Old 10-11-2011, 10:09 AM   #51
bustac
bustac's Avatar
Re: Electric Wiper Conversion on the cheap
What did you guys end up using for a wiper switch?
1947 5 Window bagged S-15 frame
5.3 w/4L80E
1960 Apache LS Swap
5.3 w/4L80E
bustac is offline   Reply With Quote
Old 10-11-2011, 10:21 AM   #52
1952ssr
1952ssr's Avatar
I used my S10 column controls.
1952ssr is offline   Reply With Quote
Old 10-11-2011, 06:48 PM   #53
mknittle
mknittle's Avatar
I am going to make a linkage for my stock switch on top of the dash. it shouldn't be too hard I am using a dp/dt toggle switch on my 42 willys jeep. I am sort of funny that way. I am also going to make a linkage so the foot starter pedal works for my 400 pontiac.
Mark
My GMC build.
http://67-72chevytrucks.com/vboard/s...d.php?t=536602
mknittle is offline   Reply With Quote
Old 10-11-2011, 09:04 PM   #54
Thadious
2 speed intermittent from a late 80's F**d F150. Dash mount, but needed to put in a bigger capacitor.
'51 Chevy Build - In the design stages
Aut viam inveniam aut faciam - I will either find a way or make one.
If you don't have time to do it right the first time, when will you...
My new build - https://67-72chevytrucks.com/vboard/...70#post8958970
Thadious is online now   Reply With Quote
Old 12-29-2011, 06:45 PM   #55
dirt53
I used the motor from the donor truck and mounted it under the dash and used all the linkage and wiper assembly . I mounted the passenger wiper in the original wiper hole which was 16 inches from the center of the windshield ,then cut a hole and mounted the drivers wiper 16 inches from the outer edge of the window. This will have the wiper parked faceing to the drivers side , then with the motor mounted where it worked good for me I started with the linkage from the passenger wiper and cut it in half and then made adjustable by welding a piece of treaded rod to 1 end of the linkage and a nut to the other piece of linkage . Then with the motor in the parked position I put the wiper in its parked position and adjusted the linkage to fit ,then after that with the other linkage made adjustable i set the drivers wiper in its parked position and adjusted that linkage to fit. The swipe is good and adjustable on those linkages , sorry but i have figured out how to post pictures of it lol.
dirt53 is offline   Reply With Quote
Old 12-30-2011, 10:10 AM   #56
1952ssr
1952ssr's Avatar
I got to try mine out the week before Christmas with a short trip to ACE for a trailer wiring kit. I really didn't want to drive it in the rain but, it wasn't raining hard and my other truck was hooked up to our trailer. They did really good so I'm pleased with my contraption I built and I won't be scared if I do get caught in a rain storm in the future.
Old 12-30-2011, 12:38 PM   #57
Chevette
Chevette's Avatar
Actually, the cheap way is to blank out your wipers completely, buy a case of "Rain-Ex" and try resist the temptation to drive the truck you spent so much time and money on when it's raining. That's what I'm going to do. Added bonus: Truck doesn't require washing as often.
Chevette is offline   Reply With Quote
Old 12-04-2012, 02:23 PM   #58
_Ogre
_Ogre's Avatar
good diy info in this thread
i like this vs the $200 kits
shop air compressor timer
Old 12-05-2012, 12:55 PM   #59
mknittle
mknittle's Avatar
I got a fix it ticket for no wipers on my 56 210 it has summer and it never rains here in summer.I had the wipers but had them off to fix a cable. and got pulled over. when i went to get the ticket wrote off the cop liked the car so much he forgot to check if the wipers worked
Mark
My GMC build.
Old 05-19-2013, 07:03 AM   #60
johns truck
You guys rock. just getting to this point but been wondering about this since I bought the truck 3 years ago. AWSOME WRITE UP!
johns truck is offline   Reply With Quote
Old 11-26-2013, 02:03 PM   #61
sqrlnts
I just wanted to share this link. Its a 12 volt DC wiper motor with switch for $30. I have not ordered yet as I still need the transmission arms. Additional details are available under the more specs tab on the linked page.
Specs on this motor.
12 VDC WIPER MOTOR WITH 3-WAY ROCKER SWITCH AND REVERSE PARK
New, MARINCO model MRV 38001-02R right angle two speed wiper motor with reversing geartrain to give back and forth sweeping motion. Factory pre-set sweep of 110°, adjustable to 45°, 60°, 80° and 110°. Additional features include, reverse park, corrosion-resistant case, two-speed motor, brass plated steel shaft, heavy-duty motor with right angle gear drive and 3-way rocker switch. Shaft length listed is length of mounting shaft and knurled wiper arm mount.
SPECIFICATIONS
Voltage 12 DC
Amperage No Load 0.5 to 1.2 amps
Amperage Stall 11.5 to 13 amps
Stall Torque 109 in. lbs.
Rotation Sweep 45°, 60°, 80° & 110°
Speed:
Slow: 32-40 sweeps per min.
Fast: 52-60 sweeps per min.
