12-06-2013, 06:59 PM | #501 | |
67-72 parts collector,…
Re: Crusty Rusty Leaky Squeaky 67 Step
They are just blank 5-lug rotors that have been drilled to the 6-lug pattern. Piece of cake swap. I have ECE rotors on my '69,...
12-11-2013, 12:56 PM | #502 |
Vic, I was actually going back through your build thread trying to find some motivation. I have actually started working on my doors first before i start welding on the cab.. I figure if i mess up a door so bad it is unuseable then i can get another fiarly easy. This is probably better to start with. I am going to be putting the inner lowers on atleast the first door and probably both but I had a question for you.
In this picture I was curious how you manage the fold over from the outside side of the door.. I cant really tell from the picture. It looks like you actually cut out the fold over. Can you point me in the right directions on this so I know how to cut mine out and also add the new patch panel.
Project "Edna Marie"http://www.67-72chevytrucks.com/vboa...74#post5998074 Toys: 2014 Dodge Ram 1967 SHORTBED |
12-11-2013, 01:43 PM | #503 |
I've never had any luck straightening out the factory clamshell lip that holds the doorskin to the inner panel. They make tools (cheap and expensive) that are supposed to be the hot tip, but I've never found one that truly works. Every time I've tried to work the lip back up to a 90 like you get on a new doorskin, I end up damaging the edge and making more work for myself than it's worth. Anytime you bend metal, it work hardens. Just take a piece of scrap, put a 90 degree bend in it and then try to flatten it back out. You have to beat it into submission.
So the approach I use is to take a cutoff wheel and remove all but about a quarter of an inch of the folded over lip. Cut all the way thru the lip and the inner panel structure, but not thru the outer skin. Remove the lower part of the inner door panel you're going to replace to give you better access. Then carefully pry up a corner to expose the trapped strip of sheet metal left behind. I grab it tight with a pair of vise grips, then start tapping the grips with a small brass hammer to work the strip out of the recess. It will take several attempts to remove the entire strip and I usually reset the grips every few inches. Once it's out, I use a thin cutoff wheel in my Dremel tool to gently clean out the rust and debris from the groove. You end up with a small recess around the perimeter of the door that, from the outside, doesn't look like it was ever disturbed. On the backside, I then trim the replacement panel to slip into what is left of the recess. Once the rest of the panel is fitted into place, I tack weld the lip to the replacement panel every few inches and then use seam sealer to finish up. Welding it solid may warp the skin, so I try to avoid that.
Victor 57 Chevy Wagon - California Dreamin'"Mecum'd" 9/2022 Dallas, TX Crusty Rusty Leaky Squeaky 67 Consigned 4/2019 Dresden, Germany Maybelline - my '57 Ford 2dr Sedan "Mecum'd" 3/2016 Location unknown Silver Streaker "Mecum'd" 4/2013 Somewhere in Texas |
12-11-2013, 07:44 PM | #504 |
Great write up on that process!
'77 K30 3+3 - "The Crummy" http://67-72chevytrucks.com/vboard/s...d.php?t=640134 '67 C10 L/SWB - Soon to be daily driver! http://67-72chevytrucks.com/vboard/s...d.php?t=471776 |
12-16-2013, 05:06 PM | #505 |
OK, back in the shop from a week in Houston, TX and early Christmas get togethers. Two down, two to go. We were late returning to KC from Houston due to all the ice in Dallas. Called best bud, Jay, a week ago Saturday and he said he had 1.5" of ice on his driveway in Granbury and they were iced in. So we had to skip a much desired visit to see his Chevy truck project. Definitely plan to reschedule, though.
Posted some photos earlier of the center caps I had CNC'd while in TX. Still haven't finished them up as I've been shaking off a bad cold. While we were in Sedalia this past weekend, I was able to sneak away from the Christmas mayhem and get Keith Daleen to punch some louvers for me in the heat shield. Turned out pretty nice. Also managed to get over to Eagle and pick up the wheels, firewall and etc. last week. Threw the f/w up on the cowl to see how it matched up to the floor pinch weld flange. Don't know why I was so hopeful this would be an easy deal. As you can see from the photos below, between the frame supports the shape of the firewall and floor couldn't be much different. Outboard of the frame supports, the two panels fit fairly well but it will take major surgery to get the rest to fit. I know because I trial fit the floor to the frame that all of work will have to be done to the firewall. Because I set the small block back in the six cylinder motor mount holes, the floor is already very close to the transmission case. So that means I can't move the floor down to meet the f/w. Time for the Sawsall.
12-16-2013, 05:33 PM | #506 |
That looks like a challenge to me but I bet you make snappy work out of it. Heat shields look slick man! Still anxious to see how you get the POR clear coat sorted out too.
12-16-2013, 06:15 PM | #507 | |
Meanwhile, I have a ton of prep work to do before anything goes on the wheels. They came back from Eagle with the worst of the clear powdercoat removed. But in the lugnut recesses, the large openings and around the bolt heads, a fair amount of residual coating remains. To clean it up, I have to run a four flute mill down the recessed areas and turn it by hand to shave off what I can. Then I use a small flap disc to get the rest. Afterwards, I put the wheel in the blast cabinet to get the finish back to a satin look. I have some 2.5" flap wheels coming that I will use to clean up the large openings. Only thing that seems to work around the bolt heads is an Xacto knife. Taken together, it's very slow going. Wish now I'd never gone with the clear powder. Live and learn.
