01-02-2013, 10:55 PM | #76 | |
Re: LS factory cruise control hook up
There may be more info in my build..
Mark ----------------------- Crash's 69 4x4 SWB Crash's Roof over Lake Home Crash's 1988 Land Cruiser Build |
01-05-2013, 12:04 PM | #77 |
Hey nova you have a pm
Posted via Mobile Device |
01-05-2013, 12:06 PM | #78 |
Good info. Does anyone make those for sale? If so, how much?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-05-2013, 01:19 PM | #79 |
Not that I know of.. It would only take the first two relays, the 3rd is one I added for the DD gauges..
Any type of relay would work.. you would not have to use the micro ones I used. You could use regular Bosch type relays...
01-05-2013, 01:24 PM | #80 |
PM sent.
01-05-2013, 01:49 PM | #81 |
Crash, clean out your PM box......
01-05-2013, 01:50 PM | #82 |
02-02-2013, 12:51 AM | #83 |
What does it take to get cruise working on a GenIV?
-Don- '66 C10 w/factory A/C '77 Cheyenne K5 350/465/205 '80 Custom Deluxe K20 350/465/205 '04 Denali XL '05 DMax CCLB 4x Have a Hickey Sidewinder Winch and need the owners/install manual? Send me a PM with your email address and I'll forward you a .pdf |
06-23-2013, 02:14 PM | #85 |
GM ONLY BABY!!!
Hooked mine up on my 72 GMC with 01 6.0 dbc but its not working. I have led taillights. What do I need to check ?
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
06-23-2013, 05:00 PM | #86 | |
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
06-23-2013, 06:53 PM | #87 |
GM ONLY BABY!!!
I have power at pink and purple. Am I supposed to have any power at vss out or K on module?
06-23-2013, 07:29 PM | #88 |
GM ONLY BABY!!!
Hooked a 2k resistor in there and now it works. Thx.
07-22-2013, 09:12 PM | #89 |
I just swapped in a 6.0 in a 86 k10 with a 700r4 Mabee I missed something but can this work with a 700 r4 with a psi harness? I have the cruse box that would mount on the firewall of a 99-02 truck. My swap is also drive by cable.
07-22-2013, 10:10 PM | #90 |
Maybe. What are you doing for a speed sensor (VSS)?
07-23-2013, 07:20 AM | #91 |
Well it's an 86 so it has a cable speedo. So I'm assuming unless I get some aftermarket converter to get a vss output it's a no go?
07-23-2013, 10:09 AM | #92 |
GM ONLY BABY!!!
Speartech labeled a yellow wire for my speedo output. I spliced into that on mine.
07-23-2013, 10:14 AM | #93 |
Yes, I'm afraid so. You need some kind of speed sensor to get a signal for it to work.
07-23-2013, 11:02 AM | #94 | ||
http://www.dakotadigital.com/index.c...rod/prd109.htm
08-19-2013, 12:55 PM | #95 | |
11-12-2013, 05:48 PM | #96 |
Back over on page 2 of this thread "farmtruck" asked about dbw, cruise, and the ebrake. I believe I am running into this same issue. I have a 2005 DBW out of a Tahoe and have wired, checked, re-checked, and checked again all of the cruise, brake switch, and TCC switch connections... all are good but still no cruise.
How do I get the cruise to work? I have a total of three harness connections. 1. The main harness to the computer 2. Two harnesses on the TAC black box. I have spent hours looking for possible solutions with no results. Any help is appreciated. Thanks.
71 C-20 Custom Camper California Truck |
11-12-2013, 09:18 PM | #97 | |
11-12-2013, 09:41 PM | #98 | |
4 wires from the tac for the cruise: gry/blck, blue, gry, light blue. Light blue to brakes "on" switch (again used a relay here for the blue brake and TCC purple). Brake lights are standard and I have adjusted the brake switch so they come on when the pedal is pressed. Should I check to see if there is a voltage leak out of the switch? It is the original. Thanks for the questions your name comes up in a ton of forums regarding cruise and LS swaps, nice to know I am in good hands. Mark
11-13-2013, 12:07 AM | #99 |
PROBLEM SOLVED! After replying in the message above I went out to dinner. This has been driving me nuts and I am sitting there eating when it hits me... I had wired the light blue brake "on" wire into the relay opposite the TCC. Technically correct, it will get 12 volts when the pedal is pressed, it also creates the same problem found when folks install leds with no resistors = no resistance on the line.
Got home, grabbed the flashlight and attached the light blue wire direct to the brake lights "on" side of the brake switch. Woohoo we have cruise. See you are a miracle worker.
11-13-2013, 05:34 AM | #100 |
Cool, glad you got it figured out. Saves me a lot of typing on my phone. Lol
