12-06-2013, 09:19 PM | #51 |
Re: Winter Beater Build- '66 BBW Custom Short/Fleet with Heat!
It will be a blast driving the new (to you) truck.
12-10-2013, 01:30 PM | #52 |
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-14-2013 at 08:19 PM. |
12-14-2013, 08:22 PM | #53 |
Got the front brakes done today, and also cut 1.5 coils off the front springs. Those self adjuster parts are a bit of a pain!
Supported the weight of the truck using jack stands on the frame, then supported the lower A-arm with the jack and broke loose the lower ball joint. I used a ratchet strap to hold the spring in place in case it wanted to jump out, and slowly lowered the A-arm down to release the spring. Chopped 1.5 coils off. Brakes rebuilt. Started cleaning the paint with 0000 steel wool. Back on the ground. We'll clean up the original hubcaps and put them back on. I thought the wheel paint would match better so those will get resprayed too.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-26-2013 at 05:45 PM. |
12-14-2013, 09:20 PM | #54 |
Looks good! The green spring on the bottom of the brakes is backward. The long bend clears the star wheel. Not to nitpick, just pointing out. (BTDT) Man, it's really looking good!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
12-14-2013, 09:37 PM | #55 |
Appreciate you posting, I put them back the way they were and didn't know it was in wrong. I'll go back in and straighten them out!
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc |
12-14-2013, 10:23 PM | #56 |
Glad I could help.
12-15-2013, 01:15 AM | #57 |
Cool truck. Sometimes its nice to just have a little beater driver that doesn't have to be perfect
1960 short bed fleetside factory 4x4 1960 panel 454 NV4500 Daily driver 1961 Short Bed BBW Fleetside 5.3 th400 swap in process |
12-15-2013, 08:36 AM | #58 |
It's coming together very nicely.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
12-15-2013, 12:26 PM | #59 |
Coming along nicely! 0000 steel wool to clean paint? I still learn something new every day! Does it require a lubricant? I assume it requires some kind of buffing process afterwards?
Nick Carter 1967 C10 Short bed Fleetside Project Cheap Thrills! 2WD C10 Modern/Performance Alignments Easiest Alignment Ever! |
12-15-2013, 12:37 PM | #60 |
Truck is looking great
12-15-2013, 01:55 PM | #61 | ||
Thanks!! Quote:
Thanks!
12-16-2013, 10:12 AM | #62 |
Love the hood work! This thing is coming along rather nicely.
12-17-2013, 09:28 AM | #63 |
Nice. I have always liked the light blue and white combo.
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
12-17-2013, 10:43 AM | #64 |
Progress is coming along nice. Great looking truck.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
12-17-2013, 10:51 AM | #65 |
Watch out for your cornhole !
To add to that, on those bottom springs, there is always one end with a long hook. That end is the one that goes towards the adjuster wheel. This applies across the board, not just GM trucks. The hook passes by the star wheel without rubbing where if you put it in backwards like the pic, the spring coil rubs on the star wheel.
12-21-2013, 07:17 PM | #66 |
Thanks guys!! Just dropped it back on the ground, did the jeep springs and rear brakes after lunch today. Also scrubbed more of the paint. The back is lower than the front now, gotta fix that We bought paint for the wheels that matches better, but I'm still undecided. Maybe white, or black? I'm off all next week so we should have it driveable if everything cooperates. Like that ever happens...
Swapping out the rear coils, two bolts is all that hold them in. Back on the ground. There's a ton of junk in the bed, so it will hopefully come back up an inch or so to level the truck out. If not I'll drop the front a little more.
Project Goldilocks '66 C10 Short Fleet BBW Build '65 C10 Highly Detailed Stock Restoration Thread '78 Camaro Targa Roof Build '55 International Metal/Body/Paint Work '66 F100 Full Rotisserie Restoration '40 Packard 120 Convertible Coupe Restoration How To Restore and Detail an Original Gauge Cluster How To Detail Sand Body Panels, Edges, Corners, Etc Last edited by theastronaut; 12-26-2013 at 05:42 PM. |
12-21-2013, 07:42 PM | #67 |
Don't do black wheels. Do white if you don't do the blue. White will keep the wheels from disappearing. Although with caps it will still look kool.
12-22-2013, 11:48 AM | #68 | |
I'm figuring that you plan on running the caps that came on the truck when you got it. A little paint and a shine on those and they'll look great.
Check out my latest endeavor: https://roundsixpod.com My build threads: '55 Chevy: http://67-72chevytrucks.com/vboard/s...d.php?t=247512 '64 C-20: http://67-72chevytrucks.com/vboard/s...d.php?t=446527 |
12-22-2013, 12:25 PM | #69 |
Shoot'em White and get back to Goldilocks!
Like driving with heat once again?? |
12-22-2013, 04:17 PM | #70 |
Looks good! We need a real world report on the TJ springs. Git ta fixin and drivin!
PS- It gets colder'n hell in Germany. Why did the over engineerin' Germans then design the most useless heater system on the planet? I got it, they were Nazis and wanted to ensure the world's suffering long after they were gone.
12-22-2013, 05:11 PM | #71 | ||||
The original heater in my '64 would cook you out of it, nothing in the system had ever been monkey'd with so it worked great. Most people ripped out the thermostat and wired the flaps open, or had such poorly fitting tin that the system didn't move enough air. Taking the heater boxes and ducts completely off to add a header may not have been my best idea lol.
12-22-2013, 05:13 PM | #72 |
I vote light blue (matching) with a white cap and thin white walls
GOD BLESS AMERICA! |
12-22-2013, 07:12 PM | #73 |
Black wheels have been played out a lot lately. Nothing against them but they are on everything from T Buckets to new trucks. I like the look of dog dishes on black wheels but on your truck I just don't know if I'd want that look. It would definitely make it look a little tougher. With your truck the white wheels would keep it classy and timeless. Just my .02, lol. Still love this truck and can't wait to see it done.
12-23-2013, 05:18 PM | #74 |
Artist
Thanks for the props!! My thoughts are the light blue with the dog dishes. Not a fan of white wheels. That way you keep the original look that I think that truck needs. Then a set of the White 66 Dog Dishes would have my vote. Just to keep it classy. The thing I love about this era trucks is the body color wheels. :-)
66 Chevy C10 283ci~cough~ SBW Fleet Buttercup '66 |
12-23-2013, 05:53 PM | #75 |
Light blue is/was my first choice... The rattle can light blue I found was a satin paint, and I think that's why it didn't look as good as I thought it should. I'll try some gloss clear over it.
