Old 11-03-2013, 01:36 AM   #1
JellyBeanDriver
2001 Jimmy-runs fine, was PO338 now PO300, and case relearn question
Not a truck but maybe someone knows what to do next?
Helping a friend with a 2001 Jimmy, 4.3L V6. Can't smog due to PO128 and PO338 error.
Fixed PO128 with a new thermostat.
Inspected CKP sensor and it is not hitting the reluctor but put a shim on it anyways. Now I have a pending PO300 code (random misfire).
What is interesting is when parked and I rev the engine up to ~3500RPM, the speedo starts to give a reading - like 4-6MPH.
Vehicle runs fine otherwise. Cap and rotor look good but also look original. Plug wires someone changed in the past. Look good but I don't know how many miles on them.
I'm thinking the PO338 to PO300 change is a clue. Want to do a CASE relearn but no scantool I own will do it (is there an inexpensive one?) Or is it red herring and the fact the speedo gives a reading shows the problem is electrical noise?
Anyone run into this before on this or another GM 4.3L product?
86' C30 Dually Crew Cab Ranch truck, carb'd 454, TH400, towing a slant load 4 horse trailer.
JellyBeanDriver is offline   Reply With Quote
Old 11-03-2013, 11:28 PM   #2
JellyBeanDriver
Re: 2001 Jimmy-runs fine, was PO338 now PO300, and case relearn question
Sorry, typo. It's was a PO335 error, now it's a pending PO300 error.
Old 11-09-2013, 02:34 AM   #3
JellyBeanDriver
Pending PO300 turned out to be nothing. No error codes now except for a PO410. Found the 30A fuse blown for the air injector pump. Will go through it tomorrow and see if I can fix the motor.
