1974 Chevrolet C-10 Custom (diesel)
Hey everyone, I've a '74 Chevy
Re: 1974 Chevrolet C-10 Custom (diesel)
Paint job looks new, but its actually original. Old guy that owned it kept it in the garage most its life.
original 350 with 97k
You might want to be careful if you go the cummins route with the truck being a half ton. I think a 4BT would be safe but if you went the 12 or 24V route you'd be better off with a 3/4 ton... Just my 0.02$. Very nice looking truck!!!!
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax ![]() |
I was kinda thinking the same thing. I currently have a 12v at the shop, so that would save me a little cha-ching but then I'd need to invest more into the truck it'll be dropped in so it could support that kind of engine. Or just invest a little less in the actual truck and use the rest for purchasing a 4bt.
Anyone can fly a plane, but only some can pilot a plane. |
78K & 79C Jimmys
dam that looks good
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Thanks man, considering the old man did his part in preserving history, i figured I ought to do mine.
WOW ,that is a nice looking truck ,maybe since we are not that far apart maybe I can see it in person someday.
Yeah man, however as of mid-late november it'll be in the shop for a complete rebuild/restoration. So if you'd like to see it before we'd need to make plans before then.
To be honest with you, your c10 is plenty strong enough to support a 6BT. I've got a half ton Tahoe with this engine in it and have had no issues with the additional weight. That said, I highly recommend the 6BT over the 4BT. The 4BT's are loud and make enough vibration to loosen teeth fillings.
1990 ¾ ton 4x4 Chevy Suburban -Cummins Diesel - 12 valve - factory rebuilt -6 speed bullet proof manual transmission - NV5600 -Gear Vendors Overdrive - HX35 Holset Turbo -NP205 iron transfer case -3.73 gears -2" Lift |
Interesting, how does it handle the torque? And did you do any reinforcements or anything along those lines to allow it to handle the engine better?
#12 | |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
I see your point there. Also, did you have any need to move the firewall back or any reworking of the engine well to allow it to fit the 6bt?
#15 | |
The engine bays on these trucks are more than adequate to fit a 6BT. In fact, when all is said and done, the engine looks like it was meant to fit in there.
#16 |
Gotcha. My main purpose for doing this is so I'll be able to haul heavy loads of metal and equipment that the 350 couldn't. Which is were that extra torque helps out!
#17 | |
Also check here for some more swap info http://www.4btswaps.com/forum/forumd....9-Conversions
#18 |
What about turbos? Like brand, model, etc? And I'm assuming it'd be a good idea to possibly put a "heavy duty" rear end in it.
#19 | |
http://www.dieselplace.com/forum/63-...diesel-engine/ http://www.dieselplace.com/forum/63-...s-performance/
#20 | ||
If you've got a 12 bolt rear end, it should be more than adequate. However, what rear end you use will have a lot to do with what transmission you end up using. If you're going to use an overdrive transmission, you'll want 3.43's and without overdrive, 3.08's or 2.73's. These 6BT's make their power at low rpm's.
#21 |
I think it is cool what you are planning to do.
But I will throw out this: If you plan on hauling loads "the 350 couldn't", your existing half ton suspension/brakes probably can't either. |
#22 |
Just here to tinker
![]() Join Date: Jun 2008
Definitely following this thread as I also plan on putting a 6bt in my '78 shortbox.
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 |
Tags |
1974 custom, 350, c10, chevrolet, restoration |
