#26 |
Re: Project '67 Clone SWB
Cleaned up and measured the deck clearance on the passenger side pistons last night. They're all running between .020" and .024" down. Gonna clean up the drivers side tonight and re-measure everything.
'67 K10 SWB 350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's My Project http://67-72chevytrucks.com/vboard/s...d.php?t=602684 |
#27 |
I'm guessing Go Seahawks?
#28 |
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#29 |
Well, it looks like I'll be replacing the cam in this engine. 2 lobes going flat, 2 scuffed lifters, and 1 lifter with a broken retainer. First thing I did when I bought the truck was change all of the fluids and the engine oil was filthy. The good news is, so far, everything else looks to be in good shape. I'm going to pull a couple of main caps and check the bearings tonight.
'67 K10 SWB 350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's My Project http://67-72chevytrucks.com/vboard/s...d.php?t=602684 Last edited by JayB331; 01-16-2014 at 12:12 PM. |
#30 |
Checked a couple of the mains last night, the crankshaft and bearings look good. I'm going to go ahead and change the rear main seal while I'm this far into it. I pulled the trigger on a Comp Cams Nostalgia Plus 300HP cam last night. My goal is to have it back running by Super Bowl Sunday
#31 |
Got a lot done in the past couple of days. The block's painted as well as the oil pan, timing cover, harmonic balancer, and alternator bracket. I cc'd the heads yesterday evening and each chamber is 76-77 cc's. The pistons are averaging .023" in the hole. I'm going with Clevite Nitroseal head gaskets with a compressed thickness of .026" giving me a quench area of .049". Plugging all the numbers in the trusty old DCR calculator gives me a static CR of 8.94 to 1 and a dynamic CR of 7.56 to 1. Just waiting on parts now!
So this afternoon, me and a buddy of mine changed out the front springs. Did away with the stock front springs and blocks and put a set of 2.5" front springs in her.
#32 |
Keep at it, its starting to motivate me!
#33 |
By the way, Go Seahawks!
#34 |
Well, I found another unexpected issue with the motor. Most of my parts are in (still waiting on the cam and lifters) and I've finished painting the engine and detailing the engine compartment, so last night I checked the end play on my crankshaft and it's running .021" to .022". I thought about possibly putting in a .010" oversized thrust bearing, but that would leave me at .011" to .012", which is a little out of spec. I talked with the guys at Performance USA and they recommended against it, especially since I have a manual transmission. So they hooked me up with a local machine shop and I got a .020/.020 crank and a set of matching bearings for $140. I think I'm finally through spending money on the motor!
#35 |
Good thing you checked the end play before putting it back together!
#36 | |
New crankshaft is installed. .006" end play. That's more like it!
#37 |
I gave my headers to my buddy Jeff last week to get them ceramic coated. Just went by his shop and picked them up!
#38 |
Plenty of assembly lube used after checking end play right?
![]() The headers look sweet! I wish i had some buddies that worked in auto body right now.
#39 |
Mocked up the motor yesterday, still waiting on the cam and lifters
#40 |
Motor's back together. Gonna prime her up tonight. Plan on putting it back in tomorrow after work
#41 |
Motor's back in. I'll be posting pics in the next couple of days. Plan on breaking in the cam Friday evening
'67 K10 SWB 350, SM465, NP205, 12 Bolt & Dana 44 w/ 3.08's My Project http://67-72chevytrucks.com/vboard/s...d.php?t=602684 Last edited by JayB331; 09-20-2014 at 12:53 PM. |
#42 |
Getting close!
#43 |
Broke in the camshaft yesterday. Changed the break in oil, set the timing, and took her for a spin. Running like a champ! I get my hood back from the painter tomorrow evening.
#44 |
Great news!
#45 |
Thanks Rat! I understand you had some health issues. Hope everything is OK
#46 |
I've been asked to help on a side project for my buddy David. He just purchased a '64 Malibu project for his wife. 54,000 miles, all original, 283 Powerglide. The car's been sitting for about 18 months. We got it running but are chasing a major vacuum leak, 10" at idle. Yeah I know, it's not a truck but it's a Chevy!
#47 |
More engine pics
#48 |
A few pics from the beach
#49 |
Sweet!
#50 |
Pic of my truck next to my buddy T-Dub's '62 Nova out at the beach a couple of nights ago
