Old 05-20-2013, 07:11 PM   #51
LVPhotos
LVPhotos's Avatar
Re: LVPhotos 1962 Build
1962 shortbed 408cui small block, TKO 600 5-speed, bagged Porterbuilt suspension. 18" Salt Flats
http://www.cardomain.com/ride/332579...t-c-k-pick-up/
http://67-72chevytrucks.com/vboard/s...d.php?t=560081
LVPhotos is offline   Reply With Quote
Old 05-20-2013, 07:12 PM   #52
LVPhotos
LVPhotos's Avatar
Old 05-20-2013, 07:59 PM   #53
Jmorales3181
Jmorales3181's Avatar
Sounds good!
My frame Layin 63 short bed project
http://67-72chevytrucks.com/vboard/s...d.php?t=551353
Jmorales3181 is offline   Reply With Quote
Old 05-20-2013, 11:06 PM   #54
markeb01
Senior Enthusiast
markeb01's Avatar
Very cool! Thanks for sharing.
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 05-24-2013, 05:13 PM   #55
LVPhotos
LVPhotos's Avatar
Just in... Porterbuilt trailing arms. Taking donations to get more parts and powder-coat! Thinking chrome powder coat or a charcoal grey. Any other colors? Not black, white, red or pink? Truck is going to be Daytona Blue. Florescent green might not make the cut. Has to be "timeless" and likable years from now.
Old 05-26-2013, 10:07 PM   #56
flips72
flips72's Avatar
I can smell the rubber burning now sounds awesome
flips72 is offline   Reply With Quote
Old 06-14-2013, 05:35 PM   #57
LVPhotos
LVPhotos's Avatar
Primed the front fenders.
Old 08-21-2013, 07:38 PM   #58
LVPhotos
LVPhotos's Avatar
Working in the garage on the rear tubular trailing arm from Porterbuilt. Bags at 80psi full up.
Old 08-21-2013, 07:43 PM   #59
LVPhotos
LVPhotos's Avatar
Out with the old boxed and powder coated originals in with Porterbuilt tubular extended 1/2" bars. This will center the axle in the wheel house. Yes there is daylight in one shot but the bolts were hand tight.
Old 08-21-2013, 07:46 PM   #60
LVPhotos
LVPhotos's Avatar
Still on jack but tucked all the way. No bump stops or pipe notch. Yet.
Old 08-22-2013, 02:19 PM   #61
dr69burb
dr69burb's Avatar
nice man looks good
Baggin 64 lwb project
http://67-72chevytrucks.com/vboard/s...d.php?t=537406
dr69burb is offline   Reply With Quote
Old 08-23-2013, 04:55 PM   #62
LVPhotos
LVPhotos's Avatar
Cut the pan-hard bar mount off. Reposition the rear. Did valve cover swap, with hint of the body color. Full down on frame and fender, time for a nip/tuck and pipe notch. Swapped in the MSD Distributor and coil, no more HEI.
Old 08-25-2013, 08:22 PM   #63
LVPhotos
LVPhotos's Avatar
Post on trailing arms not working. What's a good price range for the ones I pulled off?
Old 09-05-2013, 07:37 PM   #64
LVPhotos
LVPhotos's Avatar
Workin!
Old 10-25-2013, 12:12 PM   #65
LVPhotos
LVPhotos's Avatar
Some updates. Dragged a 4 door dualy to buddy's house. Applied GM engine decals. The 400 is early Caprice which is right size and car wrong year. The 400hp is for the 409. Test fitting Porterbuilt bar and frame mount. Now the axle sits 1/2" back the new mount is relocated rear of crossmember about where the 63-72 is.
Old 10-25-2013, 12:36 PM   #66
jchav62
1962 C-10
jchav62's Avatar
I like! Very cool project...
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline   Reply With Quote
Old 10-25-2013, 03:36 PM   #67
TJ's Chevy
TJ's Chevy's Avatar
Looking sharp!!! Awesome!!!
Old 12-11-2013, 06:13 PM   #68
LVPhotos
LVPhotos's Avatar
Found this initial measurement of rear ride height with 275-60-15s minus bed weight.
Old 12-19-2013, 01:28 PM   #69
LVPhotos
LVPhotos's Avatar
since cardomain is now jacked here are exhaust pics
http://carphotos.cardomain.com/ride_...iginal.jpg?v=0
Old 12-19-2013, 01:29 PM   #70
LVPhotos
LVPhotos's Avatar
Old 12-19-2013, 09:31 PM   #71
TJ's Chevy
TJ's Chevy's Avatar
Sure as heck is alot cleaner under there then my truck is! LOL!
Old 12-19-2013, 10:36 PM   #72
NEWFISHER
NEWFISHER's Avatar
Cool build. Do the PB rear arms drop it any over using stock or just move the axle location?
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 12-19-2013, 11:27 PM   #73
LVPhotos
LVPhotos's Avatar
Built in L.A. and has been in Nevada most of its life. Few months in AZ when I was in college.
Old 12-19-2013, 11:32 PM   #74
LVPhotos
LVPhotos's Avatar
I believe they have 1" built in but you can get 3" ones. I plan to pipe notch and not go more... for now. They solve the centering of wheels and axle angle.
Old 01-02-2014, 09:57 PM   #75
LVPhotos
LVPhotos's Avatar
Rearview.
1962 chevy, bagged c10, manual transmission, short bed c 10
