what to do about the spare tire.
09-27-2013, 02:26 PM | #8 |
Re: gas tank move
spare tire stays in the back of the bed, i dont do underneath set ups anymore, i have been caught out in muddy wet , BFE roads and fields before and not happy to get under the truck to remove the spare tire, not me
09-27-2013, 02:47 PM | #9 | |
Active Member
Re: gas tank move
One thing to be aware of with tires in the bed. Make sure it's tied down some way. Tires ain't cheap these days and easy for someone to make off with it unless chained to something.
09-27-2013, 03:38 PM | #10 | |
Re: gas tank move
09-28-2013, 05:49 AM | #11 | |
Re: gas tank move
Hope all is well, we will know in three years...... Smitty
09-28-2013, 07:26 AM | #12 |
Re: gas tank move
Do a search for... '69 Camaro gas tank
http://67-72chevytrucks.com/vboard/a...1348778248tank |
09-28-2013, 09:27 AM | #13 |
Re: gas tank move
I'm in the middle of doing this now. There's a very cool spike tv episode you can find on their website by typing in 72 chevy truck. They put the filler neck behind the side marker light. I just fabricated mine for this, but I'm in a hotel right now and have no pictures. It's even easier on a stepside like mine than on the fleetside they used in the show. Good luck
