#26 |
Re: Your best junkyard find
We have a winner!!! Awesome score! Those pickups are made for hemi motors!
#27 |
78K & 79C Jimmys
Barn find pushbar ,lol,and a truck ,found in the barn....with his hobby engine
truck was his sons and son was buying parts for it older retired guy was really cool,gave me part of a F*&D grill,looks like a boomerang lol
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
#28 |
Clean rust free 89 cab, 4 doors and core support and door panels.$150
#29 |
One of my better junkyard finds, I went just to look around one day and found a mint dashboard for my 1983 Malibu just sitting bare in the back of an EL Camino. I grabbed that fast and paid $20 for it. Original uncracked ones go for over $200 if you can find one. Another time at the same yard I scored a clean tach dash from an El Camino for $20 as well. sold that one for $100.
Best truck score so far was the mint C60 tach dash I got from a guy parting one out in my town. Best part is the tach works great! Paid $30 for it. ![]() |
#30 |
I've been looking for a 1973 C20 454 grill for some time now, can't find one at our local junkyards here in Phoenix! Any one got one?
#31 | |
The spot where the fuel gauge is in your picture is where my "Fasten Seat Belts/CHOKE" lights are currently. I'd love to find one of these and put my original gauge cluster back in with this addition!
1980 Chevy K10 Silverado --> Build Page My wife told me I spent too much time on Facebook. So I bought an old truck. Now she wishes I was on Facebook, it was cheaper. ![]() |
#32 |
I've had a few of the big series tach clusters.....they require NO re-pinning. They literally are a plug n play cluster.
#33 |
Yes the main plug requires no re-pinning to work. I dropped in my original C10 speedo into the cluster housing and installed it. The tach has a separate harness for power, ground and tach signal. Real easy
#34 |
I know how the tach is wired, I was referring to the fuel gauge wiring. So if I understand you, you put the C60 cluster in your truck and just swapped out the speedo? What I would want to do is swap my fuel gauge for the tach/fuel combo gauge, which isn't a direct matchup with the circuit board I have.
#35 |
Here's what I did-using my existing unmodified cluster plug-in on my 78 K20 I had at the time which had gauges and a brake light indicator, I dropped in a 79 C60 tach cluster and instead of using a BRAKE indicator where the vacuum gauge was which is independant of the C60 printed circuit, I installed a factory clock in its place. So I ended up with a factory clock and a complete, working C60 tach cluster. No repinning was required.....I just plugged in my existing instrument cluster plug-in and it all worked. Since you have electric gauges being an 80, you can use any C60 tach cluster from 77?78 and up. I'm not sure what year the big trucks went from mech. to electric oil pressure. Usually, 60 psi is electric, 80 psi is mechanical. Hope this helps more than confuses....lol.
#36 |
My C60 cluster was from an 85, and it had an electric 80 PSI gauge, which I later swapped in, since my 60psi gauge went kaput. works perfect.
Best way to do this swap is to use the big truck cluster housing, since the fuel gauge pins are lower, plus the cutout for the tach terminals. |
#37 |
One of my best junkyard finds is a LT1 Camaro T56 6 speed I found at Pic-A-Part and paid $183 total. Sold on CL a week later for $1050.
![]() 73-80 GMC Tailgate trim. ![]() Almost new Holley carb. ![]() Tach Cluster ![]() 73-74 GMC/Chevrolet 454 Grille emblem ![]() Nardi Steering wheel ![]() Guess I should stop.. lol OK One more. Dual Air Pressure gauge sold to a forum member. ![]()
#38 |
#39 |
150? these trucks are made to hardly do half that lol. unless thats kph
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
#40 |
I wondered that but the temp gauge is in Fahrenheit...unless they all were. I would assume those would be Celsius.
Trevor 74 C20...work in progress. 04 Saturn Ion...Daily Driver |
#41 |
Slots go on anything!
They are 70's Camaro gauges (tach/speedo). I dig the look of them.
1974 Jimmy- 5.3/4L80e/NP241 |
#42 |
In particular its a 70-73 Z28 cluster since the 150-mph Speedo and RPM redline is 7K. Big block equipped rare 396 70-73's also got the 7K tach. All others got a 6K redline and a 130 mph Speedo. So, its a pretty scarce cluster in its own right.
#43 |
Scored LH and RH Bumper Guards for $20.00 at local yard. LMC wants $149.95 for just the LH. Guess the RH is discontinued. They will work on mine with slight modification to the attach bolt's. The contour is right on just needs a large washer in back so the nuts wont suck through.
#44 |
Installed my bumper guards today. What do you think ??
#45 |
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
#46 |
Jeff Shaw 2003 Chevy 2500HD LB7 Duramax ![]() |
#47 |
Looks good!
70 stepside 76 blazer 86 Silverado 20 Max Trailering 6.2 Crew 71 Nova SS My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634 |
#48 |
![]() Join Date: Aug 2010
Resurrecting a thread that’s older than dirt. But not nearly as old as these junkyard finds! Saw these two in a local yard yesterday.
Jeff 1972 Blazer CST 2wd- My son Sam's Project "S" Project "S" 1970 Suburban - SOLD "One Bad Burb" Photobucket Album 1986 C30 Crewcab - 63K original miles, original paint Members I have met: mikey531, gcburdic, bashed, burbman69, TonyPieras, Blazester, GCncsuHD, custombuilt67-72, tsnow678, highrpm, PanelDeland, tanman722001, 47thriftmaster, babyblueoval, 68stepbed, JesseWebb, Andy4639, xs-style, TobyArnot, BigOrange, frednoah, brn_agn, k5hart, Graham57a, bhelton, AJohn6, SilverC10, 69CST, '71 Flame, RaceAGMC, Liz, Josh, MattPSU, 68corvair, Chevy350V8, mdeal, ccrorymc, mrhurt73, dmxxpert, Custom68, 84GMC, BionicABs1, BigBlockBurris, Ebfabman, ATP... |
#49 |
![]() Join Date: Oct 2014
I go quite often to the junkyards. This was probably one of my best finds. I went to pick up a seat from a local yard. They drove me out to the truck, to let me see it to make sure I wanted it, before they pulled it. So while I was standing there waiting for the guy to get the seat pulled, I look in the bed of the truck, and all these were just laying there in the bed of the truck.
And here's the seat. It had been recovered in Black Leather, it was just dirty. I took the cover off and sandblasted the frame & repainted it, like I do all my seat rebuilds. Put the cover back on and I got myself a beautiful seat.
FB Page for my Seats Belts https://www.facebook.com/73-87-Chevy...9439407476735/ Restoring Seatbelts: http://67-72chevytrucks.com/vboard/s...d.php?t=809750 SOLD My 86 Build:http://67-72chevytrucks.com/vboard/s...d.php?t=654972 Past Restored Bench Seats:http://67-72chevytrucks.com/vboard/s...d.php?t=715398 PayPal link to pay for your items: https://www.paypal.me/TKCR |
#50 |
Just a random junkyard pickin pic from a couple years ago...