Duty Continuous
Mounting Shaft 5/8" dia. threaded
Shaft Length 1-1/2"
Knurled Wiper Arm Mount 1/2" dia. x 1/2" long
Size 7-5/8" x 4" x 2-1/2"
Shpg. 4 lbs.
sqrlnts is offline   Reply With Quote
Old 11-26-2013, 10:32 PM   #62
solidaxel
solidaxel's Avatar
SPECIFICATIONS
Voltage 12 DC
Speed:
Duty Continuous
Shaft Length 1-1/2"
Shpg. 4 lbs.
I sent away for one,
I have this on my to do list, glad it does not rain down here very often, as I have been putting this off for 7 years !!
I hope there is instructions on how to set the sweep
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 11-27-2013, 04:30 PM   #63
1adam12
1adam12's Avatar
Let me know how those work out im about to pull the trigger and get one for myself....
1adam12 is offline   Reply With Quote
Old 11-27-2013, 09:42 PM   #64
sqrlnts
I would be interested as well. I just wish I would have done this before I installed the AC evap unit....
Old 11-28-2013, 12:03 AM   #65
solidaxel
solidaxel's Avatar
.................. Thanks for reminding me !!
LS 3 4L70E
Old 11-28-2013, 08:18 PM   #66
chip46wis
The comment---This reminds me of hot rodding in the 50s is SO correct---I adapt and improvise everything possible due to my nature---This is great and I thank you guys for sharing this with us!!!!!!!
chip46wis is offline   Reply With Quote
Old 11-29-2013, 10:03 AM   #67
tbrown5079
Good timing. I hope someone posts the install on the Marinco wiper.
tbrown
tbrown's 56 Cameo Build
tbrown5079 is offline   Reply With Quote
Old 11-29-2013, 10:38 PM   #68
1adam12
1adam12's Avatar
I got one out of a 98 blazer rear wiper motor but there is a bunch of wiring does anybody know which wires I need to use??
Old 11-30-2013, 08:12 AM   #69
msaintg
msaintg's Avatar
try this
msaintg is offline   Reply With Quote
Old 12-10-2013, 12:12 AM   #70
solidaxel
solidaxel's Avatar
Well I had some time today so I opened the box with the wiper motor, and right away I have a question !!
I just went back and looked at the description of the motor and my questions were answered?
TOP LINE ............ROCKER SWITCH!!!!
If you all order one of these motors, I suggest you ask them for a motor that has three spade connections for,
1 fast
2 slow
3 park
The one I have in my hand (as advertised) has rocker switch, and in order to make this thing work you will need access to the ROCKER SWITCH, which of course will be up under the dash !!!
Sure with a little bit of hot rod engineering and more time you will be able to solder three wires and fill in the hole where the rocker switch is mounted and bring them to a remote 3 way switch.
and the shipping and handling was 11 bux !
Good Luck with your decision
LS 3 4L70E
Old 12-10-2013, 09:57 AM   #71
72Mountaineer
72Mountaineer's Avatar
Originally Posted by msaintg View Post
try this
Is this diagram used with a dash switch or a column stalk?
72Mountaineer is offline   Reply With Quote
Old 12-10-2013, 10:28 AM   #72
tbrown5079
Just got all my old wiper parts out on Saturday and realized I have 2 sets, both in usable condition. Not a hard thing to install once you get positioned on the cab floor. Got on the "net" and found some sites for rebuilding vacumm motors, then took one apart, cleaned and ready to go back together.
If they work reasonably well I'm going to do like "Chevette" says and buy a case of RainX and drive it. I have enough projects to work on.
tbrown
Old 01-20-2016, 02:29 PM   #73
lower50's
lower50's's Avatar
Great write up. I know its old didn't want to loose it.
http://67-72chevytrucks.com/vboard/s...d.php?t=648459
https://67-72chevytrucks.com/vboard/...d.php?t=769441
1951 MG TD
1967 Jeep CJ5 1.9L TDI 33X13.5X15 Mud Grapplers.
1952 GMC 9700 p/u 7.3L diesel on air, dually
lower50's is offline   Reply With Quote
Old 01-20-2016, 09:38 PM   #74
chevyguyase
I also used a '93 S10 Blazer rear motor. I used the pivot off of the vacuum wiper motor, shortened the shaft and snout of the electric motor. I also used the washer nozzles, switch and washer bottle and pump off of the s10. I mounted the nozzle on the wiper arm like the new cars have. It all worked out great. After doing all that I found a wiper motor at a garage sale that has two speeds, parks, the angle of pivot is adjustable, and is more compact. I gave him the $5.00 he was asking for it and asked him what it came off of. He said they use them on boats. I have yet to put it on the truck but I think it's going to work better than the S10 set up. You might want to check out boat wiper systems. I wish I would have thought of it sooner. I'll try to send a picture in another post.
chevyguyase is offline   Reply With Quote
Old 01-20-2016, 11:36 PM   #75
chevyguyase
Size:  44.8 KB This is the picture of the boat wiper motor. it is 2 speed and as you can see, it has different holes you can select on the wiper crank arm and under the lock washer you will see a slotted mount for changing the ark of the wiper. The unit is about 1" longer than a dollar bill and 4 1/2" deep, not counting the post for mounting the wiper arm. The mechanism converts rotary motion to ark motion in very a small unit. A clever guy could just duplicate the mechanism, but like I said I bought this one for $5.00 at a garage sale. I haven't tried it yet but I'll be replacing my Blazer unit with this one.
electric wipers
