#26 |
Re: Repossessed HUD home renovation
i like those colors... you are making good head way.
#27 |
Thanks!
I got the appliances installed in the kitchen, finished staining the end caps/etc, then cut the trim boards. A few touch ups here and there and they'll be ready for the clear/matte poly finish. I also marked up some of the counter tops that I'll be installing. Granite-look laminate from Menards in stock section. We agreed, real granite is too cold. Plus I can easily replace the counters 10 times for what real granite would cost wholesale, about 15 times retail. I have about $200 into these, not including the bowling alley lane at $160.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
#28 |
Looking very nice ,you will be done in no time .
#29 |
Thanks. It always seems to take way longer than I would like though. Behind schedule! Gotta GO GO GO!
#30 |
Sink hole cut out, miter test fitted, counters trimmed to length. Final few cabinets hung. Some trim boards for those final few cabinets, and glue the counter end caps are probably next.
#31 |
End caps glued/trimmed/filed on counter tops and all screwed down. Sink installed with faucet and disposal (one drain extension yet to buy/install since it wouldn't quite reach). Final semi-gloss clear coat applied. Vacuumed and final swept. Now to finish that island for the final reveal.
#32 |
Looks great ,you do nice work .
#33 |
![]() Join Date: Nov 2004
I REALLY wanted an island (in addition to building cars and stuff I like too cook stuff) but our kitchen just wasn't wide enough.
Looks great so far!
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#34 |
I spent some time last night cross cutting the bowling alley lane and truing up one edge. I had one little piece knock out, but it came out clean and split down the middle, so it was easily glued back into shape and will look totally fine. I got REALLY lucky and didn't hit any major nails on this piece at all.
I was going to trim up the left over piece (about 4' long by 3'7" wide) and make a table for my in-laws, but on the very next cut I hit some 3/16" SPIKES and killed the blade almost instantly even with a triple life carbide tipped blade intended for going through nails... I'm going to buy another blade tonight and try to make their table again with another cut... supposed to be for Christmas for them... Their gift keeps getting smaller with every failed cross cut path through it though. They may just end up with a cutting board LOL! ![]()
#35 |
MOVE OVER
that is going to look great
No matter where you are..... There you are... Buckaroo Banzi |
#36 |
Thanks!
Here's the sink and disposal all done up close. The island is secured/screwed in place and electrical hooked up. Pantry cleaned and installed/partially stocked. Up close on the bowling alley wood. There are several impact marks from storage that I will have to steam out once the wood is fully braced and glued (there's a slight bow to it now, less than an eighth of an inch). Then I can attach trim and pour the resin top.
#37 |
Forgot to include all of the recycled base trim. Probably a couple thousand nails I had to cut off. I got tired of cutting them by hand, so I started using my cutoff wheel on the grinder and it went MUCH easier.
#38 |
That bowling alley top looks great as well as the rest of the kitchen . When do you plan to move in.
#39 | |
I got the bowling alley all braced and glued last night and reset the metal angle bracket braces that I had temporarily attached when I first put it on. After it dries a full 24 hours I'll remove the pipe clamps and start the edge trim. That won't be for a little while though since I have to do the base molding first. Then there's mounting the TV (locating 3 jacks, wall mount, etc) and of course painting the granddaughter's bedroom (she's due the 3rd, we can hardly wait!).
#40 |
Congrats on the move in and you will finish quickly now .
#41 |
Wax removed (about a quart of mineral spirits and a couple old T-shirts), trim installed and stained, and resin applied. Unfortunately there were a few leaks between the boards on the alley floor that leaked resin and caused some wrinkles (resin partially dried on top, but soft underside kept leaking causing the surface to slightly collapse and wrinkle). I will have to sand and reapply. It's going to look great though.
#42 |
Last picture.
#43 |
Very nice ,you did a great job.
