01-03-2014, 04:17 PM | #726 |
I know the pieces fit
Re: The Hillbilly Deluxe dually build
I can't believe I'm reading you guys talking about eating an elephant because that's the way I've started thinking of it in the last month or so. I haven't tried Rock Auto but I'm convinced now.
01-03-2014, 04:21 PM | #727 | |
Watch out for your cornhole !
1939426717018033 Its good for 90 days, unlimited usage. Give it to anyone and everyone. Use it as many times as you want. There's no limits on how much it's used and by whom.
01-03-2014, 06:49 PM | #728 |
UPS delivered like expected. One day shipping for 4 bucks. This is why Amazon is on their way up and local retailers are on the skids.
Made in USA quality. All installed. I torqued and cotter pinned all hardware on the front suspension. Then a full grease job. There are 20 zerks on this front suspension. It took a full tube of grease to do them all. Then I bled the front brakes and called it a day. Tomorrow I'll get Valerie out there to help me set the toe-in and the front will be entirely complete. Then to start on the clutch, bell housing, transmission and rearend. It won't be long now.
01-03-2014, 08:30 PM | #729 |
I don't see how they can deliver anything for 4 bucks, it costs me 8 every time I go to the post office.
Gary 1971 Chevrolet C/10 1951 GMC 100 1977 GMC C15 1955 Chevrolet 3100 |
01-03-2014, 08:51 PM | #730 |
My wife is an Amazon Prime member which gets free two day shipping on all her orders. Its a thing she pays like 80 bucks per year to belong to. As much as we order from them, it's a fantastic deal for us. Average one order a week and the 80 dollars per year for free shipping is a bargain. In this case, I wanted to get the front end part of the project tied up soon and there's a bad cold spell coming Sunday, so she paid an additional 4 dollars for next day shipping instead of two day shipping. That way I wasn't laying under the truck on Monday in 20 degree temperatures to install it.
01-03-2014, 10:01 PM | #731 |
The prime definitely pays off if you use it a lot. My wife bought me an action camera for Christmas and it was broke. After dealing with the manufacturer. they told me to send it to them, at my expense (it was brand new). I was kinda miffed, so my wife said she would send it back to Amazon. I was amazed that they paid for the shipping! The wife printed off a UPS bare code and I dropped it off yesterday in about 20 seconds. I also went with a different camera company. Can't say enough good things about Amazon....
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
01-04-2014, 09:05 AM | #732 |
Well, that sounds worth having. I don't order too much from Amazon, maybe I should take another look at it.
01-04-2014, 10:37 AM | #733 |
My wife orders from Amazon a lot and she's a prime member. It works out good. I personally haven't ordered any thing from them yet. But they seem to have good service and quality customer service.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
01-04-2014, 01:09 PM | #734 |
I have an Amazon prime membership as well, bought a complete ACDelco clutch kit for my 400/sm465 from them, the HD one that is one step below the ceramic disc kit. It was about $106 and shipped to me in 2 days, Rock Auto couldn't even come close.
Devin 1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt 1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050 1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350 My Introduction with my '83s History New Daily, the '96 |
01-04-2014, 02:54 PM | #735 | |
Today I turned the truck around and began swapping the rear ends. First, this truck has a load sensing valve that modulates the rear brake pressure. It uses a lever and sensor that detects how high or low the rearend is in relation to normal ride height. That, then guesses at how much load is on the truck. If it's sitting lower than usual, it applies the rear brakes stronger than normal unloaded height. Since I lowered the truck, this stuff is all out the window. I've seen poor reliability on these anyway, so I'm going to remove it in its entirety and run normal unrestricted rear brakes. More to come later in the project. Valve mounted on the frame. Brake line in and brake line out. The swing lever controls its operation. The lower end of the lever is mounted to the top of the rearend. A few nuts and bolts later, we have this. I sprung for a pair of Harbor Freight mover dollies to help me move this heavy thing around. I'm also going to remove that upper overload spring and little spacer block. It won't affect the ride height any, but the truck being lowered, that leaf is too close to hitting the overload brackets on the frame. When I get off work Monday morning I'll drop by the spring shop and have a couple of pairs of new, shorter, u bolts made up. I need shorter u bolts to compensate for removal of the overload and spacer blocks. I'll also get a shorter pair of spring pack center bolts. When I disassemble the pack to remove the overload and spacer, I'll need shorter center bolts. And, for the folks who haven't followed this thread every page, a reminder of what I'm putting back in.
01-04-2014, 03:02 PM | #736 |
I chuckle every time I see the wheelchair. . .....
