#8451 |
Re: What did you do to your truck today!
#8452 |
![]() Join Date: Sep 2008
@magwaa...how did you wire that alternater..cant get my to work....im mean what you wire that little wire to...thanks..oletimer
#8453 | |
Thank you Sir ! . I have a good idea how much better it'll be , I'd rather die than have one more year of this I have now .
Congrats on your Daughter ! my Son just gave me my first Grand Daughter , I am well pleased . -Nate Quote:
-Nate Geezer '49 3100 235 W/ Muncie SM420 SOLD '69 C/10 shortbed sidemount survivor 250 L6 W/ 350TH ![]() |
#8454 | |
RAT1968 '68 Cab/'71 Parts
On mine, using this internally regulated alternator, the one brown wire that comes off of the alternator plug runs into a connector that holds the blue and white wires, which in turn connect to what would normally be the blue and white terminals voltage regulator. As per M & H, the guys whose wiring set-up I have, on this alternator, the white wire that would otherwise connect to the single brown wire connector coming out of the alternator is not "used" and, therefore, "deadheads", or does not connect in that connector. Also, and because of this style alternator, of course you know that this set-up does not use use a voltage regulator.... Check this thread where a lot of our Forum pros helped me out: http://67-72chevytrucks.com/vboard/s...d.php?t=604860
M17 Coarsegold, CA RAT's shiny now. But always a rat. |
#8455 |
ok...thanks I have the same alternater...I put all the set up from a 94 c1500 on mine with the American autowire harness...I guess I have to read up on it...thanks for the link...oletimer
#8456 |
![]() Join Date: Apr 2013
If I see a Zombie.. Im runnin it over with my Truck. |
#8457 | |
terminal where the voltage regulator used to be. If it's the same set-up as mine, it should work just right. Thanks to the guys on that thread and info from a call to M & H.
#8458 |
installed headers for the last time, bent a few brake lines, installed GMPP intake manifold.
[IMG] ![]() ![]()
SOLD -77 CHEYENNE SWB, LS SWAPPED -1976 SILVERADO YUBA GOLD/NEUTRAL (2-TONE) |
#8459 |
![]() Join Date: Jul 2013
Bought some parts from tlcrz1972 (Brain) today.
nice full-foam seat with tracks full "low" tranny hump patch panels for both doors both chrome wing vents. Great prices and great conversation. It sure is nice having a addict like me local. ![]()
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#8460 |
![]() Join Date: May 2012
#8461 |
Thanks, its been a fun ride........and close to taking it for its first ride.
#8462 |
I installed my new glovebox liner. And worked on the RH side window, it would not roll down - it was all rusted up. And once it was all WD40'd up, I found out that the window regulator is worn out and now the window won't stay up when I shut the door or when I hit a bump while going down the road. Bummer!!
#8463 |
Welded inpatienly a couple weeks ago... warped the firewall a tiny bit, got. It fixed!!
![]() Replaced the rusted piece above rear window, now waiting for (my new best friend) OSPHO to dry on the outside/inside inner/outer roof! The cold weather doesnt help! And built an air compressor enclosure...finally!! Now I can work later in the day, and when neighbors are out!! ![]() ![]() |
#8464 |
Be sure and vent it.....heat will kill it sooner
#8465 |
Good thinking! Pm sent!
#8466 |
Went from buckets "back" to bench. The "Boss" wanted to put in the bench seat we got (and have had stashed) since I started the build five years ago.
These buckets will probably be available free ('04 blazer...electric/leather 9.25 out of ten 10) for a Forum Member to pick up. But I first have to ask my pal that gave them to me.
#8467 |
I made a fan shroud, for my Volvo fan upgrade....
![]() Volvo '870', 2-speed fan... ![]() $20 worth of steel... ![]() Took a trip to my buddy's house, with the plasma cutter... Because cutting holes without plasma just SUCKS.. ![]() Perfect... Only took about 10 minutes, 6 of which were spent making the jig. ![]() Made a frame... ![]() Tacked together... ![]() Welded up... ![]() ![]()
'70/C10/402/TH400. |
#8468 | |
1970 C10 Short Stepper with 71/72 front clip. |
#8469 |
#8470 |
His wife.... Reading comprehension, c'mon.
#8471 |
Been married 41 years +.
Over the years, I've had the temptation of trying "new things". But I've always contained the responses to those urges to the inside of the automotive realm. ![]() ![]() ![]() ![]() Besides, she bought this seat, suggested we try the seat, and loves the way it looks. Last week, I did a "heavy-hand" and broke the cheap-o center console. I searched for a new one....A hundred for this one, $159 for this one, $350 for another.... This morning, in order to dig out the Christmas decorations, I had to move the bench seat that I plasti-wrapped almost five years ago. One thing lead to another.
#8472 |
![]() Join Date: Jan 2010
Went to the Indy swap meet and picked up my '68 front fenders,2 core supports,door panels and trim,gas pedal,radio delete cowl panel and two '67 hub caps from Todd68chevy,and also bought a new pair of QA1 coil overs and some new 4link brackets for my build.
#8473 |
#8474 |
Boys,
Speaking as a person who *does* have **** for brains, I did not consider that a slam.... ![]() ![]() Also, I *do* dig my new seat. Sort'a "traditional"...sort'a.
M17 Coarsegold, CA RAT's shiny now. But always a rat. Last edited by magwakeenercew2jh; 12-01-2013 at 11:16 PM. |
#8475 |
Hey, everyone likes what they like right, if nobody likes my truck I don't care because I like it, I may not like yours but do say that I try to appreciate "all" builds, mine are way different than they were when I was a kid.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