12-16-2013, 06:35 PM | #508 |
sounds like an xacto knife would be a PITA... What about something like a dremel tool with some sort of sanding attachment? Or would that be too rough?
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
12-16-2013, 06:44 PM | #509 |
That's not a bad idea. I have several possible attachments for the Dremel that might work. Will give it a try and report back …tomorrow. Headed out for yet another family gathering in a few minutes.
12-16-2013, 08:53 PM | #510 |
I'm hoping that fresh powder was a bunch tougher than an old OEM clear coat and I'll be able to blast - shoot with noooo touchy! I feel your pain on the meticulous scratchy/scrapy/sandy you've got ahead. At least you have the end mill to get at the lug nut cavities! Thanks for the updates and sand on!
12-16-2013, 09:53 PM | #511 |
In post 505, IIRC, I had to do several pie cuts to get that area to lay flat....
Build looks great, enjoying your posts and pics.
12-17-2013, 12:19 AM | #512 |
The first time I had the wheels blasted, they came back very clean. The OEM finish gave up a lot easier than the clear powder coat did the second time around. I'd bet you'll have very little cleanup if you're only removing the original finish.
12-17-2013, 12:21 AM | #513 |
Thanks, Jim. Do you have a link to the post you mentioned? I always like to look at what others have done to resolve a problem.
12-17-2013, 12:28 AM | #514 | |
If you clamp the center ofthe trans cover, then work your way around, i think alot of that will pull in
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim Last edited by jaros44sr; 12-17-2013 at 12:53 AM. |
12-17-2013, 01:10 AM | #515 |
Try searching under tri-pro gpw build, back around 2008, page 6....dont know how to do a link
12-17-2013, 01:22 AM | #516 |
Here is a floor pan install link Vic, not sure if this helps . Everything is looking great.
http://67-72chevytrucks.com/vboard/s...=311224&page=2
Scott |
12-17-2013, 02:12 AM | #517 |
Here is jaros44sr build he was talking about.
http://www.67-72chevytrucks.com/vboa...ighlight=Floor
Scott |
12-17-2013, 09:07 AM | #518 |
Feelin' ya on the cold, Vic... I'm on the backside of round 2. Good lookin' work, can't wait to see what's next!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-17-2013, 12:01 PM | #519 | |
12-17-2013, 12:02 PM | #520 | |
12-18-2013, 09:27 AM | #521 |
I think HF has a flap wheel that expands radially with a 1/4" shaft, for what it's worth. About an inch long.
12-23-2013, 08:06 PM | #522 |
Remodeling (basement this time) has once again cut into the truck build, so not a lot has been happening on that front. I did manage to finish cleaning the clear powdercoat from around the rivet heads on the wheels. I tried several things such as tiny sanding drums, mini carbide burrs, Cratex abrasives and etc., but nothing worked as well as the Xacto knife. So I painstakingly scraped every one of the 80 rivet heads and then hit them with the glass beads to remove the shiny places. I bought some 2.5" flap wheels from CGW and they work great in the big holes. Despite all of this, I'm still considering painting the wheel centers the Toxic Orange Pearl color to match the body. I'd leave the outer rims the aluminum finish with a coat of the Glisten PC over all of it. There are still a lot of warts on the wheels despite all the prep work. Painting the centers would hide a lot of evil.
I also did a bit of work on the floor. Pie cut the ends where they angled down and welded in some tapered material. The ends now go out straight and match the ends of the firewall. The rest of the f/w is another matter. I've laid out the cut lines I'll need to make to bring it in line with the floor. I'll have to remove a center section of the f/w completely, reform the bottom lip to match the floor and then weld it back in. Removing it will also allow me access to pull down and straighten the section that kicks up as it gets close to the tunnel. As they say down in TX ...all that stands between me and the finish line is fear and thin air.
12-23-2013, 08:35 PM | #523 |
That's a ton of fiddling around on the floor but you're making it look easy! Wheels look sharp too. I think you could pull off the painted centers. It'd be cool if you could leave the big holes natural. Wonder what'd take to polish the outers? It'd be cool if you could drill them phony rivets out, polish, then mash something custom back in to the rivet holes (polished SHCS or something)??? Just thinking out loud, no doubt about it, whatever you finish with is going to be trick and sanitary.
12-23-2013, 09:41 PM | #524 | |
12-24-2013, 07:19 PM | #525 |
Today was slice and dice time. After laying out the cut lines, I made the two vertical cuts on each side as well as a short horizontal cut at the top. Turns out the horizontal cuts were not really needed. I was able to move the firewall pinchweld edges into position with just a few light taps from a rubber mallet. At this point, I could tell the area around the curve of the tunnel would need some serious hammer and dolly work to get it to fit the floor. I started by flattening the pinchweld lip and then folding it back opposite how it was originally formed. I then laid down some tape on the roughed in edge as a guide for the final lip.
