![]() Join Date: Jan 2013
Location: 3,018 feet above the SoCal/Mojave Desert region.
1969 GMC headlight conversion and wiring questions.
Are the headlights 5 3/4" or 7"??
I don't have the truck with me right now, but I'm looking to buy a pair of low beams conversion where all I have to replace is just the bulb and not the whole unit. Also, can I use the stock wiring or will I need to buy an adapter to work with the new headlights?? I made calls to after market places, but can't get a straight answer. Thanks. ![]() |
Re: 1969 GMC headlight conversion and wiring questions.
Cibie H4 & H1 headlamps • 5.75” round for the low and hi. These have a H4 for the low and H1 for the hi beam. Note with this light upgrade I recommend the head lamp relay wire upgrade is installed in the truck. link http://www.madelectrical.com/catalog/rly-1.shtml
here is a link http://www.danielsternlighting.com/p.../products.html Or the seal beams from http://www.sylvania.com/en-us/applic...n.aspx#fldYear
Trueman |
#3 | |
![]() Join Date: Apr 2010
John Paap Ole Greenie Hagerstown, MD My Mistress 70 CST Short/Step LS 5.3/4L65E New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773 |
Future TOTM Winner
"We" as in chevy owners have 7" lights but desert-rat has a GMC emblem under his name with tells me he has 4 head lights. They are not 7", they are smaller. I don't know the exact dimension but 5.75" sounds about right. I'm sure a GMC guy will chime in here in a second.
72 Chevy CST K5 HIGHLANDER BLAZER Getting a 6.0,NV4500,NP205,14BFF (Currently laying all over the place in little pieces) 72 Chevy swb step-side "LS" 6.0 Here's a build thread of sorts 2002 HD2500 Crew Cab, 8.1L Allison 4x4 Daily Driver Check it out www.lsdyno.com |
Chev is 7" lights (2 headlamps) GMC is a 5.75” light (4 headlamps) setup.
Trueman |
So buying the head lamp relay wire upgrade will come with everything that I need to get the headlight conversion to work??
In most cases the kit is complete , you may want to move or relocate to you liking and that may require more wire. you need 2kits hi and low.
Trueman Last edited by 463; 12-09-2013 at 09:56 PM. |
So all and all, this is a pretty straight forward install??
Yes! It's one of the top five upgrades for my money.
Trueman |
LMC Truck has your harness already made with both high and low beam relays $29.99+ shipping.
part -36-3581 http://www.lmctruck.com/icatalog/cb/full.aspx?Page=76 |
#11 | |
