11-03-2013, 05:45 PM | #1351 |
Re: Project '86
Some one with skill such as your self must see alot of trash on vehicles...
You must from time to time just see stuff that you cant even fault them for, but just give them a nod and say "A for effort" haha
1989 3+3 2wd Dually. 454 BB. Factory loaded for the day, including Alcoa rims. |
11-17-2013, 09:04 PM | #1352 |
Re: Project '86
Got bored this afternoon and was itching to make something. Decided to fancy up the core support.
Gonna clean it all up and weld it in later this week. |
11-17-2013, 09:11 PM | #1353 |
Re: Project '86
Looks great bro!!
Fuzzy Dice Club Member 87 Crew SWB Build for the crew http://67-72chevytrucks.com/vboard/s...d.php?t=430082 http://www.cardomain.com/ride/3232925 90 burb 2wd Build Thread For The Burb! http://67-72chevytrucks.com/vboard/s...d.php?t=383055 |
11-17-2013, 09:11 PM | #1354 |
Re: Project '86
You should make those to sell.... Just a thought
11-17-2013, 09:13 PM | #1355 |
Re: Project '86
Hell yeah I'd buy one! Looks killer
WillieloRidez Drive em in Drag em out! Projects: 1956 Chevrolet 210 2dr post 58 chevrolet 2dr delray 58 chevrolet belair 4dr hardtop 1965 Chevelle big block 4spd 88 crewcab 1/2 ton long bed aka STRETCH Lt1-4l60e http://67-72chevytrucks.com/vboard/s...d.php?t=388445 |
11-17-2013, 09:39 PM | #1356 |
Re: Project '86
you got some skills. I like your work. that truck is going to be killer when your done.!
11-17-2013, 11:36 PM | #1357 |
Re: Project '86
Thanks guys
11-17-2013, 11:57 PM | #1358 |
Re: Project '86
Been awhile since I've checked in on your progress. Dude, its looking impressive.
11-18-2013, 07:44 PM | #1359 |
Re: Project '86
You know, if youre not careful, youre going to finish that thing and be forced to drive it around..... :-)
11-18-2013, 08:11 PM | #1360 |
Re: Project '86
damn I need you to stop making this thing so over the top... its crazy just knowing the amount of time you have in some of these one off pieces
1980c-10 mybaby |
11-18-2013, 08:45 PM | #1361 |
Re: Project '86
11-25-2013, 04:07 PM | #1362 |
Re: Project '86
I missed somewhere that you changed the inner fender wells on the ft fenders. I am glad I caught that I was about to make the mistake of putting the single fenders in. Did they rub?
11-25-2013, 04:35 PM | #1363 | |
Re: Project '86
I installed them before I decided to do the body drop so they were too low afterward. Since I had to redo them anyway I decided to change it up and go with the tandem axle trailer fender instead. |
01-06-2014, 12:24 AM | #1364 |
Re: Project '86
Little more from the '72 I am working on
01-06-2014, 01:22 AM | #1365 |
Re: Project '86
Slick little mount set up.
01-06-2014, 02:31 AM | #1366 |
Re: Project '86
Wow great work. From that 91 to that 72 and everything else in between. I am sure I missed something along the way buried in the many pages. Top notch.
My Chevy habit is paid for by Ford diesels... Here is my SLOW LS install: http://67-72chevytrucks.com/vboard/s...55#post6456355 Caliper Rebuild: http://67-72chevytrucks.com/vboard/s...d.php?t=613748 Upper Control Arm Bushings: http://67-72chevytrucks.com/vboard/s...d.php?t=616974 IG mattcrp1 |
01-06-2014, 04:39 PM | #1367 |
Re: Project '86
01-10-2014, 01:24 AM | #1368 |
Re: Project '86
01-10-2014, 01:34 AM | #1369 |
Re: Project '86
Poterbuilt or No Limit rear set up? Or your design?
01-10-2014, 01:48 AM | #1370 |
Re: Project '86
01-10-2014, 01:54 AM | #1371 |
Re: Project '86
Nicely done ...
Also .... the shops got to be better than the old overhang & outdoors!! I've watched for a while. Great progress. |
01-10-2014, 03:10 AM | #1372 |
Re: Project '86
01-10-2014, 03:28 AM | #1373 |
Re: Project '86
That's right ... the overhang was for the doorway into your crib.
KUDOS my friend & great job so far on both. |
01-10-2014, 09:40 AM | #1374 | |
Re: Project '86
01-12-2014, 09:32 PM | #1375 |
Re: Project '86
got the shocks mounted today
