Old 12-29-2013, 02:58 PM   #1
Hellion Customs
Hellion Customs's Avatar
Hellion Customs 1955 Chevy Truck
Thought we would post up a build thread on a customers 55 we are building right now. When this project originally came to us it was just a set of rusted fenders needing some metal work. Well one thing led to another... This build is on a extremely tight budget so some of the materials and prosesses are not how we would normally do things or materials we would normally like using. But plans for this one so far are, rust repair & full paint and body while keeping the truck exterior basically stock, full C4 suspension front and rear on coilovers, LS1 & 4l60, one piece power door glass, frame mounted brake booster, tilt, ac, ect...
Hellion Customs is offline   Reply With Quote
Old 12-29-2013, 03:00 PM   #2
Kim57
Kim57's Avatar
Re: Hellion Customs 1955 Chevy Truck
Sounds nice.
How about some pics?
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 12-29-2013, 03:10 PM   #3
Hellion Customs
We removed all the glass, doors, the remainig dash hardware, wiring ect.. Then we blasted the interior surfaces that are to be painted. Then sprayed on a few coats of Epoxy Primer.
Old 12-29-2013, 03:37 PM   #4
Hellion Customs
Moving on to some rust repair.. Starting with the cab corners. This one needed both L&R inner and outer corners. We trimmed down both inner and outer patches that we got from Brothers to a more manageable size, then trimmed off enough of the OG metal to fit up the patches for a scribe line, fitting and tacing on the the exterior first as it is critical for all body lines and also to locate the inner panel.
Old 12-29-2013, 03:40 PM   #5
Hellion Customs
Cut out inner panel for replacement. We will blast mating surfaces before reinstalling.
Old 12-29-2013, 03:47 PM   #6
Hellion Customs
Inner panel fitted and tac welded in.
Old 12-29-2013, 03:47 PM   #7
The Haberdasher
Nice
The Haberdasher is offline   Reply With Quote
Old 12-29-2013, 03:50 PM   #8
Hellion Customs
Inner cab corner patch welded up and metal finished out.
Old 12-29-2013, 03:54 PM   #9
Hellion Customs
Outer cab corner welded up and metal finished out.
Old 12-29-2013, 03:59 PM   #10
Hellion Customs
Left cab side needed some metal finishing and some old holes from a slide hammer welded up. Also we are relocating the fuel tank so the filler neck hole needs to go.
Old 12-29-2013, 04:03 PM   #11
Hellion Customs
Cab corners and sides ready for some epoxy. Next we tackle the steps.
Old 12-29-2013, 05:23 PM   #12
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Great work Ray. Rust repair turned out great.
--Josh
My Build Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=799218
A good crossthread is better than Loctite any day.
Life is not about what you have, but who you have to share it with.
STOCKISH is offline   Reply With Quote
Old 12-29-2013, 08:29 PM   #13
papastrk
Nice work. Thanks for posting.
papastrk is offline   Reply With Quote
Old 12-30-2013, 01:00 AM   #14
Kim57
Kim57's Avatar
Nice repairs.
Kim
My build thread
Old 01-13-2014, 12:53 AM   #15
Hellion Customs
Originally Posted by Kim57 View Post
Nice repairs.
Kim
Thanks guys!
We have been extremely busy with a few other projects here, but we finally got some time back on the 55. We need to replace or repair a bit of metal here so we came up with a game plan and started with the right side lower hinge pocket since we needed to remount doors to get our lines to replace the steps and rockers.
Old 01-13-2014, 12:55 AM   #16
Hellion Customs
Lower hinge pocket in need of rust repair
Old 01-13-2014, 12:59 AM   #17
Hellion Customs
Lower hinge pocket welded to A-Pillar and tek screwed to step.
Old 01-13-2014, 01:02 AM   #18
Hellion Customs
Right side steps removed and blasted flanges.
Old 01-13-2014, 01:04 AM   #19
Hellion Customs
Right side step reinstalled and welded in.
Old 01-13-2014, 01:17 AM   #20
Hellion Customs
Now the panel that is between the lower hinge pocket and the step is rusted where the hinge pocket overlapped it and needs replaced but the cab mount/step brace attached to it and the floor at mount bolt location need repair also, so I felt it would just be easier to remove all at once and repair separately on the bench and also to gain access to the kick panel area that is also rusted.
Old 01-13-2014, 01:20 AM   #21
Hellion Customs
Cab mount/step brace kick panel area repair
Old 01-13-2014, 01:22 AM   #22
Hellion Customs
Cab mount/step brace repair
More pics up tomorrow
Old 01-13-2014, 11:04 AM   #23
Kim57
Kim57's Avatar
Nice progress.
Kim
My build thread
Old 01-13-2014, 01:27 PM   #24
Hellion Customs
Next thing i needed to fab up and install the panel at the front of step area between the hinge pocket and inside of step.
Old 01-13-2014, 01:29 PM   #25
Hellion Customs
Then on to little rust repair on the kick panel/toe board area
