Old 01-27-2014, 11:01 PM   #1
19684x4
Big Cowl hood
Does anyone know where I can buy a 4" or 6" cowl hood for my 1968 4x4 chevy? I'm hoping to fit a weiand 250-256 supercharger.
19684x4 is offline   Reply With Quote
Old 01-27-2014, 11:11 PM   #2
Molberg
Molberg's Avatar
Re: Big Cowl hood
You can make one... Heard too many horror stories about after market for these. No factory dies to duplicate. Out of square, etc. bloody night mare. I made mine. Took some time but fits great. Go slow with the welding... Easy to warp if you do. Wasn't sure on the carb(s) setup... And still aren't. Wanted the clearance in case I got crazy.(mines a 4")
-Project Nitemare-
http://67-72chevytrucks.com/vboard/s...d.php?t=607359
Molberg is offline   Reply With Quote
Old 01-28-2014, 10:27 AM   #3
xman
Re: Big Cowl hood
they are pricey but you can check into Harwood
I have a four inch fiberglass hood on my wifes 72 pick up
came with the truck when we bought it
xman is offline   Reply With Quote
Old 01-28-2014, 11:26 AM   #4
Tinkermc
Re: Big Cowl hood
It's so easy save a bushel basket of money and make your own.
Tinkermc is offline   Reply With Quote
Old 01-28-2014, 12:01 PM   #5
71chevyowner
71chevyowner's Avatar
Re: Big Cowl hood
Auto metal direct sells a 4 inch scoop made from metal
71chevyowner is offline   Reply With Quote
Old 01-28-2014, 02:53 PM   #6
19684x4
Re: Big Cowl hood
Thank you all. I will check harwood and auto metal direct. What did you guys use to make your own? What did you use for cowl hump?
Old 01-28-2014, 02:58 PM   #7
71chevyowner
Re: Big Cowl hood
I used the 2 inch from auto metal direct
Old 01-28-2014, 03:13 PM   #8
19684x4
Re: Big Cowl hood
Does anyone know how big of a cowl it would take to cover a BBC with a 250-256 weiand supercharger?
Old 01-28-2014, 08:27 PM   #9
cheviss427
Re: Big Cowl hood
hello, i got my 4" cowl from unlimited, covers a tunnel ram....fiberglass, around $500
cheviss427 is offline   Reply With Quote
Old 01-28-2014, 10:00 PM   #10
454_72_4X4
454_72_4X4's Avatar
Re: Big Cowl hood
I'm not sure how tall that blower is, but I'd think anything shorter than a
4-71/6-71 would clear a stock hood.
Mine has a 454 and must be a foot between the top of the carb and the bottom of the stock hood. I do have a fiberglass cowl hood for it, but it's not on yet though.
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 03-15-2014, 07:30 PM   #11
Cumminpwr11
Southern Nevada Coal Roller
Re: Big Cowl hood
71chevyowner.
Do you have a part number for the 4"? I been looking and can't find it.
Also did you cut out under the hood or just add for looks. Just wondering about strength of the hood if you cut it out.
Any pics?
Chris
Chris
72 Suburban, 1 ton dodge chassis 4wd cummins, DTT 47rh 89%, PDR VE 3200 spring, PODS, Piers Turbo.
36 Chevy P/U rat rod project. 4bta cummins
Cumminpwr11 is offline   Reply With Quote
