47 Step van
While Shannon works on the 1951 C 4,,,I started the bull work on the new work truck,,,http://i1363.photobucket.com/albums/...49f.jpg:metal:
48 GMC Burb 51 Chevy AD 3100/C 4 byShannon 74 Chevy P 10 48 Double Duty 04 SS Burb 01 Springer HD |
![]() Join Date: Apr 2009
Re: 47 Step van
I'm in ♡. That thing would make an awesome RV.
Posted via Mobile Device |
Re: 47 Step van
Love the truck. Not a fan of lowering.
Re: 47 Step van
TKG guys
I need say that the AUTO TRUX is not mine just a pic of what could be. My plans are 87 1/2 susp 2" lowered,4 wheel disc, 350 vortec FI,460 LE trans, & AC. If anyone has one or some pic please post TKS KC
Re: 47 Step van
I mocked up the front & rear susp then sent it to Shannon AKA Magic Metal Man
Re: 47 Step van
I just think I might have seen a frame of one of those. Bad thing is I only have 3 pictures of the rear suspension. I will post later.
Shannon
48 Panel Truck 1948 Chevy / S10 1954 Chevy / S10 1951 Chevy / C4 47 Step van Lowered 1996 Dually |
Re: 47 Step van
Seems like forever since I last posted. So here are some pictures of the frame. It is a 1947 frame with 1987 1/2 ton suspension. The front is bagged and the rear is leaf springs with bags as helpers because this will be a work truck. The motor is a 305 vortec with a 700r4 for the tranny. I can not wait to see it with the body on it to see the way it will set. I will be a neat truck when up and running.
Shannon
Re: 47 Step van
Ken put the cab back on the frame this weekend. So I could not wait for you guys to see what the truck looks like. He said it sets about 11 inches off the ground. Looks low for how big it is. Remember this will be a work truck so laying on the ground was out of the question.
Shannon
Re: 47 Step van
Nice truck ,never saw one like it before ,what kind of work truck will it be ?
Re: 47 Step van
It will be a mobil Grooming truck . This is the first one
Re: 47 Step van
It has been a while since I posted. I have been working on the box truck plus with the holidays I have been super busy. I have the truck at my house now. Ken ordered a boat load of parts for me after I figured out what I needed. I mounted the body on the chassis. I made a mount that houses the compressor and the air tank. He is going with a toggle or manual air switches. I have it all plumbed up but it looks like a rats nest till I redo the dash. I put on the coated shorty headers and have all mandrel bends to do the exhaust. They are coming out in the center of the back were I will make a custom aluminum roll pan. I bought a AD under the cab brake assembly where it will really be on top of the frame because of where you set. That will take a special mount. Then comes the steering which is going to be fun. The column comes out in front of the steering box so I ended up getting a clear steer box from wizard. It is a really nice piece. Then I can mount the steering column. I should have a lot of pictures in the next coming weeks. The pictures are with it aired out. It is really a neat truck.
Shannon
Re: 47 Step van
Shannon
![]() Join Date: Mar 2007
Re: 47 Step van
I really like the stance in the last few pics. If it is for a mobile dog gromming rig you want it nice and low so the small dogs and easily walk right in. Ha ha
I like it Marc
…………...........__________ .................. ((__|__||___\____ ..;.;;.:;:;.,;..;((_(O))____ (_(O)) 1948 Chevy Truck - Finished SOLD!! 1953 Chevy Suburban "Family Truckster" Completed: Spring of 2021 http://67-72chevytrucks.com/vboard/s...d.php?t=605484 1994 4x4 Blazer - "Field Find" https://67-72chevytrucks.com/vboard/...ferrerid=30857 |
Re: 47 Step van
I'm in that is sick.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc http://67-72chevytrucks.com/vboard/s...d.php?t=382481 49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold http://67-72chevytrucks.com/vboard/s...d.php?t=594874 VIDEOS https://youtu.be/E8zHhjgS_lA https://youtu.be/E8zHhjgS_lA Geronimo 54' LS engine, static drop IFS, Client build, just about done http://67-72chevytrucks.com/vboard/s...62#post7399162 52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next! www.coffeeandcustoms.com |
#15 |
Re: 47 Step van
youngrodder, That is with it aired out. It does make it easy to in and out of with it low. The rear doors are a little short for me because I hit my head a bunch of times. But Ken"s wife is shorter than me so she will be alright. It is going to be a neat work truck.
99 to Life, It is really different. I could not find to much online about them. Shannon
#16 |
Re: 47 Step van
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
#17 |
Re: 47 Step van
I just love these, I like the bare metal look. Just screams some old spacecraft theme.
#18 |
Re: 47 Step van
_Ogre, I like the metro. I too think these old box trucks are just plain cool.
99 to Life, They are cool, the outside is going to be part wrap and some bare aluminum with some engine turning. Shannon
#19 |
![]() Join Date: May 2010
Re: 47 Step van
Do you have any info on how you did the front suspension swap?
#20 |
Re: 47 Step van
itstheshu, if you are thinking about putting it on a regular truck it will be a little too wide. The box truck is wider than a regular truck. But here is how I did it. There was about 3/4 on an inch on each side of the frame and crossmember, so I has some plates burnt out and used them as spacers and welded them too the frame. Then bolted through the crossmember, spacers and the frame. I also had to make spacers for the box and the idler arm. The AD frame was about 1 1/2 inches narrower than the 87 c10 frame.
Shannon
#21 |
Re: 47 Step van
shannon,
check out this one, I saved this pic a while ago. Seems like the same van.
#22 |
Re: 47 Step van
99 to Life, that might be a metro, but that is really cool. I like it a lot.
Shannon
#23 |
Re: 47 Step van
Worked on the exhaust today. I am using all mandrel bends, they came from speedway motors. Here is a little trick on connecting them, I use a piece of angle and use hose clamps to hold it. I tack it at 2 places and then pull it out and tack at another place , then weld it around. I got the exhaust all the way back to the rear end and made the pieces over the rear but have to jack up the rear to check for clearances. The exhaust is are going to come out through a custom aluminum roll pan. Here are some pictures.
Shannon
#24 |
Re: 47 Step van
Shannon
#25 |
Re: 47 Step van
Worked on the truck this morning before shoveling the snow. I had a SST battery box from another project. I made a aluminum frame work out of angle. I used SST fasteners to attach them together. I TIG welded the corners. Then cut a hole in the front passenger side wheel well. Then installed it. I still have to bolt it in. I made a aluminum bead rolled cover to place over it. Hopefully the snow will not last long on the driveway so I can finish the exhaust.
Shannon
