Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 11-21-2013, 08:14 PM   #1
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Do you have a Crushed, Accidented, Dinged , Dented 63 grill
Looking for the two supports 1.266. These attach the grill to the panel assembly. Need the left and right side. Please.
Old 11-21-2013, 11:33 PM   #2
DPowers
One foot in front of the other
DPowers's Avatar
Re: Do you have a Crushed, Accidented, Dinged , Dented 63 grill
are 63 different than 64-66?
DPowers is offline   Reply With Quote
Old 11-22-2013, 12:00 AM   #3
Budman56
Budman56's Avatar
I have a whole dented up 63 aluminum grille I will let you have for $100. if interested let me know I will send you photos.
MY 65 C20 BUILD
http://67-72chevytrucks.com/vboard/s...d.php?t=483346
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
Budman56 is offline   Reply With Quote
Old 11-26-2013, 08:58 PM   #4
aerotruk63
aerotruk63's Avatar
Since the grill support changed from 63 to 64, I'm assuming the supports changed as well.
Old 11-27-2013, 11:26 PM   #5
DPowers
DPowers's Avatar
Cant help you then- sorry.
Old 11-27-2013, 11:50 PM   #6
GMCNUT
GMCNUT's Avatar
I may have a steel 63 grille you can get for 50-75 dollars or so - let me look to see if it has the mounting brackets first...will PM if so
My Projects and Toys - All 100% Stock
1972 CST "Highlander" Blazer - 350 auto, PS, PB, A/C, Tilt, Tach, AM/FM & Positraction
1966 Chevy SWB Fleetside BBW Custom Cab, #'s matching 327 V8 & Powerglide, factory deluxe heat, PS, PB, Tinted Glass, sway bar
1961 Chevy SWB Fleetside BBW Custom Cab #'s matching 283 V8 & Powerglide w/ uber-rare Cool-Pack A/C, factory PB, deluxe heat, Clock
1961 GMC K1000 4x4 SWB w/ BBW, Custom Cab and numbers matching 305D V6 engine & 4 spd
1960 GMC SWB Fleetside BBW Custom Cab #'s matching 305A V6 & Hydramatic, factory PB, Clock, Tach, Compass, Hood Jet
1959 Chevy SWB Fleetside BBW Custom Cab w/ rare stainless bed trim, #'s matching 283 V8 & Hydramatic, Deluxe Heat, radio, spotlight
1958 Chevy Cameo #'s matching 283 V8 & Hydramatic, radio, window washers, Factory PB
1958 GMC BBW SWB Fleetside Custom Cab, #'s matching 336 V8 Hydramatic, Factory PS, PB, Clock, RSD, Deluxe Heat & Hood Jet
1957 GMC Suburban Pickup (GMC's Cameo) #'s matching 347 V8 Hydramatic, uber-rare vacuum ashtray, Factory PS, PB, Clock, RSD, Hood Jet
1956 Chevy 3800 1 ton w/ rare 9 ft stepside bed, factory 265 V8 w/ Hydramatic, factory PB, Custom Cab, deluxe heat, spotlight and hood jet.
GMCNUT is offline   Reply With Quote
Old 12-02-2013, 02:08 PM   #7
b.sharp
b.sharp's Avatar
I have asked Rene (c-10 king) this question and says he never has to change the light mounts to add '63 grills to his trucks. He says they all line up, just the grill itself is deifferent. Just to let you know, you might want to try it first.
b.sharp is offline   Reply With Quote
Old 12-04-2013, 05:30 PM   #8
aerotruk63
aerotruk63's Avatar
Well stopped in Gladstone Michigan on the way back, this guys son has a 63 and they have a dozen or so different years parts trucks. He had two sets of supports already removed from the 63 grill face. Got a left and right support.
Life is sometimes good.
Thanks to all who tried to help.