01-04-2014, 03:37 PM | #737 |
That is a classy looking rear end!
01-04-2014, 09:01 PM | #738 |
01-04-2014, 09:09 PM | #739 |
Why am I a Moog fan boy ? Because they're the best. Look closely at my two pictures below. This is an idler arm off my 89 NBS truck. Notice the massive difference in size between the stock one and the Moog one.
Look closely at the pivot point. The Moog is nearly twice as substantial in that area. More surface area means stronger and longer lasting. And the grease zerk is relocated to a more convenient spot too. There is no comparison.
01-05-2014, 12:08 PM | #740 |
This is the second reference (unless I missed one) to you tinkering on the 4x4. Will you be putting together a build thread for it too?
01-05-2014, 02:09 PM | #741 | |
But, first I will finish this truck. I can't do good work and stay focused on two trucks at the same time. I've been thinking about whether I want to pull the transmission and go through it and the clutch or just run it for now and maybe do an NV4500 swap in the future. Even with the 4.10 gear I'm installing, an OD would be welcomed. I'm still mulling it over.
01-05-2014, 02:31 PM | #742 | |
Hah, I should have caught that when you said '89, I knew the 4x4 is newer. A 4500 swap is a beautiful thing, I have one in the works myself. After a lot of research I chose an early one with external clutch slave cylinder. The later design with the fully synchronized 1st & Reverse was appealing, but I am not sold on the internal slave/throwout bearing assemblys used in them. How have you decided to address the routing of the parking brake cables on Hillbilly Deluxe? Did you have or will you be keeping the factory rear swaybar? I ask because with the purchase of new ubolts, this is an ideal time to ditch that saddle-under-axle tube style plate that GM used. I am not a fan of how they collect dirt/debris and accelerate the deterioration of the bolts, but I recognize they are necessary with the factory style swaybar mount. With the disassembly of the rear springs will you be coating and installing new pads between them?
01-05-2014, 03:58 PM | #743 |
So, i dont mean to intrude on the tech here with silly questions, but i decided to give rock auto a shot. i want to order a serpentine belt, with no specific application. just a length and rib count. i cant make the damn website do anything for me. i also need to order a few wheel cylinders and cannot find a place that it actually list the country of manufacture or origin anywhere. am i just stupid, or is there some things that rock auto wont do for you?
01-05-2014, 04:25 PM | #744 |
ok, i think i figured it out. significant savings. i really hate to abandon my local businesses but jeez. all the good counter guys get hired elsewhere because they dont make enough money and i end up trying to tell the tards that are left how to look up parts. gets old.
01-05-2014, 06:46 PM | #745 | ||
Currently, I'm at the fire station counting the minutes till I get off in the morning and I'll go by the spring shop to get my u bolts made. I've been searching Craigslist looking for a stock 85-87 four headlight grille for this truck. I figured I'd try to find someone who wants a billet and trade them for their stocker. I think the dually will look better with a stock grille with white center bar. I had the same combo on my 83 about 20 years ago and I sure liked it.
I'm on the Instagram- @Gearhead_Kevin Last edited by Tx Firefighter; 01-05-2014 at 09:09 PM. |
01-06-2014, 09:34 AM | #746 |
Progress is lookin' good! Can't wait to see how it comes out!
Boppa's Old Yeller Truck Build, Old Yeller's New Heart! Project Buzz Bomb Flyin' Low! |
01-06-2014, 04:51 PM | #747 |
Since 1928 in the same location. I love this place. They make your u bolts while you stand there. Old school.
It's too cold to work outside now so not much progress today.
01-06-2014, 05:13 PM | #748 |
I'm just glad to be here!
Yeah, its cold here too. My office has frozen water pipes today....
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
01-09-2014, 11:48 AM | #749 | |
Your wheels are a work of art and I know you did a lot of hand work getting them that way. I saw in an earlier post someone had a machine that would do a lot of work on wheels. With that in mind, please tell me why I would be totally crazy to try something like this: Put the rear axle on jack stands and run the truck in gear, using the rear axle like a lathe. Use manual or machine tools to apply the restoration steps: sanding, polishing, buffing, and maybe even coating. I have even further to go than you did, so I'm looking to minimize the elbow grease. Thanks in advance for your help and all your posts.
Mama Truck: 1996 S10, 4 cyl, 5 spd. Papa Truck: 1973 Cheyenne Super 20, Camper Special, 3/4 K20 350, manual. |
01-09-2014, 01:03 PM | #750 |
Doing what you are suggesting would be very dangerous ,might lose a limb or your life .
