Old 09-27-2013, 05:02 PM   #1
Blue Heeler
Blue Heeler's Avatar
exhaust tube routing.
Wondering if anyone has some pictures of exhaust routing on a 65 c10 lowerd truck. just bought a kit from Jegs that was a good price to pass up. thanks
Blue Heeler is offline   Reply With Quote
Old 09-27-2013, 05:05 PM   #2
TJ's Chevy
TJ's Chevy's Avatar
Re: exhaust tube routing.
V8 or Inline 6?
Old 09-27-2013, 06:55 PM   #3
Blue Heeler
V-8. sorry bout dat.
Old 09-28-2013, 09:05 AM   #4
vin63
It's Better With Nitro
vin63's Avatar
Are you looking for photos of exhaust tubing routed to the inside of the frame rails, or to the outside?
1963 C-10: Deluxe-optioned cab, shortbed, fleetside
Pontiac 462 ci, Kauffman D-Port alum. heads
4L80E, narrowed sheetmetal Ford 9-inch
Tubular front and rear suspension
Custom 6-piston front disc and 4-piston rear disc brakes
vin63 is offline   Reply With Quote
Old 09-28-2013, 09:15 AM   #5
wjjeeper
wjjeeper's Avatar
I'd Ike to see both.
wjjeeper is offline   Reply With Quote
Old 09-28-2013, 11:04 AM   #6
chevyrestoguy
chevyrestoguy's Avatar
See post 159 of my '64 build thread. There's some shots of what my exhaust looks like. 2.25" pipe, routed between the frame rails, between the trailing arms, and tailpipes dumping behind the rear wheels.
Check out my latest endeavor:
https://roundsixpod.com
My build threads:
'55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512
'64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527
chevyrestoguy is offline   Reply With Quote
Old 09-28-2013, 11:51 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm running a true-dual setup with a side dump. It runs outside the frame 95% of the way, and tucks under the rockers. You can see it going together around the 3rd or 4th page on my build.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 09-28-2013, 04:13 PM   #8
Blue Heeler
Looking to see inside frame rails and outside just to get a ruff idea.
Old 09-28-2013, 06:09 PM   #9
vin63
vin63's Avatar
3-inch tubing routed to the outside of the frame rails...
...muffler located behind the cab, under the bed with turn out in front of the rear tire...
Old 09-29-2013, 03:38 AM   #10
familyfast64
familyfast64's Avatar
Here's a piss poor shot but it's 3inch and comes out right before the tire. It is hanging below the frame tho.
Live and let live
familyfast64 is offline   Reply With Quote
Old 09-29-2013, 03:41 AM   #11
familyfast64
Prolly pretty close to the kit tho welded like you can do at home.
Live and let live
Old 09-29-2013, 03:45 AM   #12
familyfast64
The guy above me had a kick as set up but short headers so this gives ya two options anyway.
Live and let live
Old 09-29-2013, 10:16 AM   #13
Blue Heeler
good set-up vin63. on familyfast64 i'm trying to stay above frame rails because i'm gonna lower the truck 5 1/2 front and 6 rear i would have no room there.
Old 09-29-2013, 04:04 PM   #14
familyfast64
I understand, just thought you might have full length headers. I agree tho, tucked up right is nice, but I will say mine is lowered and I have room but it's not slammed. Your progress looks awesome tho keep it up.
Live and let live
Old 09-29-2013, 04:07 PM   #15
familyfast64
Oh I guess I'm complementing vin63. I'm sure yours looks awesome to tho.
Live and let live
Old 09-29-2013, 06:32 PM   #16
vin63
vin63's Avatar
Originally Posted by Blue Heeler View Post
...i'm trying to stay above frame rails because i'm gonna lower the truck 5 1/2 front and 6 rear i would have no room there.
Yep, that's why I routed my exhaust to the outside of the frame to keep the entire system above the bottom of the frame rails. The 4L80E transmission and mount prevented me from running the exhaust to the inside of the frame. Here are a few photos as I was pie cutting and tack welding for the compound curves of the head pipe, and mocking up the rest of tubing and muffler...
