01-10-2014, 09:41 AM | #1 |
Widen wheel tubs question??
I need to widen my wheel tubs to fit my wheel/tire combo. Is there somewhere that makes a pre bent section that I can weld in to widen them. I do not have the capabilities or the knowledge to do it myself.
01-10-2014, 10:06 AM | #2 |
Moderator
Re: Widen wheel tubs question??
How about a set of used tubs to cut a section out of? If you want perfect, new tubs are only 80 bucks from Top Banana.
01-10-2014, 10:06 AM | #3 |
I bought a second set and split them adding 2 inches and just one seam to weld up. just offset the cut on the other tub the amount needed when you cut it.
Jimmy
60 to 66 Chevy and GMC window decals http://67-72chevytrucks.com/vboard/s...d.php?t=661131 Good friends, good food and a hotrod what else do you need? 1966 BBW long fleet Daily driver 1965 BBW short fleet Sold and going to a good home 1965 Suburban 2003 3500 Duramax 2005 Ultra Classic |
01-10-2014, 12:46 PM | #4 |
I used two sets of OEM ones also to make wider ones.
1962 Impala SS 383 stroker Tremec TKO 600 Black 1965 SWB BBW Fleetside Custom Cab PB Coilover setup Black 2003 100th Anniversary Road King Classic Silver Black |
01-12-2014, 09:12 PM | #5 |
ok cool that sound like a plan?
01-14-2014, 01:30 PM | #6 |
It's Better With Nitro
1963 C-10: Deluxe-optioned cab, shortbed, fleetside Pontiac 462 ci, Kauffman D-Port alum. heads 4L80E, narrowed sheetmetal Ford 9-inch Tubular front and rear suspension Custom 6-piston front disc and 4-piston rear disc brakes |
01-14-2014, 02:07 PM | #7 |
"Where were you in '62?"
My Ole' Stepside Mini Tubs $50.00:
"1962 Chevy C-10 Stepside Parts for Sale" & miscellaneous stuff http://67-72chevytrucks.com/vboard/s...d.php?t=337099
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
01-14-2014, 06:24 PM | #8 |
I bought a set of repop fenders, cut both old and new sets, welded them together for a few more inches. Keep in mind that you might need to add/move the skid strip mounting holes in the fender lips if you keep the wood bed. I added some and bent the lips to make it look stock where the strips go under.
01-14-2014, 07:39 PM | #9 |
Just sectioned the stockers and added a 4" strip...
1958 Chevy 1 ton dually 4X4 dump/flat bed My build thread 1966 "Not-So-Original" Chevy Custom Trim Suburban My Time-Killing Project Truck 1966 GMC Extended cab 1 1/4 ton 4X4 My Son's build thread |
01-14-2014, 07:56 PM | #10 |
I didn't get to do mine but I thought it'd throw in a pic since there square n not round.
Live and let live |
01-14-2014, 08:19 PM | #11 |
I widened mine 4 3/4", they are 16" wide, I also used 67-72 tubs had to cut the opening where they bolt to the inner bedside to match
my project: http://67-72chevytrucks.com/vboard/s...d.php?t=456163 |
01-15-2014, 08:53 AM | #12 |
So after you guys are putting fatter tubs in, What size rim and what off set with a fleet side bed ??? What tire ???
01-15-2014, 02:26 PM | #13 |
If my truck sits lower, can the stock wheel tubs be made taller as well?
01-15-2014, 06:14 PM | #14 | |
In my case, I raised the bed 1 inch in addition to widening the wheel tubs.
