11-04-2013, 11:30 AM | #426 |
Re: Crusty Rusty Leaky Squeaky 67 Step
Fusor 122 is the hi-tech stuff- can be seen here-
http://67-72chevytrucks.com/vboard/s...=575769&page=7 I got the Lord Stuff at Auto Color and Equipment, the paint store I use on 23rd between Noland and Lee's Summit rd on the North side. Well, hell. I just figured out Lord makes Fusor. Gaah. Anyway, the easy standard caulk gun stuff is Fusor 800 EZ, and it is. A little messy, wear gloves, mineral spirits on a finger slicks the whole channel right up nice. Get extra shoot tubes. It's what we used on Yeller. Uncle Matt got all zen and did it right over the first crap I put on while I was wigging out and handing him stuff like a squirrel on meth. Sometimes cooler heads must prevail! Your work is looking great! Can't wait for the next installment! Ps- don't forget to look down into the holes there on the top of the cowl and inspect the heck out of that seam-especially on the pass. side. Sneaky sneaky rust there, big leak later. Found it there big time but almost unnoticeable on Yeller. Keep it up!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
11-08-2013, 11:40 AM | #427 |
GEARHEAD
I'm late to the party but jumping on the band wagon now. I scrolled through most of the build this morning and you're doing some real nice work. Watching guys like you always makes me feel like a hack, but maybe over time some of the finer points to doing this work will sink in and I can at least aspire to greatness. And thanks to you I have a few more tools added to my watch list on ebay.
If no one knows what you're doing, they can't tell you you're doing it wrong HG's Dream Car Build - Shelby Cobra Kit Build your own adjustable track bar 71 Long Fleet C/10 72 Jimmy 4x4 (Junkyard Jimmy) HG's Plow Truck '78 K35 Dually Bigass Farm Truck HG's thread of miscellaneous stuff |
11-08-2013, 12:05 PM | #428 | |
11-08-2013, 12:11 PM | #429 |
Still Learning
Very nice work on the firewall and roof. This cab will be as close to perfect as you can get when done. Keep the pictures coming.
11-09-2013, 05:58 PM | #430 | |
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
11-09-2013, 06:15 PM | #431 |
I've been puttering around with stuff that needs to be done, but doesn't have as much impact as big body panels. I decided to reinstall the accessories on the front of the engine and was in the process of giving the brackets a tune-up when I was hit by Moore's Law. If more is better, too much ought to be just right. While attempting to give the nickel plating a satin look, I spent too much time on the front of the AC bracket with the glass beads. Long story short, I ruined it and one other piece as well. Costly mistake, but I've decided to send them to Jonathon for powder coating and call it good.
The front of the fan pulley was bothering me, so I dug around in the scrap bin and found a piece of aluminum that I'd machined a long time ago as a steering wheel adapter for my 57 Ford. With a little work it became a cover for the front of the pulley which looks much better than four bolts and the pilot. Also finished welding out the patch in the dash where the stereo head will go. Today was probably the last day the temperature will permit painting for a while. I needed to get the last of the pulleys painted and while I was at it, I went ahead and squirted the driveshaft and the shocks. I'll be glad I did it when the cold weather hits next week.
11-09-2013, 08:10 PM | #432 |
Everything looks great Vic.
I can't wait to see the rest of the cab work. |
11-11-2013, 11:25 AM | #433 |
Lookin great Vic!
11-11-2013, 11:43 AM | #434 |
Awesome idea on the pump pulley cover! Looks clean.
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
11-12-2013, 05:14 PM | #435 |
After the paint cured on the parts, I figured to quickly reinstall them and get back on the cab. Not to be. When I mounted up the first Monroe SensaTrac shock, the increased barrel diameter immediately interfered with the axle tube. It looked like if I moved the top of the shock back, it would correct the problem, but after several mods, I'd moved it back 1/2" and only had about .100" between the shock and the axle tube. So the only practical solution was to move the bottom shock mounts forward.
Once again the scrap bin came to the rescue as I was able to find two pieces of 1/2" x 1-1/2" x 3" material that miraculously had two 1/2" holes in just the right spots. The task became much easier at that point. I mocked up the pieces and marked the angle that I needed. I then calmped them on the mill and removed .240" of material to offset them flush with the existing mounting eye. Used the corner rounder to make them a bit prettier and then installed them. Pictures below are before paint and you can see they are supported on the front and the bottom of the existing mount areas. With a 1/2" bolt torqued to 95 ft/lbs, they aren't going anywhere. With the shocks in the front hole, I now have plenty of clearance between the shock barrel and the axle tube. I also went down to the tire store this morning and had the tires dismounted. Headed to Eagle Stripping tomorrow to have the front of all four wheels blasted back down to bare aluminum. When I get them back, I'll use Glisten PC to coat them. It's crystal clear and will not cause the rims to turn grey like they did with the clear powder coating.
