Old 10-16-2013, 03:00 PM   #901
OrrieG
OrrieG's Avatar
Re: Lurker OrrieG Progress Pics
Originally Posted by mvitale27 View Post
Thanks man! That was just what I was looking for.
Just to clarify the photo attached shows the factory big hole I used with a 3/4" fine thread G8 bolt with self locking nut and big plate for a washer. The small hole next to it is a 3/8" G8 fine thread with self locking nut and washer. Here is another pic of the trann/transfer mount I found too.
Old 10-17-2013, 10:31 AM   #902
mvitale27
mvitale27's Avatar
Thanks. It is very kind of you to provide this information. I am already loving this forum and my truck is scheduled to be delivered this Saturday!
1956 Chevy 3600
Matt's 3/4T 4X4 Build
mvitale27 is offline   Reply With Quote
Old 10-20-2013, 10:00 PM   #903
OrrieG
OrrieG's Avatar
Good weekend. Cleaned up the shop some. Ordered 9w led back up lights and revised the circuit so I can turn them on without putting the truck in reverse. Got my door switches for the courtesy lights and installed them, thanks to Orge for sharing his hidden switch idea using the upper hinge. It is a simple two bend bracket that is attached to the upper back hinge bolt. Threaded it to match the switch for adjustment. Got misc. electrical parts so I can finish the front and back light wiring. Also scored some 69-72 4wd front hub caps so I do not have to cut up the 2wd ones.
Old 10-20-2013, 11:46 PM   #904
oldman3
oldman3's Avatar
Nice ideal with the hidden switch (Orge)...Jim
oldman3 is offline   Reply With Quote
Old 10-31-2013, 12:37 AM   #905
OrrieG
OrrieG's Avatar
Here is the modification to the ac vent. It came out of an 09 Mustang, about 2 7/8" OD. AC hose is 2.5" ID. It was also too long for the hose to bend without crimping. It is abs, so I cut it down and used a sewer coupling and piece of pipe as a reducer. Both required taking out about 1/4" to reduce the diameter. Bottom is stock, top modified.
Still fighting getting the correct lamp sockets for the courtesty lights. NAPA is on try two, will be here in a week or so. If its a direct replacement will post the number for all to use. Also got my taillight leds but they sent 1156 single filament instead of 1157 dual advertised to have to wait on that too.
Old 10-31-2013, 01:45 PM   #906
_Ogre
_Ogre's Avatar
who's this orge guy with all these cool ideas?
shop air compressor timer
Old 10-31-2013, 02:29 PM   #907
oldman3
oldman3's Avatar
I got the spelling from above post, sorry it was wrong. I also notice you have posted that the fiberglass forum is back up. I looked at this alot, until it told me I couldn't sign on. Will give it a try again...Jim
Old 10-31-2013, 05:06 PM   #908
OrrieG
OrrieG's Avatar
Sorry for the misspelling...
Old 12-04-2013, 08:33 AM   #909
msilva12
OrrieG what year and make did you use the park brake pedal mechanism from?
I love the thread great job. I been down and sick for a couple of days and just read the entire thread. I cant wait to get going on mine!
msilva12 is offline   Reply With Quote
Old 12-04-2013, 08:51 PM   #910
OrrieG
OrrieG's Avatar
74 K10 truck. C and K series 10-30 from 73-80 something are all the same. Thanks for taking a look and the compliment.
Old 01-17-2014, 12:22 PM   #911
Sam03
Sam03's Avatar
Great build! Keep the updates come!
1st Series 55 Chevy Pickup
235 4 speed
Sam03 is offline   Reply With Quote
Old 01-17-2014, 07:17 PM   #912
OrrieG
OrrieG's Avatar
Accumulating parts for a big push when temps get better. Just about everything left needs warmer weather to accomplish.
Old 01-24-2014, 06:59 PM   #913
OrrieG
OrrieG's Avatar
This is out of sequence but tired of looking for it and realizing I did not post. Around post 815 I was doing the cab wiring. here is a photo of the back of my cluster before I put it in. I wanted to show the trailer light connector I used and the new lamp holder, available off the rack at O'riellys. The upper lights are a separate harness directly from the light switch. Ammeter wired directly, oil pressure is mechanical fitting.
Old 01-24-2014, 08:51 PM   #914
oldman3
oldman3's Avatar
Looks nice and neat, plug in makes it nice, if it has to come out....Jim
Old 03-10-2014, 12:56 AM   #915
OrrieG
OrrieG's Avatar
Good weekend. Got the hose routed from the wiper fluid tank to inside the cab, need to get a tee and some smaller line for the wiper bezels. Dropped in a battery and started checking circuits. Got a scare when I first connected the battery some of the AC relays activated, need to check the circuit to see if they were just setting or if they are drawing power all the time.
All of the stuff I have hooked up works except for the 4wd indicator on the transfer case (the switch is good, think I have a bad connection in the circuit) and an over-ride switch I wired into the courtesy relay is not working.
Here are photos of the instrument lights and high beam indicator, courtesy lights (each door operates both lights in the kick panel using a relay), dome light, and the ac and back wiring of the kick panels as I installed them. Got them installed too.
I had to take out the light switch and do some work on it. Initially the dome and instruments did not work. The switch was working when I removed it 15 years ago but sitting around it got dirty. A little sand paper for the dome ground and it started working. The instrument circuit is working but might be developing an internal break. Everything is ok on the outside of the switch, including the reostat, I am hoping one it gets used regulary it will be ok. If not its easy enough to replace.
Engine turns over so next I am going to check the fluids and start it up to check for leaks before I start putting on any more front sheet metal.
All the pics except the back of the kick panel were taken with any light in the cab or the camera flash on. Pretty bright.
Old 03-10-2014, 01:08 AM   #916
Flames97
Flames97's Avatar
Cool build. I've checked it out many times before and enjoy it.
-Aaron
'15.5 Chevy Duramax LTZ/Z71, LML, CC/SB
'77 Chevy K10, 4" lift, 33-12.50, 350/350
'55 Chevy Short Box (In Pieces)MII,4-link,Bagged,383 Stroker,700r4,3.73posi (SOLD)
My 55.2 Chevy 3100 Build
Flames97 is offline   Reply With Quote
Old 03-10-2014, 10:23 AM   #917
Kim57
Kim57's Avatar
Coming along real nicely.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 03-10-2014, 10:32 AM   #918
oldman3
oldman3's Avatar
Feels good to have things working and getting them off the "to do list"...Jim
Old 03-10-2014, 09:31 PM   #919
OrrieG
OrrieG's Avatar
Thanks guys. I checked the front and back lighting circuits, no lights just the connector ends, everything worked as is should. Also remembered that the "faulty" courtesy light override is not that, it is the back up light switch, I have it set up so the reverse column switch or dash switch with turn on the back up light(s). Going to get an 4" aircraft landing light (off road guys love them) to use back there so I can flash the tailgaters and high beam runners...
Old 03-14-2014, 01:58 PM   #920
OrrieG
OrrieG's Avatar
Fixed the 4wd "in" light, I had the LED wired in backwards, which should have been a duh because diode by definition allow current to flow one way (red wire in, black out to ground for LED). All wiring is checked and good EXCEPT the HEI which I have faith in.
Old 03-15-2014, 04:47 PM   #921
focusedontheprize
focusedontheprize's Avatar
@OrrieG
Is your dome light as stock setup or did you do the LED modification?
focusedontheprize is offline   Reply With Quote
Old 03-15-2014, 10:01 PM   #922
OrrieG
OrrieG's Avatar
Stock, decided to see how it looked, plenty bright for me. I will take a pic with it on, but not pointing at it.
Tried to start the truck today but having starter issues. It came with two starters, but the PO of the donor (daughter) had been having issues. former hubby had ground down the teeth on the starter and flywheel. I replace the flywheel but grabbed the wrong starter (shiney newer one but with ground down teeth). I pulled it and replaced with other (bench tested it to make sure solenoid was engaging and it spins) but it engages but will not turn the engine. I can turn the engine with a 9/16" wrench on the flywheel bolts so that is not the issue. Reading think it is shimming, will tackle it tomorrow.
Old 03-18-2014, 01:39 PM   #923
OrrieG
OrrieG's Avatar
After trying two starters got it to start once. It ran for about 30 seconds until the carb bowl went dry. Good news is no PS, radiator or tranny line leaks. Bad news is dispite another two hours of shimming, etc. could not get the starter to engage again, think the bendix is bad. Other starter was a newer NAPA but the teeth were ground down. I took it to NAPA and found it had a life time warranty so walked out with a new replacement.
Old 03-18-2014, 05:50 PM   #924
6BT 56
6BT 56's Avatar
Its been a while since you have seen the old girl make smoke i bet ! Must have felt good. Even if it was a bit short lived . Nice job on the electrical ! Looks great .
56 gmc 4X4 Cummins 5 spd 60F 70R
2005 Ram 3500 DRW cummins 4X4.
2006 Conolift 9/15. 2011 F 350 winter beater
New 2018 ram 3500 drw 4x4. Makes my 2005 Look as if it's been running on 4 cyl since new !
My Build http://67-72chevytrucks.com/vboard/s...d.php?t=556908
6BT 56 is offline   Reply With Quote
Old 03-18-2014, 08:17 PM   #925
OrrieG
OrrieG's Avatar
Yeah, big milestone for me, its been off the road 15 years or so.