11-12-2013, 05:30 PM | #436 |
Great problem solving Vic. Getting closer.
11-12-2013, 07:51 PM | #437 |
Oh the things i could do with a mill! Cool mod!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
11-12-2013, 08:11 PM | #438 |
Very nicely done! You amaze me with your elegantly simple but NICE solutions.
1968 SWB Stepside "Bella coming home" "Bella's Build Thread" A master in the art of living draws no sharp distinction between his work and his play. He simply pursues his vision of excellence through whatever he is doing, and leaves others to determine whether he is working or playing. To himself, he always appears to be doing both. L. P. Jack |
11-13-2013, 02:05 PM | #439 |
Lookin good- the extra vertical should make 'em work!
11-13-2013, 03:03 PM | #440 |
Very nice work! Corner rounder??? Is that quarter round tooling for your mill? Anxious to see the clear coat on the wheels. My factory alloys on the Silverardo are looking shabby
11-13-2013, 03:15 PM | #441 | |
The wheels are at Eagle Stripping as of this morning along with several other pieces. Hope to have them back by next week. Meanwhile, the weatherman says the temps are supposed to be in the low 70's on Sunday, so I may do a couple of test pieces with the Glisten PC to see how it works. Will post pics of the results.
11-13-2013, 03:18 PM | #442 |
Yep, I remember you suggesting that I relocate the bottom mounts, but I thought I could get by without it. Then the SensaTracs sent me off the cliff and I had no choice. But I'm much happier with the results now.
11-14-2013, 11:12 AM | #443 |
I wish I had a mill. You make some pretty cool parts when you need a solution to a problem. I'd love to be able to do that kind of stuff.
As always, NICE WORK!
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
11-14-2013, 12:17 PM | #444 |
Still Learning
That paint looks great!
11-14-2013, 01:29 PM | #445 | |
While we're wishing for stuff, I'd love to have a GTO like yours. It's my favorite year and model. We had a couple of 69 Judges when we lived in Missouri City, TX back in the 70's. Picture below was taken up at the track in Porter, TX. We used the stock appearing one to tow the race car.
11-14-2013, 01:39 PM | #446 |
Thanks, Mike. Me and painting go WAY back. Nowadays, though, I have to work myself into the mood to do it. Plus, my shop isn't really setup very well for paint work, so I mainly stick to small stuff or primer.
11-14-2013, 07:27 PM | #447 |
Finished welding out the patch for the speaker grille. Took a long time to stitch it together, but still had to use pins to pull out a few low places and the hammer and dolly in others. Makes me wonder how the long welds on the bed will go. No use fretting over it, will cross that bridge when I come to it. Used the Dremel tool to cut out an opening for the center A/C outlet. The plastic duct that fastens to the back of it is resting on the top of the stereo bracket. If the stereo opening was 1/8" higher, I'd be hosed. Sometimes it's better to be lucky than good.
11-14-2013, 08:37 PM | #448 |
Looking good. Nice steady pace you got going. Won't be long if ya keep it up.
11-15-2013, 07:34 PM | #449 |
Today I cut the remainder of the old floor out. Used the plasma cutter to remove most of the rear floor brace and then cut the spotwelds from the inside. Doing it this way means I can use the spotwelder like the factory. Cleaned some of the grunge off the back of the cab sheetmetal and dragged the new floor over and set in place to see what I was faced with.
11-15-2013, 07:47 PM | #450 |
With the floor pan resting in the correct location at the back of the cab, it was immediately obvious there's a mismatch between the outer edges of the floor and the bottoms of the A-pillars ...like about 1-1/2" total. The tunnel was bumped up against the brace due to planning two steps ahead instead of three or four. However, the fix was to make a bridge to clear the hump. I clamped it in place instead of welding it in case I need to spread the A-pillars. Right now I'm wishing I had the firewall back so I can compare the flanges where they meet. However, I don't recall there being a big gap at the bottom where the firewall meets the kick panels.
I did some research on the forum on installing a full floor, but most of the fitment issues were between the firewall flange and the floor, not that the floor was wider than the spread between the bottoms of the A-pillars. Will have to wait until the firewall is back to see what I'm going to have to adjust. (As in pie cut, hammer, port-a-power, heat, bend, curse and etc.)
